So when you create a new Style in the Styles Pallete it saves the layer opacity... but ONLY if the opacity is below 100%?
I created and saved 3 identical styles... sans the different layer opacity... and when I toggle between the 33% and 66% styles it jumps back and forth...
however, if I select the 100% opacity it ignores the opacity and stays at whatever it was set to with the last style I selected.
Bug?
Just my install?
Has it always been this way?
I think this is as it should be, as layer opacity can be adjusted independently of the rest. It probably only stores it if it is lower than 100% under the assumption that this influences the appearance of the style itself...
Mylenium
