2 Replies Latest reply on May 8, 2011 8:29 PM by alexanderRV
    SQLConnection database engines
    alexanderRV
      Greetings.
      I am coming from backend environment in PHP into desktop in AIR and trying to grasp the new concepts.
      In PHP when I am accessing a database I would usually write a database-augnostic connection class so others, like DataMapper or ActiveRecord pattern classes can seamlessly connect to it regardless of DB implementation.  This DB-augnostic connection has a propery which points to a DB specific class (mysql, mssql, postgre, etc.) so then DB backeds can be swapted without affecting the application.
      When I am working in Air, however, I only see an Sqlite implementation by SQLConnection class. I do not see a way to change this type if, for whatever reason, I want a different embedded database engine (and the app will never interface to the internet).  If Air does not support other embedded DB vendors, I do not have much problem with it, but then there is no point wasting time writing DB-augnostic adapters; I can go straight into data management.
      So my question is, should I bother separating DB engine layer through adapters in Air or there is only one choice in the first place and I can code to Sqlite directly.
      Thank you.
        • 1. Re: SQLConnection database engines
          Joe ... Ward Level 4
          There is only one choice right now. We do have a feature under development that would allow extensions written in native code to be added to an application. That feature could be used to provide a different database implementation.
          • 2. Re: SQLConnection database engines
            alexanderRV Level 1
            Thank you, good to know.
            Will the new implementation be abstract like, say Zend Framework, where I write to Zend_Db_Table class in a generic syntax and ZF does convertion to native code of whatever engine I picked in main configuration? Or should I create DB  abstraction layers manually between Value Objects and database engine in  preparation for that new feature?
            Is it too early for you to answer these question?
