1 Reply Latest reply on Jun 8, 2007 10:48 AM by Captiv8r
    HOW TO RECORD MOUSE MOVEMENTS
    Rosendo_Roche
      I have a group of slides which includes graphs and audio. I want to add mouse movements in order to pinpoint certain areas of the slide.
      I have not found the way to add the mouse movements to the slides.
      Any idea ?
        • 1. Re: HOW TO RECORD MOUSE MOVEMENTS
          Hi Rosendo Roche and welcome to our community
          Just right click the slide in the Filmstrip and point at Mouse in the resulting context menu. Then you should see an ability to "Show Mouse". Once you do this, you may configure the movement. Note the following:
          1. You may only configure the Starting point on the first slide where Mouse Movement begins. On each subsequent slide, the start point is determined by where the mouse Stopped on the slide before.
          2. You may only have a single movement occurring between two points. For example, from the upper left corner of the slide to the lower right. You may not configure something like a circling movement or a zig zag pattern.
          Hopefully this helps... Rick
