6 Replies Latest reply on May 17, 2011 2:00 AM by nikos101
    labelDisplay is null in CustomComponent
    nikos101 Level 2
      I've created a custom component where I've borrowed the code from button that sets content for a label
      public class ToggledBackground extends SkinnableComponent
      etc
          public function set content(value:Object):void
              _content = value;
              // Push to the optional labelDisplay skin part
              if (labelDisplay)
                  labelDisplay.text = label;
              dispatchEvent(new Event("contentChange"));
      [Bindable("contentChange")]
          public function set label(value:String):void
              // label property is just a proxy to the content.
              // The content setter will dispatch the event.
              content = value;
      In my mxml file I declare it as such and this the label gets set. However when I debug the n set content method the labelDisplay is null.
      <customComponents:ToggledBackground  label="1.Values"   id="arroValies" >
              </customComponents:ToggledBackground>
        • 1. Re: labelDisplay is null in CustomComponent
          Flex harUI Adobe Employee
          See the doc on creating custom components.  Use the lifecycle methods.
          • 2. Re: labelDisplay is null in CustomComponent
            nikos101 Level 2
            thanks but I don't see the ButtonBase (im trying to copy the label stuff) do anything when the label is set to invalidateStuff,
            All it appears to do is:
            • 3. Re: labelDisplay is null in CustomComponent
              After it checks for the existing of labelDisplay.  But if you read the doc,
              and look for where _content is also applied, you'll see how the component
              lifecycle methods are used.  Follow that pattern and you should have
              success.
              • 4. Re: labelDisplay is null in CustomComponent
                nikos101 Level 2
                I set a breakpoint in ButtonBase here to see what happens in my normal buttons
                        _content = value;
                        if (labelDisplay)
                but I always get labelDisplay = null in the initialise phase
                but in my normal buttons the button text does get set with the values I hardcode in MXML
                However my label value never gets set
                    <customComponents:ToggledBackground label="5. Risk and control" id="arrowRiskC" >
                • 5. Re: labelDisplay is null in CustomComponent
                  See commitProperties
                  • 6. Re: labelDisplay is null in CustomComponent
                    nikos101 Level 2
                    sorted, I had to add this
                    override protected function partAdded(partName:String, instance:Object):void
                            super.partAdded(partName, instance);
                            if (instance == labelDisplay)
                                // Push down to the part only if the label was explicitly set
                                if (_content !== undefined)
                    What I dont understand is where the content setter is being called on app startup (I'm not calling it in my code) for Button or my custom component
