1 Reply Latest reply on Jun 7, 2007 3:43 AM by cf_dev2
    Reading Large Text Files into a Database
    sampsas23
      I have been having this ongoing battle with large files (3 MB or more).
      Basically each file is a comma delimited text file that on every line has information that needs to be checked against the database and then either updated or inserted.
      Right now I loop through every line in the file and using CFQUERY to do the database check and insert/update.
      But with the files being 3 MB, it is slow and timesout. The customer is not happy.
      For the database check I use "IF EXISTS (....) UPDATE .... ELSE INSERT ...."
      The ISP is using CF Server MX 6 and SQL Server 2000. I cannot use CFFILE for security reasons, they created their own CFX tag to accomodate uploads. So trying to access the file via SQL Server 2000 probably isn't possible.
      Is there a better way to deal with large files and trying to get them into the database?
      Any ideas would be appreciated!
        • 1. Reading Large Text Files into a Database
          cf_dev2 Level 1
          If you can't access the file via sql server, then its going to be difficult. Row by row inserts are slow. It would be faster to import the data into a staging table. Then update/insert the main table. Finally truncate the staging table.
          Sql server has a few tools for importing CSV files. I don't know which (if any) you have access to:
          BCP (can use it command line or via xp_cmdshell)
          DTS package (may be restricted)
          Linked Server (sp_addlinkedserver. requires one-time setup by dba)
          OpenDatasource/OpenRowset (ad-hoc querying. requires sufficient permissions)
          Given the current restrictions, I'm assuming DTS is out. Having the dba establish a linked server might be a viable option or possibly bcp.
          http://msdn2.microsoft.com/en-us/library/ms190479(SQL.90).aspx
