1 Reply Latest reply on Jun 8, 2007 7:16 AM by Gorka Ludlow
    CSV , text file out put from flash exe
    Manu Palasery
      I want to save data from flash exe to CSV file and text file . OS is XP and there will be no server connections. Is this possible. Please help.
        • 1. Re: CSV , text file out put from flash exe
          Gorka Ludlow Level 1
          If th ecomputer you're working with has some server software running (Apache or IIS) you could save your data with php or asp. If you don't then you could use the Shared Objects (which works as a cookie, so you'll be e bit limited here). There was a function called MMSAVE back in FlashMX, don't know it that still works, that writes to a text file (but only in the development enviroment).
          Let me know a few more details and we'll find a way.
