7 Replies Latest reply on May 7, 2011 2:17 AM by dtcullen
    Aligning the label in mobileiconitemrenderer
    dtcullen
      I have a customized item rendered for a list in an application to run on android and am having difficulty getting the 'label' to align in the center.
      The code is;
      override public function set data(value:Object):void {
      if(value != null) {
          super.data = value;
          setStyle("fontSize",18);
      if (value.assigned) {
          label = "[ASSIGNED TO YOU]";
          setStyle("textAlign", "center");
      else {
          setStyle("color",0xFFFF00);
          label = "[PRESS TO ACQUIRE]";
      height = 150;
      iconWidth = 75;
      iconHeight = 75;
      iconFunction = getIcon;
      messageFunction = getMessage;
      The colors and the fontsize seem to work fine but the label stays aligned left. I have also tried setting the alignment in the List which is the owner of the renderer.   Any ideas?
        • 1. Re: Aligning the label in mobileiconitemrenderer
          Lee Burrows Level 4
          hi
          have you set a width for your label? if not, label will size itself to the width of the text - so left/right/center align will all look the same - does it center itself if you set label width at 100%?
          • 2. Re: Aligning the label in mobileiconitemrenderer
            dtcullen Level 1
            Thanks for the reply Lee.
            I am presuming that the width is the ultimate source of my problem but am confused as to where to set the width.  In the itemrenderer 'label' is just a string.  I have set the width in the list and also in the item renderer (width = 500) but to no effect.  I can set the height okay and that works.
            Am I missing something?
            Regards
            Des.
            hi
            • 3. Re: Aligning the label in mobileiconitemrenderer
              Lee Burrows Level 4
              hi
              im not too knowledgable on the mobile stuff but this tutorial looks like it should help you out: http://www.asfusion.com/blog/entry/mobile-itemrenderer-in-actionscript-part-1 (by creating a custom renderer)
              • 4. Re: Aligning the label in mobileiconitemrenderer
                Shongrunden Adobe Employee
                It sounds like you are using a very early preview release.  MobileIconItemRenderer has been renamed to IconItemRenderer and this seems to work for me the final release of Flex 4.5:
                <s:List width="100%">
                    <s:dataProvider>
                        <s:ArrayList>
                            <fx:String>one</fx:String>
                            <fx:String>two</fx:String>
                            <fx:String>three</fx:String>
                        </s:ArrayList>
                    </s:dataProvider>
                    <s:itemRenderer>
                        <fx:Component>
                            <s:IconItemRenderer>
                                <fx:Script>
                                    <![CDATA[
                                            super.data = value;
                                            if (!data)
                                                return;
                                            if (data == 'two'){
                                                setStyle('textAlign', 'center');
                                </fx:Script>
                            </s:IconItemRenderer>
                        </fx:Component>
                    </s:itemRenderer>
                </s:List>
                • 5. Re: Aligning the label in mobileiconitemrenderer
                  dtcullen Level 1
                  Thank you.  It would be great if Adobe told me that 4.5 had been released.  I will upgrade and give it a go.
                  >>     <s:dataProvider>
                  >>         <s:ArrayList>
                  >>         </s:ArrayList>
                  >>     </s:dataProvider>
                  >>     <s:itemRenderer>
                  >>         <fx:Component>
                  >> <fx:Script>
                  >>                     <![CDATA[
                  >> super.data = value;
                  >> if (!data)
                  >> return;
                  >> if (data == 'two'){
                  >> </fx:Script>
                  >>         </fx:Component>
                  >>     </s:itemRenderer>
                  >> </s:List>
                  • 6. Re: Aligning the label in mobileiconitemrenderer
                    It was just released on May 3rd.  Keep an eye on the Official Flex Team blog for more updates:
                    http://blogs.adobe.com/flex/
                    • 7. Re: Aligning the label in mobileiconitemrenderer
                      dtcullen Level 1
                      Thanks all.  The upgrade worked.
