0 Replies Latest reply on May 9, 2011 2:09 AM by TheGarfunkal
    Webservice IO error help!
    TheGarfunkal
      Hi
      I have a company internal Flex application that uses a asp webservice (again internal)  to get user Id and Name.  Its been live for a few months now, but today its gone haywire - it was even working earlier today!
      My app calls this webservice which has two webmethods - oddly one is fine and returns the info ok - the other is failing.  If i access the webservice via the browser thru localhost then they both work - so this seems to be an interpretation in Flex maybe?
      The trace shows the error as :
      faultCode:Server.Error.Request faultString:'HTTP request error' faultDetail:'Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://horoap509/CMIRSS/Flex.asmx"]. URL: http://horoap509/CMIRSS/Flex.asmx'
      The webmethods are: (top one is the working one)
          <WebMethod()> _
          Public Function GetName() As String
              Return My.User.Name.ToString
          End Function
          <WebMethod()> _
         Public Function GetFullName() As String
              Dim defaultNamingContext As String
              Using rootDSE As New DirectoryEntry("LDAP://RootDSE")
                  defaultNamingContext = rootDSE.Properties("defaultNamingContext").Value.ToString()
              End Using
              Dim strUserName As String
              Dim strRealName As String
              Dim strADPath As String
              strUserName = (My.User.Name.ToString)
              strUserName = strUserName.Replace("OPD\", "")
              'strUserName = "a08107"
              strADPath = "LDAP://" + defaultNamingContext
              Dim Entry As DirectoryEntry = New DirectoryEntry(strADPath)
              Dim Searcher As DirectorySearcher = New DirectorySearcher(Entry)
              Dim result As System.DirectoryServices.SearchResult
              Searcher.Filter = ("(sAMAccountName=" & strUserName & ")")
              result = Searcher.FindOne()
              strRealName = (result.GetDirectoryEntry().Name)
              strRealName = strRealName.Replace("CN=", "").Replace("\", "")
              strRealName = StrConv(strRealName, VbStrConv.ProperCase)
              Return strRealName
          End Function
      any ideas?  Its pretty weird that it worked earlier!
      cheers
      Andrew
