16 Replies Latest reply on Aug 21, 2006 6:48 AM by Newsgroup_User
    maxlength behaviour
    Level 7
      <textarea name="textarea" cols="50" rows="5" maxlength="5"></textarea>
      How come the textarea tag does not allow the use of 'maxlength' fo rmulti
      line? If this
      restriction can be applied to text fields, why not to multi line text
      fields?
      We had to create a small javascript to detect when a user entered
      too much text into a comments field - not sure why we had to do this when
      this provision could very easily have been catered for in the same way as
      single line text fields.
      For them to make a conscious decision to disallow this there must have been
      some reason - very curious to know what this is? Surely it would not hurt to
      have this feature, but could potentially hurt not to,right?
      Thanks.
        • 1. Re: maxlength behaviour
          Level 7
          > line?
          You would have to ask the W3C this question.
          > If this
          > fields?
          A textarea is generally used for free-form input, and in that context,
          maxlength makes no sense.
          Your application is an unusual one. I guess you found the right solution.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Eric" <ericp@citadelip.net> wrote in message
          news:ec0np9$lqq$2@forums.macromedia.com...
          > line? If this
          > fields?
          > been
          > to
          > Thanks.
          • 2. Re: maxlength behaviour
            Level 7
            Maxlength makes every bit of sense in this context - does data in free form
            text areas not go into database columns? In such cases max length could be
            set to a very high postive number or simply set to 'unlimited'. The point is
            that the developer makes the decision - not the w3c. How could they possibly
            anticipate all use cases for text areas and stranger still, how could they
            not see this very basic matching of text area data to databases with defined
            datatypes?
            I wouldn't mind finding out if this was something they intend to fix or
            something they do not consider to be broken - might sniff around a bit at
            w3c.org for that one.
            Anyway, just venting some pent up "what the hell were they thinking" issues
            I am currently experiencing. Thanks for for your feedback.
            "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
            news:ec1mqd$qma$1@forums.macromedia.com...
            rmulti
            > > line?
            > > If this
            > > fields?
            rmulti
            > > line? If this
            > > fields?
            when
            as
            > > been
            hurt
            > > to
            > > Thanks.
            • 3. Re: maxlength behaviour
              Level 7
              I doubt that they consider it broken.
              "michael phillips" <m.phillips@centrelink.gov.au> wrote in message
              news:ec314d$hpj$1@forums.macromedia.com...
              > form
              > is
              > possibly
              > defined
              > datatypes?
              > issues
              > rmulti
              >> > line?
              >> > If this
              >> > fields?
              >> solution.
              > rmulti
              >> > line? If this
              >> > fields?
              > when
              > as
              >> > been
              > hurt
              >> > to
              >> > Thanks.
              • 4. Re: maxlength behaviour
                Level 7
                I am sure you are right. To be honest, I am also of the opinion that a
                simple maxLength attribute was inadequate as validation tool at the html
                level. Why not add a 'dataType' attribute to check for number, char, regEx
                adn so on. I know that JavaScript can do all this but such a basic and
                frequently occuring thing could easily have been added to specs and
                implement by browser vendors.
                news:ec350i$ltq$1@forums.macromedia.com...
                > > form
                be
                point
                > > is
                > > possibly
                they
                > > defined
                > > datatypes?
                at
                > > issues
                > > rmulti
                > >> > line?
                > >> > If this
                > >> > fields?
                > >> solution.
                > > rmulti
                > >> > line? If this
                > >> > fields?
                > > when
                way
                > > as
                have
                > >> > been
                > > hurt
                > >> > to
                > >> > Thanks.
                • 5. Re: maxlength behaviour
                  Level 7
                  > adn so on.
                  the validation should be done server side.
                  a form element having an html attribute isn't of any value, because there
                  will be browsers that don't support the attribute, not to mention all of the
                  user agents (including malicious bots) that will ignore that type of
                  attribute.
                  • 6. Re: maxlength behaviour
                    Level 7
                    sure, it almost always is done server side. Thats not what the poster was
                    saying.
                    the
                    > attribute.
                    With that logic, we should forget using javascript too?
                    The point is that the deevloper can make the choice.
                    Strange response. using you logic, again, the W3C would never have
                    introduced the <div> tag becuase there were no browsers that supported it.
                    It doesn't work that way.
                    I also think it would be perfectly reasonable to have some basic validation
                    options vailable at the html form level - they are closely enough related
                    and frequently enough needed. Why offer one validation tool (maxlength) but
                    then draw the line right there? Offer none or offer a selection I say.
                    "Alan" <dont_mail_me_period@macromedia.com> wrote in message
                    news:C10A9740.2A0C42%dont_mail_me_period@macromedia.com...
                    regEx
                    > > adn so on.
                    the
                    > attribute.
                    • 7. Re: maxlength behaviour
                      Level 7
                      On Fri, 18 Aug 2006 11:17:48 +0800, "RonOnTop" <ron123T@hotmail.com>
                      Complaining about it here will do no good. Perhaps here would be a good
                      place to start: http://www.w3.org/Consortium/join
                      Gary
                      • 8. Re: maxlength behaviour
                        Level 7
                        I for one will be joining - I want my other issue addressed. I think
                        hypertext is all one word, not two ('hyper' 'text') so therefore the
                        language should be HML/XHML. I find this rather disturbing anomaly greatly
                        reduces what can be acheived with the language.
                        "Gary White" <reply@newsgroup.please> wrote in message
                        news:8ijae2pqcrc579kg7h291fvjprbd9vudjd@4ax.com...
                        > Gary
                        • 9. Re: maxlength behaviour
                          Level 7
                          Third edit of what i want to say.
                          do you understand the things you are working with?
                          Why ask for a standard for client side validation when it simply won't work
                          because there will be user agents that will ignore it?
                          • 10. Re: maxlength behaviour
                            Level 7
                            Are you serious? Of course there will be user agents that will ignore it!
                            Just as there are user agent that will ignore javascript based validation,
                            or user agents that will ignore ANY newly introduced tag or attribute. Even
                            user agents tha will ignore well established tags and attributes. That is
                            the whole point, that there is no support for it and we think there should
                            be.
                            Do you? You seem to think that an tag or attribute that does not exist must
                            be a waste of time becuase there is currently no support for it. Luckily for
                            us all, the w3c think very diffrently than you and are very much of the
                            opinion that they can (and do) introduce new tags and attributes. And,
                            surprise surprise, vendors can add support in their next browser releases.
                            news:C10ADA75.2A0C73%dont_mail_me_period@macromedia.com...
                            work
                            • 11. Re: maxlength behaviour
                              Level 7
                              > be.
                              Yes- I am serious. Because the intent of your proposed tag attribute is that
                              it's used for client side validation. And if introduced, it would be used
                              for validation of form data. And relied on by some as the only validation of
                              the form data.
                              It won't work in all user agents, so it simply won't work. Even if it's
                              eventually adopted into 100% of web browsers- it could be easily bypassed at
                              will. It's wrong-headed to do form validation client side.
                              • 12. Re: maxlength behaviour
                                Level 7
                                rE: It's wrong-headed to do form validation client side.
                                Can I just say as politely as possible, that you do not really know what you
                                are talking aout. Not only is it not 'wrong-headed' it is also totally
                                advisable that you do validation client side, and then you do it server side
                                also. You do it client side to save the form from having to submit to the
                                server only to recieve back a validation message from server side code. The
                                client side validation will work, and speed up the process in most cases. In
                                the cases where it fails, the server side validation kicks in.
                                You may need to do some basic web surfing - when you do, you will see that
                                almost all websites that have forms use client side validation. They have
                                absolutely niothing to lose by doing so, and everything to gain.
                                Anyway, this is digressing from the original point, so will leave it right
                                there. If you are building forms and are not bothering to validate them on
                                the client, you are failing the end users of the websites you build. You
                                will be forcing them to travel back to the server to validate when the vast
                                majority of them have the ability to do this validtion without this extra
                                overhead. So I hope your understanding of this matter improves.
                                news:C10B5995.2A0CCD%dont_mail_me_period@macromedia.com...
                                work
                                it!
                                validation,
                                Even
                                is
                                should
                                > > be.
                                that
                                of
                                > the form data.
                                at
                                • 13. Re: maxlength behaviour
                                  Level 7
                                  I think this is fear mongering. The delay involved in passing the form to
                                  the server, and back to the client if there is an error is miniscule.
                                  > You
                                  > vast
                                  > overhead.
                                  The extra overhead is not really measurable. And the client / user doesn't
                                  care - they just want and expect the form to work.
                                  I rarely do client-side validation any more.
                                  "RonOnTop" <ron123T@hotmail.com> wrote in message
                                  news:ecau4l$hvb$1@forums.macromedia.com...
                                  > you
                                  > side
                                  > The
                                  > In
                                  > vast
                                  > work
                                  > it!
                                  > validation,
                                  > Even
                                  > is
                                  > should
                                  >> > be.
                                  > that
                                  > of
                                  >> the form data.
                                  > at
                                  • 14. Re: maxlength behaviour
                                    Level 7
                                    How can you possibly know - the page could be huge, use resources that are
                                    expensive to create or simply be very heavy while making poor use of
                                    caching. Aside from this very real possibility, the unneccasarry submit
                                    could cause loss of scroll position or other unwanted side effects. As but
                                    one example, have you any notion of how the reduction of traffic to a server
                                    can be reduced ten fold on busy servers, simply due to not having to deal
                                    with unneccasarry requests?
                                    I'm sorry, but to not use a perfectly good tool to cover these eventualities
                                    is pure laziness in my opinion. Particularly when the use of this tool has
                                    no downsides, the tool is widely available, ubiquitous even, and if it fails
                                    to run, its simply picked up at the server level. No harm done.
                                    Are you kidding? Suggesting the use of javascript for validation is fear
                                    mongering - that has to be the single most ridiculous idea I have been
                                    presented with by another web professional in quite a few years. I can only
                                    assume that you are more of a graphic designer type or that this is just an
                                    anomaly in the way you normally approach web development, as I find it hard
                                    to see how you get the ACE with this level of understanding.
                                    news:ecavhm$j91$1@forums.macromedia.com...
                                    right
                                    on
                                    > > You
                                    > > vast
                                    extra
                                    > > overhead.
                                    doesn't
                                    > > you
                                    > > side
                                    the
                                    > > The
                                    cases.
                                    > > In
                                    that
                                    have
                                    right
                                    on
                                    > > vast
                                    extra
                                    won't
                                    > > work
                                    > > it!
                                    > > validation,
                                    attribute.
                                    > > Even
                                    That
                                    > > is
                                    > > should
                                    > >> > be.
                                    > > that
                                    used
                                    validation
                                    > > of
                                    > >> the form data.
                                    bypassed
                                    > > at
                                    • 15. Re: maxlength behaviour
                                      Level 7
                                      I have to agree with RonOnTop here Murray - there are many reasons to make
                                      use of client side validation and practically no reasons not to. In case you
                                      didn't notice, almost all web sites make use of this - and why wouldn't
                                      they?
                                      I have noticed some of your other posts, and generally it seems you are a
                                      useful and helpful soul here in these forums - this one, however, is a bit
                                      of a blooper.
                                      For the benefit of the other poster - please consider that server side
                                      languages such as Asp.Net and ColdFusion, amongst others, actually create
                                      the client side validation code for you. And they do this for exactly the
                                      reason RonOnTop mentioned. Consider this for a moment - the creators of
                                      server side languages themselves agree that client side validation is
                                      neccasarry, useful and far preferable than doing it on the server. Kind of
                                      puts it in context doesn't it?
                                      Rule of thumb - if the client can do it, don't bother the server.
                                      right
                                      on
                                      > > You
                                      > > vast
                                      extra
                                      > > overhead.
                                      doesn't
                                      > > you
                                      > > side
                                      the
                                      > > The
                                      cases.
                                      > > In
                                      that
                                      have
                                      right
                                      on
                                      > > vast
                                      extra
                                      won't
                                      > > work
                                      > > it!
                                      > > validation,
                                      attribute.
                                      > > Even
                                      That
                                      > > is
                                      > > should
                                      > >> > be.
                                      > > that
                                      used
                                      validation
                                      > > of
                                      > >> the form data.
                                      bypassed
                                      > > at
                                      • 16. Re: maxlength behaviour
                                        Level 7
                                        Absolutely, especially if you have nothing to lose. I find it strange Murray
                                        saying he can't be bothered doing this given that DW can do all the hard
                                        work for you.
                                        "Monza" <monica@taskinteractive.net> wrote in message
                                        news:ecb4ug$oha$1@forums.macromedia.com...
                                        > you
                                        > they?
                                        > of a blooper.
                                        > right
                                        > on
                                        >> to
                                        >> > You
                                        >> > vast
                                        > extra
                                        >> > overhead.
                                        > doesn't
                                        >> > what
                                        >> > you
                                        >> > side
                                        > the
                                        >> > The
                                        > cases.
                                        >> > In
                                        > that
                                        > have
                                        > right
                                        > on
                                        >> > You
                                        >> > vast
                                        > extra
                                        > won't
                                        >> > work
                                        >> >> > ignore
                                        >> > it!
                                        >> > validation,
                                        > attribute.
                                        >> > Even
                                        > That
                                        >> > is
                                        >> > should
                                        >> >> > be.
                                        >> >> is
                                        >> > that
                                        > used
                                        > validation
                                        >> > of
                                        >> >> the form data.
                                        >> >> it's
                                        > bypassed
                                        >> > at
