2 Replies Latest reply: May 8, 2011 6:36 AM by Rodieck RSS
    Installing new fonts
    Rodieck Community Member
      I have some new fonts which I’ll be using only very, very rarely.  I think, if my aged memory is working, that I’ve read that you want to minimize the number of fonts that are automatically loaded when you start Illustrator. But I’m a bit hazy on this, and I can’t find anything when I search this forum. Should I be loading these seldom-used fonts somewhere other than in the Windows Fonts folder, and, if so, where?
      I'm running CS5 on a Windows 7 machine.
        • 1. Re: Installing new fonts
          Scott Falkner Community Member
          No fonts are automatically loaded when you start Illustrator, so that number is already minimized at zero. Fonts are installed at the OS level using Font Book on a Mac or the Fonts control panel in Windows or a font management utility. Illustrator will probably launch quicker with fewer fonts active and it will be easier to select a font with a smaller Fonts menu, but that’s about it as far as Illustrator specifically goes. Your system will probably run a bit more responsively with fewer active fonts.
          • 2. Re: Installing new fonts
            Thanks, Scott -- I appreciate that info.
