7 Replies Latest reply on Jun 2, 2011 2:29 PM by Nancy OShea
    Design View Not Working Properly
    jarodsafehouse71 Level 1
      Hi, I save my web site files as .php and I'm using DW CS5. When I switch to Design View all I get are a couple of icons. Why won't it display the page for me?
        • 1. Re: Design View Not Working Properly
          Ben M Adobe Community Professional
          Design View does not render PHP code.  You need to activate Live View for that.
          • 2. Re: Design View Not Working Properly
            bemdesign Level 4
            PHP is a server side scripting language - it requires a server to parse the script and render the output. Dreamweaver can not, by itself, parse PHP - it needs a testing server to do the PHP parsing and render the resulting output, for it.
            And Design view is...spotty...at best. It's really just a rough guestimate by Dreamwever on how static HTML (not PHP) would look like, possibly, in a browser. If you want accuracy, use Live View.
            And again, for PHP, set up a testing server.
            • 3. Re: Design View Not Working Properly
              But it's regular html, not php code. Is it because of the .php extension then?
              • 4. Re: Design View Not Working Properly
                Anything that is between <?php and ?> requires the server to process the code regardless of what code you put in between there.  You can use PHP code on a page that begins with the HTML doctype declaration vs a PHP statement if you want HTML to load.  For instance:
                <HTML>
                <body>
                [lots and lots of stuff here]
                <?php [some php stuff here] ?>
                [lots more stuff here]
                </html>
                In that example the "lots of stuff" will load and an icon will show for the "php stuff".  Given that is not valid code just a representation, but it should hopefully get the point across.
                • 5. Re: Design View Not Working Properly
                  bemdesign Level 4
                  The .php extension tells Dreamwever that it's supposed to be a PHP file and it needs to be processed by the server first before rendering, even if the php file doesn't contain a single bit of PHP code.
                  So if you want to write static HTML pages and have Dreamqweaver's Design view give you a rough approximation of what you're doing, use the HTML filetype (.html or .htm) and not PHP.
                  Now if you really are going to use PHP, set-up a testing server that can parse your PHP.
                  • 6. Re: Design View Not Working Properly
                    timmer101
                    I am having the same problem with design view.  Even when I open a new page.  I have removed all file extensions from the open in code view in preferences but still design view does not work.  Can you help me?
                    • 7. Re: Design View Not Working Properly
                      Save file as 'test.html'
                      If you still cannot see anything in design view, use the validation tools below and fix reported errors.
                      Code Validation Tools
                      CSS - http://jigsaw.w3.org/css-validator/
                      HTML - http://validator.w3.org/
                      If you're still not seeing anything in Design View, post your code into the web forum with  >> Syntax highlighting > Plain.
                      Code in the web forum looks like this.
                      Nancy O.
                      Alt-Web Design & Publishing
                      Web | Graphics | Print | Media  Specialists
                      http://alt-web.com/
                      http://twitter.com/altweb
