4 Replies Latest reply on May 28, 2011 11:55 AM by Shongrunden
    how can I avoid hard coding this width?
    vertex_shader Level 1
      I have something like this:
      <s:SkinnableDataContainer
                                    width="200"
                                    itemRenderer="MyItemRenderer"
                                    dataProvider="{ dp }">
      If I have 4 items each 50px wide, I would set the width to 200px.
      However, I want to avoid hardcoding the width.
      How can I extract the width from the item renderer?
        • 1. Re: how can I avoid hard coding this width?
          MikisMM Level 2
          What exactly are you trying to achieve? Maybe constraints (left, right, top, bottom) will do the work.
          • 2. Re: how can I avoid hard coding this width?
            milan_va
            As a quick hack, you may try
                                          width="{50*dp.length}"
            but I guess that sooner or later you'll have to use ActionScript anyway as the computation gets more complicated (min+max, invisible items etc.).
              Milan
            • 3. Re: how can I avoid hard coding this width?
              Sorry, I should clarify a couple of things.
              1. The dp may have 50 items
              2. The SkinnableDataContainer has a Scroller for which I've disabled the thumb/track.
              3. I set the SkinnableDataContainerto display 4 of the 50 items and the user uses buttons to scroll to the next 4 items (I do the scrolling programatically with a little elastic animation)
              So, I'm basically setting the container to the width of the item renderer * some number of items that represent a page. For now, I think I'll do something like this:
              private var pageSize:int = 4;
                              width="{ MyItemRenderer.WIDTH * pageSize }"
              • 4. Re: how can I avoid hard coding this width?
                Shongrunden Adobe Employee
                You might want to try not setting a width and setting requestedColumnCount on the layout instead.
                <s:List>
                    <s:layout>
                        <s:HorizontalLayout requestedColumnCount="2" />
                    </s:layout>
                    <s:dataProvider>
                        <s:ArrayList>
                            <fx:String>0000</fx:String>
                            <fx:String>1000</fx:String>
                            <fx:String>2000</fx:String>
                            <fx:String>3000</fx:String>
                        </s:ArrayList>
                    </s:dataProvider>
                </s:List>
