1 Reply Latest reply on May 6, 2011 7:57 AM by juresti
    PAth not working
    juresti Level 1
      The code below is loaded into a clip movieHolder and I can not get it to work. It works on its own but not when loaded.
      holder_mc0.onRelease = function(){
          holder_mc0.stopDrag();
              if (this._droptarget == "/string02") {
              this..onTarget=true;
              string02.gotoAndStop(2);
             this._visible = false;
              menu_txt0._visible = false;
              zoom0._visible = false;
              main_txt1.setNewTextFormat(mainText);
              main_txt1.text = $parsedObject.tool[0].name
              trace(main_txt1);
      }else
              _parent.onTarget=false;
      One movie loads another in movieHolder, then that swf loads the movie I'm trying to get to work by going back to the main movie using this code:
      function preloadContainer(){
          // get bytes loaded and total from container_mc
          var bytes_loaded = movieHolder.getBytesLoaded();
          var bytes_total = movieHolder.getBytesTotal();
          // stop and hide the movie so it wont play or
          // be seen while progressively downloading
          // (keep trying if it exists or not just to be sure)
          movieHolder.stop();
          movieHolder._visible = false;
          // if bytes_total is a valid number and greater than 0
          if (bytes_total > 0){
              // get percent loaded
              var percent_loaded = bytes_loaded/bytes_total;
              // update the value in the preloader
              preloader_mc.value = percent_loaded;
              // check if preloading is complete
              if (percent_loaded == 1){
                  // play and show the container clip
                  movieHolder.gotoAndStop(1);
                  movieHolder._visible = true;
                  // remove the preloader movie clip
                  preloader_mc.removeMovieClip();
                  // delete the onEnterFrame event handler running this function
                  delete onEnterFrame;
        • 1. Re: PAth not working
          juresti Level 1
             I got it!!
                  if ((eval(this._droptarget) == string02)) {
                  this.onTarget=true;
                  trace("WT");
          }else
                  this.onTarget=false;
