4 Replies Latest reply on May 13, 2011 5:28 AM by jfb00
    ArrayCollection error
    jfb00 Level 3
      Hi All,
      I am getting this error when i try to add an item to an arrayCollection:
      Error: Find criteria must contain at least one sort field value.
      at mx.collections::Sort/findItem()
      at mx.collections::ListCollectionView/getItemIndex()
      I have an advanced datagrid, base on a comboBox change I reload the data to the dataprovider so I have to remove all the items from the arraycollection and add the new data to be display in my ADG.
      I was removing the items with removeAll, the error was showing at this line so change my code to using:
      myArrayCollection = null;
      myArrayCollection = new ArrayCollection();
      After adding the new items to the array collection using a loop I have a sort:
      ----Loop----
      tempObject = new Object();
      myArrayCollection.addItem(tempObject);
      myArrayCollection.refresh();
      ----End Loop----
      var sort:Sort = new Sort();
      my_adg.validateNow();
      sort.fields = [new SortField("MY_FIELD",true)];
      my_adg.dataProvider.sort = sort;
      my_adg.dataProvider.refresh();
      If I remove this sort, all work.
      What is the issue here? The null is not removing the sort?
      Also, in my ADG I have grouping collection.
      <mx:GroupingCollection id="myGroupedData" source="{myArrayCollection}" >
      Any ideas?
      Johnny
