0 Replies Latest reply on May 9, 2011 12:46 PM by Kristin95762
    Passing variable values between windows (AIR, sqlite)
    Kristin95762 Level 1
      Hi
      I have a main app, a custom component, and a class file.
      In the main app I have this code:
      private function authorGrid_doubleClickHandler(event:MouseEvent):void
      popup = new BookDetailsWindow();
      popup.addEventListener(Event.CLOSE, closeBookDetailsHandler);
      popup.addEventListener("readBooksDetail", readBookDetailsHandler);
      popup.addEventListener("cancel", closeBookDetailsHandler);
      PopUpManager.addPopUp(popup, this, true);
      popup.title = (authorGrid.selectedItem as Object).title;
      popup.bookTitleTxt.text = authorGrid.selectedItem.title;
      bdSelectedBook = authorGrid.selectedItem.title;
      trace(bdSelectedBook);
      PopUpManager.centerPopUp(popup);
      Currently, I am passing a value to the popup via the popup.bookTitleTxt.text = authorGrid.selectedItem.title;
      I use the bookTitleTxt.text value in a parameter for a query in the actionscript file for the popup custom component.
      This works the way it should but what I would rather do is use something like
      bdSelectedBook = authorGrid.selectedItem.title; so I can pass this value to a SELECT statement in the custom component.
      How do I set up variable sharing? I have the same variable defined in all three files, declared as public, but it returns null.
      Thanks alot for your help.
      Kristin
