6 Replies Latest reply on Nov 6, 2011 10:57 AM by michaelbarsotti
    Flash Builder Export Release Build Fails
    comradeburk
      I'm having an issue when trying to export the release build of my AIR application in Flash Builder 4.5.  After choosing the key to sign the package and clicking finish to complete the export, it errors saying that "Error occurred while saving the project settings: "default" build target cannot be found for the selected project."  I've included the error message output to the log in the .metadata folder.  Any help would be great as this is baffling to me.
      !ENTRY com.adobe.flexbuilder.project 4 43 2011-05-10 15:56:11.432
      !MESSAGE Failed to get build target settings: default
      !STACK 0
      java.lang.Exception
          at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore. java:1009)
          at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
          at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:52)
          at com.adobe.flexbuilder.project.ui.utils.ProjectBuildPackagingUI.doApplySettings(ProjectBui ldPackagingUI.java:754)
          at com.adobe.flexbuilder.project.ui.utils.ProjectBuildPackagingUI.applySettings(ProjectBuild PackagingUI.java:781)
          at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionBuildPackagingPa geContent.saveSettings(ExportReleaseVersionBuildPackagingPageContent.java:131)
          at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionBuildPackagingPa ge.saveSettings(ExportReleaseVersionBuildPackagingPage.java:84)
          at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.performFi nish(ExportReleaseVersionWizard.java:144)
          at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
          at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
          at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
          at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
          at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
          at org.eclipse.jface.window.Window.open(Window.java:801)
          at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:97)
          at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
          at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
          at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
          at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
          at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
          at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:108)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
