0 Replies Latest reply: May 11, 2011 11:33 PM by senthil s RSS
    Flex List with data-grid issue any body can help me ......i added the full code below
    senthil s Community Member
      Exactly wat i want to do is
      1.if i click the open button want to visible all datagrid ,its working perfectly.
      2.if i click the close button want to close all data grid ,its working perfectly.
      3. if i click a particular  list means want to visible particular datagrid..some times working good but some times not visible ...
      4.if i click the list if datagrid already open means want to close .some times creates extra space below the datagrid........
      if u cont get clearly please copy the below code and check it.......and give the right solution for this problem.......
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx" width="100%" height="100%" >
      <fx:Declarations>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      [Bindable]
      public var ArrUserList:ArrayCollection;
      [Bindable]
      public var listDB:ArrayCollection = new ArrayCollection([ {label: "2011", data:"jan",day:"saturday",date:"1-4-11"},
      {label: "2011", data:"jan",day:"monday",date:"13-4-11"}, {label: "2013", data:"jan",day:"monday",date:"1-5-11"}, {label: "2013", data:"jan",day:"wednesday",date:"14-5-11"}, {label: "2015", data:"jan",day:"tuesday",date:"11-5-11"}, {label: "2015" ,data:"jan",day:"friday",date:"1-6-11"} ]);
      public var loc_first_last_name:String;
      function Load():void
      ArrUserList=Find_Duplicate(listDB);
      for(var i:int=0; i<ArrUserList.length; i++)
      ArrUserList[i].click=0;
      Lst_userlist.dataProvider=ArrUserList;
      Lst_userlist.rowCount=ArrUserList.length;
      function Clink_lnk_open():void
      if(lnk_open.label=="Open")
      ArrUserList[i].click=1;
      lnk_open.label="Close";
      ArrUserList.refresh();
      Lst_userlist.validateNow();
      Lst_userlist.rowCount = ArrUserList.length ;
      else
      lnk_open.label="Open";
      function Click_UserName1(event:MouseEvent,data:Object):void
      loc_first_last_name=event.currentTarget.text;
      var str:String;
      str=ArrUserList[i].label;
      if(loc_first_last_name==str)
      if(ArrUserList[i].click == 0)
      else
      public function Find_Duplicate(test_arr:ArrayCollection):ArrayCollection
      var res_arr:ArrayCollection=new ArrayCollection();
      var flag:Boolean;
      for(var i:int=0;i<test_arr.length;i++)
      var j:int=0
      flag=false;
      for(;j<res_arr.length;j++)
      if(res_arr[j].label==test_arr[i].label)
      res_arr[j].dataCollection.addItem(test_arr[i]);
      flag=true;
      break;
      if(!flag)
      var myItem:Object = new Object() ;
      myItem.label=test_arr[i].label;
      myItem.dataCollection=new ArrayCollection();
      myItem.dataCollection.addItem(test_arr[i]);
      res_arr.addItem(myItem) ;
      return res_arr;
      </fx:Script>
      <s:Scroller id="id_scroller" width="100%" height="100%">
      <s:VGroup id="id_Vgroup" paddingLeft="50" paddingTop="10" paddingBottom="10"   width="100%" height="100%" >
      <mx:VBox width="850" paddingLeft="0" paddingTop="1"    color="black"  backgroundColor="#FFFFFF">
      <mx:HBox width="850" left="50" paddingBottom="3"  paddingLeft="5" backgroundColor="#6D6C6C"   paddingTop="3" color="#FFFFFF" >
      <mx:LinkButton id="lnk_open" label="Open" textDecoration="underline" click="Clink_lnk_open();"/>
      <mx:Button id="load_btn" label="Load" click="Load()"/>
      </mx:HBox>
      <mx:VBox id="Vbox_main" width="850"   horizontalScrollPolicy="off" verticalScrollPolicy="off"  >
      <mx:List variableRowHeight="true"   width="850" id="Lst_userlist" paddingTop="-3" verticalScrollPolicy="off"  horizontalScrollPolicy="off"
      buttonMode="true"  >
      <mx:itemRenderer>
      <fx:Component>
      <mx:VBox paddingTop="-5"  horizontalScrollPolicy="off" verticalScrollPolicy="off" >
      <fx:Script>
      <![CDATA[
      override public function set data(value:Object):void
      super.data = value;
      Membership_Grid.dataProvider=data.dataCollection;
      Membership_Grid.rowCount=data.dataCollection.length;
      lbl_userhead.text=data.label;
      lbl_userhead1.text=data.dataCollection.length+" Datas";
      if(data.click==1)
      Vbox_main.visible=true;
      Vbox_main.includeInLayout=true;
      else
      Vbox_main.visible=false;
      Vbox_main.includeInLayout=false;
      Membership_Grid.validateNow() ;
      </fx:Script>
      <mx:HBox id="vbox_grid"  horizontalScrollPolicy="off"  height="25" verticalScrollPolicy="off" width="850"  paddingLeft="10" paddingTop="5"  backgroundColor="#6D6C6C" color="#FFFFFF">
      <s:Label id="lbl_userhead" click="outerDocument.Click_UserName1(event,data)" buttonMode="true"   width="250"  paddingTop="3" />
      <s:Label id="lbl_userhead1"  buttonMode="true"   width="548" paddingTop="3" />
      </mx:HBox>
      <mx:VBox id="Vbox_main" width="850" horizontalScrollPolicy="off" verticalScrollPolicy="off"  visible="false" includeInLayout="false" >
      <mx:DataGrid id="Membership_Grid"   alternatingItemColors="[#DCDCDC,#F8F8FF]"  paddingLeft="5"  horizontalScrollPolicy="off" color="black"
      horizontalGridLines="false" verticalScrollPolicy="auto"  verticalGridLines="false"  rowHeight="25" width="850"  borderSkin="{null}"
      borderVisible="false" >
      <mx:columns>
      <mx:DataGridColumn width="150" headerText="Year" dataField="label"/>
      <mx:DataGridColumn width="150" headerText="Month" dataField="data"/>
      <mx:DataGridColumn width="150" headerText="Day" dataField="day" />
      <mx:DataGridColumn width="150" headerText="Date"  dataField="date"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:VBox>
      </mx:VBox>
      </fx:Component>
      </mx:itemRenderer>
      </mx:List>
      </mx:VBox>
      </mx:VBox>
      </s:VGroup>
      </s:Scroller>
      </s:Group>
      Thanks in advance ,
      senthil.
