1 Reply Latest reply on Mar 12, 2012 4:09 AM by staniere
    jfmerge: [240]Failure loading colour palette from form file.
    softdev20 Level 1
      Hi All,
      I need your help. I am new to JetForm and have to use it because of my work. Recently I have been assigned a task which is to amend an existing form, however, when I opened it with the JetForm Designer, it prompted me with message #4043 with following information:
      The current settings for Symbol Set handling are different
      from when the form was last saved.
      Form: Convert is Yes,950,950
      Current: Convert is Yes,1252,850
      I skipped the warning message and just compile the MDF file directly without any changes. Then, I just got the "jfmerge: [240]Failure loading colour palette from form file." error message during the printing process. May I know how could I fix it? Please help and advise.
      Charoite
        • 1. Re: jfmerge: [240]Failure loading colour palette from form file.
          staniere
          Hello,
          I have exactly same problem than you while opening an existing .ifd file :
          The current settings for Symbol Set handling are different from when the template was last saved.
          Template : Convert is No,936,850
          Current : Convert is N0,1252,850
          I suppose it is due to chinese characters (Simsun font) bad installed on my desktop, but it is only hypothesis.
          Did you achieve to avoid this message since 05/2011 ?
