0 Replies Latest reply on May 10, 2011 7:08 AM by DBarranca
    Graphics support
    DBarranca Level 4
      Hello,
      I've approached the unhappy business of drawing things into CS extensions. Basic vector things, like shapes, lines, etc.
      What a pain.
      Waiting for the support of Flex 4 and its super-easy declarative approach with Spark components (please, do it, please: we will love you forever), I've decided to try out the Degrafa framework (see here and on GoogleCode here) which is declarative as well - in fact, it looks very like Spark in some ways. So nice.
      Alas, it shows some annoying bugs - I use to output to Flash Player to speed up the testing; things are getting even worse when you try to put it inside extensions - god knows why, since I use the very same EB sdk to compile.
      Anyway, you experienced Flex/extension coders around, what approach would you suggest? I can't use SVG, for I need the graphic objects to be scriptable; should I stick to Degrafa, are there any better options?
      Thanks in advance!
      Davide
