1 Reply Latest reply on Oct 4, 2011 3:55 AM by nuruddinalam
    Install of Adobe Flash Builder 4.5 fails
    rsrogness
      Installation of Adobe Flash Builder 4.5 fails with 3 warnings and 4 errors.
      Attatched are the errors presented in the log.
      Some Google searches suggested uninstalling both the Flash plugin and ActiveX controls and/or rebooting to troubleshoot the installtion. Neither solution worked for me.
      I have also uninstalled the previous version of Flash Builder (FB4) even though there was supposedly no conflict betweent the two.
      Adobe support suggested creating a "webcase;" anyone know where I can do that?
      Thanks in advance.
        • 1. Re: Install of Adobe Flash Builder 4.5 fails
          nuruddinalam
          I am trying to install on windows7, nad facing the similar problem:
          Exit Code: 6
          -------------------------------------- Summary --------------------------------------
          - 0 fatal error(s), 13 error(s), 9 warning(s)
          ----------- Payload: {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0 -----------
          ERROR: Error 1935.An error occurred during the installation of assembly component {937FF758-7DED-3922-B192-1CA34A6D9AC2}. HRESULT: 0x80073712.
          ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
          MSI Error message: Error 1935.An error occurred during the installation of assembly component {937FF758-7DED-3922-B192-1CA34A6D9AC2}. HRESULT: 0x80073712.
          WARNING: DW036: Payload cannot be installed due to dependent operation failure
          ----------- Payload: {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0 -----------
          ERROR: DW050: The following payload errors were found during install:
          ERROR: DW050:  - Adobe Flash Player 10 Plugin: Install failed
          ERROR: DW050:  - Adobe Flash Player 10 ActiveX: Install failed
          ERROR: DW050:  - Microsoft_VC90_MFC_x86: Install failed
          ERROR: DW050:  - Adobe Flash Builder 4.5: Install failed
          ERROR: DW050:  - AdobeTypeSupport CS5: Install failed
          ERROR: DW050:  - AdobeHelp: Install failed
          ERROR: DW050:  - Microsoft_VC90_MFCLOC_x86: Install failed
          ERROR: DW050:  - AdobeCMaps CS5: Install failed
          ERROR: DW050:  - Adobe Player for Embedding 3.2: Install failed
          ERROR: DW050:  - Suite Shared Configuration CS5.5: Install failed
