1 Reply Latest reply on May 10, 2011 6:07 AM by UbuntuPenguin
    Binding To a Propery - Inside an ArrayCollection Problem
    dataDash Level 1
      I'm trying to make an editor where users can select an editable item from a list (each item in the list might be a different type of editable object). When the user selects an item from the list its editable properties show up in a panel with a suitable item editor.
      The problem I'm having is I don't want all item properties to be editable and I need to be able to specify what type of editor should be used e.g. TextInput, ColorPicker or custom editor.
      I thought about creating an EditableItem objects which could have an ArrayCollection called editableItems which holds what can be edited and what type of editor to use in a EditConf object:
      package
          [Bindable]
          public class EditConf
              public var value:*;
              public var editor:String = "DefaultEditor";
              public function EditConf(value:*, editor:String)
                  this.value = value;
                  this.editor = editor;
      Inside the EditableItem would look something like this with an ArrayCollection holding the EditConf objects.
      package
          import mx.collections.ArrayCollection;
          [Bindable]
          public class EditableItem
              public var label:String;
              public var colour:uint;
              public var nonEditableVar:String;
              public var nonEditableVar2:Boolean;
              public var editableItems:ArrayCollection;
              public function EditableItem()
                  editableItems.addItem(EditConf(label, "TextInput"));
                  editableItems.addItem(EditConf(colour, "ColorPicker"));
      The problem with this is when you assign the editor - say a TextInput to edit the value "label" from the editableItems ArrayCollection it updates the editableItem ArrayCollection but not the variable "label". I thought the ArrayCollection would just hold a pointer to "label" so it would update the variable but no such luck.
      Does anyone know of a better way to create the application above or why the binding does function as I expected?
      Many Thanks
        • 1. Re: Binding To a Propery - Inside an ArrayCollection Problem
          UbuntuPenguin Level 4
          It sounds more like an architecture problem.  If I had a problem like this, I would have a model class hold my selectedItem.  This "selectedItem" property would be injected into a presenter model through a setter function.  In the setter function, the presenter would look at the selectedItem and decide which properties on the view class ( viewstack or states ) should be editable.
          I have some misgivings about the value objects holding the type of editor they should use, that sounds like something that should be delegated to a UI/Presenter class.
