14 Replies Latest reply on Jun 3, 2011 10:16 AM by Flex harUI
    what component to display a matrix
    eprevot123 Level 2
      I want to create a grid with horizontal and vertical header, like Excel tables.
      All the cells of this grid are independant :
      seems to me that in a datagrid, the cells of a same row represent differents fields of a unique dataProvider element.
      but here I want that each cell represent an independant element.
      For example I would like to have a model that is a matrix, maybe an ArrayCollection of ArrayCollections, and each element of this matrix is displayed in the corresponding cell.
      What component would you use ?
        • 1. Re: what component to display a matrix
          Flex harUI Adobe Employee
          It depends on what else you want to do with it, like selection,
          manipulation, animation.
          You could just use constraintColumns/constraintRows, or TileLayout, or even
          the old MX Grid/GridColumn/GridRow
          • 2. Re: what component to display a matrix
            eprevot123 Level 2
            I would like to be able to scroll vertically and horizontally, and still see the headers (like the datagrid does).
            I tried to create a mxml component with DataGroup with TileLayout, surrounded by HGroup and VGroup for the headers but if I set scrollers on the datagroup then the headers don't follow, and if I set scrollers around the hole component then headers disapear when I scroll.
            Plus the component takes 7sec to display the 240 cells, I still have to determine which of the model creation or the component displaying takes so long.
            Can we have vertical and horizontal headers with MX Grid ?
            Since I don't know what will be the number of row/columns, I would have to create the Grid/GridColumn/GridRow in an as file ?
            • 3. Re: what component to display a matrix
              eprevot123 Level 2
              I created a AS component with mx grid/gridRow/gridITem, and other grids for the horizontal and vertical headers, and synchronize the headers's scrollbar with the main grid scrollbars.
              It works but it takes a loooong time to display. (about 6 seconds to display 4 columns, 17 rows, a renderer in each cell).
              I click on a button to change the state of my application and display the grid.
              My AS method to create the Grids/GridRows/GridItems takes 3 seconds to finish, then I receive a "addedToStage" event, and then I wait again 3secs to see the grid.
              -> I don't understand the 3 secs between the addedToStage event and the display I see on screen.
              -> If I can't reduce the time, at least I would like that the application changes as soon as I change the state, and see each cell displayed as it is created. How to do that ?
              Edit : I tested with 20 rows, 20 columns => 1sec to calculate the Grid, 25secs to display the grid !!
              • 4. Re: what component to display a matrix
                Comment out the renderers and see how fast it is.  It might be something
                about the renderers.
                • 5. Re: what component to display a matrix
                  eprevot123 Level 2
                  Well of course with nothing in the renderer it's almost instantaneous.
                  But I need these renderers to display the information, otherwise the grid is useless...
                  Maybe flex draws every renderers instead of drawing only the visible ones.
                  I tried with DataGroup and TileLayout but has the same problem (too long to display).
                  You seem to think there is a problem with the renderer, do you have something in mind ? any clue ?
                  Edit : each renderer contains a Rect (to display the frame to have a grid), 2 labels, 1 textArea, 3 buttons with icon (icon is embeded once in another class)
                  • 6. Re: what component to display a matrix
                    Post the renderer code.
                    • 7. Re: what component to display a matrix
                      eprevot123 Level 2
                      Here is the mxml part of my renderer (Labels are bound on var sound:XMLList that has only one XML element) :
                      <s:Group>
                           <s:states>
                              <s:State id="noSound" name="noSound"/>
                              <s:State id="soundRecording" name="soundRecording"/>
                              <s:State id="soundRecorded" name="soundRecorded"/>
                          </s:states>
                          <s:Rect width="100%" height="100%" >
                              <s:fill>
                                  <s:SolidColor id="background" color="0xFFFFFF"/>
                              </s:fill>
                              <s:stroke>
                                  <s:SolidColorStroke color="0x000000" weight="1"/>
                              </s:stroke>
                          </s:Rect>
                          <s:Label x="5" y="5"
                                   text="{sound.@id}"
                                   includeInLayout="{isExpanded}" visible="{isExpanded}"/>
                          <s:Label x="40" y="5"
                                   includeIn="soundRecorded"
                                   text="{sound.@pathName}" toolTip="{sound.@pathName}"
                                   width="100%" maxDisplayedLines="1"/>
                          <s:TextArea id="descriTA" x="5" y="22"
                                      width="150" height="60"
                                      change="{descriChange(descriTA.text)}" text="{sound.@descri}"/>
                          <s:Image id="playImage" source="{SoundGrid.playIcon}"
                                   mouseDown="{playImage.source = SoundGrid.playIconDown}"
                                   mouseUp="{playImage.source = SoundGrid.playIcon}" mouseOut="{playImage.source = SoundGrid.playIcon}"
                                   x="5" y="84"
                                   toolTip="play"
                                   click="playClicked()" />
                          <s:Image id="recordImage" source="{SoundGrid.recordIcon}"
                                   mouseDown="{recordImage.source = SoundGrid.recordIconDown}"
                                   mouseUp="{recordImage.source = SoundGrid.recordIcon}" mouseOut="{recordImage.source = SoundGrid.recordIcon}"
                                   includeIn="noSound"
                                   x="5" y="84"
                                   toolTip="record"
                                   click="recordClicked()"/>
                          <s:Image id="stopImage" source="{SoundGrid.stopIcon}"
                                   mouseDown="{stopImage.source = SoundGrid.stopIconDown}"
                                   mouseUp="{stopImage.source = SoundGrid.stopIcon}" mouseOut="{stopImage.source = SoundGrid.stopIcon}"
                                   includeIn="soundRecording"
                                   x="5" y="84"
                                   toolTip="stop"
                                   click="stopClicked()"/>
                          <s:Image id="importImage" source="{SoundGrid.importIcon}"
                                   mouseDown="{importImage.source = SoundGrid.importIconDown}"
                                   mouseUp="{importImage.source = SoundGrid.importIcon}" mouseOut="{importImage.source = SoundGrid.importIcon}"
                                   includeIn="noSound"
                                   x="50" y="84"
                                   toolTip="import"
                                   click="importClicked()"/>
                      </s:Group>
                      • 8. Re: what component to display a matrix
                        You might want to use the profiler to see if it shows anything as being
                        slow.  There is lots of bindings which can be slow, and lots of mx:Images
                        which could be slow if the images are big or external.
                        • 9. Re: what component to display a matrix
                          eprevot123 Level 2
                          In the renderer, it is the textArea and the Images that take the most time. But I still don't know how to speed up the display.
                          I can remove binding and update the cells myself but I want to have Images in each cell.
                          Are you saying that this display time is normal ? as long as I use binding and Image (and textArea) I won't be able to display faster the renderers ?
                          (what is external image ? mine is in the src/assets folder)
                          • 10. Re: what component to display a matrix
                            Images are either embedded or loaded at runtime.  Loading at runtime takes
                            more time.  Another factor is the original size of the image vs the
                            displayed size.  If I take a full photograph that is 10's of MB in size and
                            display it down in a small area, that will also take time.
                            • 11. Re: what component to display a matrix
                              eprevot123 Level 2
                              I embed the images, and they are 4K (16x16 pixels icon).
                              • 12. Re: what component to display a matrix
                                I don't think a 16x16 icon should be 4K in size.  If you are asking the
                                player to scale it down, that may take extra time.
                                • 13. Re: what component to display a matrix
                                  eprevot123 Level 2
                                  I don't set any height/width to the Image, no code to scale the image, it displays it as it is.
                                  Anyway I tried to replace the Images by Buttons without icon, and the time to display the grid is the same. So I don't think I can gain time on this part.
                                  But I tried to replace the TextArea by a Label and it's better.
                                  I added a listener to trace "added" events on the renderer and I see many traces for the scrollers of the TextArea.
                                  I tried to remove the scrollers from the TextArea : scroller="{null}" horizontalScrollPolicy="off" verticalScrollPolicy="off"
                                  But I still trace all the scrollers "added" events.
                                  Is there a way to not calculate scrollers when displaying a spark TextArea ?
                                  And does it seem likely to you that TextArea scrollers are the main source of my problem ?
                                  • 14. Re: what component to display a matrix
                                    Probably.  If you don't ever want them, use some component like
                                    RichEditableText that doesn't have scrollbars built in.
