0 Replies Latest reply on May 6, 2011 10:51 AM by Rahul7777
    setting localization from command for flex 3.5.0
    Rahul7777
             I am tring to set up the localization for my project, i am using macbook pro, terminal when i enter the command
      copylocale en_US es_ES
      i am getting the error saying can't copy .property files, i didn't understand what the error is.
      Here is what it showed up when i run the command
      Anyone has the same problem, I am running in Adobe flash builder 4(comes with default localization)  i am working on 3.5.0 project.
      ODDEVMAC7W1:3.5.0 GChigurupati$ bin/copylocale en_US es_ES
      In Flex SDK at bin/.. ...
      Copying files from frameworks/projects/airframework/bundles/en_US/src
                      to frameworks/projects/airframework/bundles/es_ES/src:
      aircontrols.properties
      Error: Can't copy .properties files
      Compiling resource bundle SWC frameworks/locale/es_ES/airframework_rb.swc:
      Loading configuration file /Applications/Adobe Flash Builder 4/sdks/3.5.0/frameworks/flex-config.xml
      Adobe Compc (Flex Component Compiler)
      Version 3.5.0 build 12683
      Copyright (c) 2004-2007 Adobe Systems, Inc. All rights reserved.
      /Applications/Adobe Flash Builder 4/sdks/3.5.0/frameworks/flex-config.xml(75): Error: unable to open 'locale/es_ES'
            </library-path>
      Copying files from frameworks/projects/automation/bundles/en_US/src
                      to frameworks/projects/automation/bundles/es_ES/src:
      automation.properties
      Compiling resource bundle SWC frameworks/locale/es_ES/automation_rb.swc:
            </library-path>
      Copying files from frameworks/projects/datavisualisation/bundles/en_US/src
                      to frameworks/projects/datavisualisation/bundles/es_ES/src:
      charts.properties
      Compiling resource bundle SWC frameworks/locale/es_ES/datavisualisation_rb.swc:
            </library-path>
      Copying files from frameworks/projects/framework/bundles/en_US/src
                      to frameworks/projects/framework/bundles/es_ES/src:
      collections.properties
      Compiling resource bundle SWC frameworks/locale/es_ES/framework_rb.swc:
