5 Replies Latest reply on May 6, 2011 10:39 AM by Hadzel
    Open mxml from a string
    Hadzel Level 1
      I have my menu in a xml:
      <MenuItem className="ProposalDetails" title="Select Proposal" openType="list" toolTip="Select Proposals and Proposal Versions" roles="60" url="selectProposalIcon" />
      I want to open the className of my MenuItem when I click it:
      I can acess the className with= data.className.... but like a string.
      How I can transform that in a compont?
      I tried:
      protected function itemRenderer_clickHandler(event:MouseEvent):void
      if( parentApplication.hasOwnProperty("pMainPanel"))
           ModelLocator.Instance.backView = parentApplication.pMainPanel;
           parentApplication.pMainPanel.removeAllElements();
             var dispObjName:String = data.className;
      var ClassReference:Class = getDefinitionByName(dispObjName) as Class;
      var classFactory:ClassFactory = new ClassFactory(ClassReference);
      var component:* = classFactory.newInstance();
      parentApplication.pMainPanel.addElement(component);
      But does't work.
        • 1. Re: Open mxml from a string
          Lee Burrows Level 4
          hi
          you haven't said how it doesn't work - are you getting error messages?
          i would create the component this way:
          var component:IVisualElement = new ClassReference() as IVisualElement;
          • 2. Re: Open mxml from a string
            Hadzel Level 1
            Yeah, if I do this :
            var ClassReference:Class = getDefinitionByName("mx.controls.Button") as Class;
            It works.
            But I set the parameter of getDefinitionByName as "modules.Project.ProposalApproval", witch is a titleWindow, and it returns this error = "Variable ProposalApproval is not defined."
            • 3. Re: Open mxml from a string
              Lee Burrows Level 4
              you may need to help out the compiler by adding references to the classes you are instantiating. such as:
              var comp1:ProposalApproval;
              var comp2:OtherMenuComp;
              (you can put these anywhere in your app)
              if there are no references to a class, it wont get included when compiling - hence runtime "not defined" error
              • 4. Re: Open mxml from a string
                Hadzel Level 1
                My ideia was to get xml's propertie with the name of the conatiner that I created and add it in my panel:
                parentApplication.pMainPanel.addElement(data.className);
                But flex doesn't find the references of my screen( ProposalAproval ) and reads 'data.className' as string and not a contatiner( TileWindow ). I didn't want to do a lot of 'if's' or 'switch-cases' to get the right container, because there are to many itens on my xml. hahahaha
                • 5. Re: Open mxml from a string
                  Lee Burrows Level 4
                  addElement takes an instance of a class - not a class itself - and the only way to generate an instance of a class from a string is to use the getDefinitionByName technique
