0 Replies Latest reply on Jun 7, 2007 9:42 PM by TimmyTears
    Chart Min And Max
    TimmyTears Level 1
      I have a line chart using a Linear Axis in the horizontal direction. I have a live data stream coming into the graph. I have options to set the graph to different ranges and what I want to to is make the size of the graph explicitly that range. I am settings the minimum and maximum values and the minimum values works fine as it is based of zero, but I am having a problem with the maximum. When i set the maximum it is not making the graph explicitly to that maximum, instead it is making it to the highest value I currently have in my dataset. I want to change this so I can set the maximum and know that the maximum on the graph will be the maximum I set.
      Any help would be greatly appreciated
      Thanks in advance
