1. Re: Flash Builder 4.0.1 with SDK 4.5?
cynicaljoy May 11, 2011 6:44 AM (in response to hidarikani)You should be able to without issue, find the 'Installed Flex SDKs' settings in the Preferences window and add the 4.5 SDK there. After adding your new SDK either check the box next to 4.5 to make it the default or to change it per project you need to go to the project settings and change the 'ActionScript Compiler' settings to 'Use a specific SDK' and select the new SDK.
2. Re: Flash Builder 4.0.1 with SDK 4.5?
2lazy May 17, 2011 7:00 AM (in response to cynicaljoy)Hi,
I also recently tried switching from SDK 4.1 to 4.5, the issue I have is when running the debugger it prompts an error saying "Required Adobe Flash Player version not installed" . Is there a way to set the path to the FlashPlayerDebugger.exe in FlashBuilder? Or are we forced to run the installer each time we want to debug against a specific version?
3. Re: Flash Builder 4.0.1 with SDK 4.5?
Webmaster1379 May 17, 2011 8:26 AM (in response to 2lazy)Okay guys i'm sorry but is there a free upgrade to Flash Builder. My Flash Builder says version 4.0.1 (build 277662) Is there a way to upgrade this without a cost to me?
I just purchased the Master Collection and shortly after they released 4.0.1.
4. Re: Flash Builder 4.0.1 with SDK 4.5?
Drew747 May 17, 2011 9:08 AM (in response to Webmaster1379)fb4.5 should come along with master collection 5.5 call sales.
5. Re: Flash Builder 4.0.1 with SDK 4.5?
yavstr May 17, 2011 2:10 PM (in response to hidarikani)I'm having issues using 4.5 in FB 4.0
Every time I create a new project and target 4.5 I get the following errors:
Description Resource Path Location Type 1084: Syntax error: expecting rightbrace before css testing Line 24 Flex Problem 1084: Syntax error: expecting rightbrace before end of program testing Line 447 Flex Problem 1084: Syntax error: expecting rightbrace before s testing Line 24 Flex Problem 1093: Syntax error. testing Line 24 Flex Problem 1093: Syntax error: A string literal must be terminated before the line break testing Line 24 Flex Problem
keep in mind the is a new project targeting the 4.5 SDK in Flash Builder 4.0. I have done nothing but create the project.
If I create the project with 4.1 SDK in Flash Builder 4.0, there are no issues.
Can someone confirm this is an issue with using 4.5 in FB 4.0 or share a solution to resolving the issues?
Thank you.
