1 Reply Latest reply on May 17, 2011 11:08 PM by Anirudh Sasikumar
    Change output target
    cynicaljoy
      How can I change the output SWF target for Run, Debug and Profile? I want to have different run configurations for each that output different SWFs?
        • 1. Re: Change output target
          Anirudh Sasikumar Adobe Employee
          Create different launch configurations by revelaing the run configurations menu from the debug button and hitting + for Web Application.
          In the newly created launch configuration, uncheck "Use default" and type in your own SWF path.
          Note that the compiler will still only generate one output SWF (that comes from the Build path property page). You'll have to manually copy the right swfs to the path you point in the launch config.
          -Anirudh
