0 Replies Latest reply on May 12, 2011 7:01 AM by smirn69
    Links problem in PDF (opened in web browser)
    smirn69
      I have a problem with the way Adobe reader works when it is embedded in Internet Explorer 7.
      The PDF is well opened but inside this PDF i have links to others PDF, this links doesn't work inside IE but when the PDF is opened inside Reader it works.
      Some precisions :
      - I have a set of PDF files with references in a hierarchy of directories on the machine
      - I have a root HTML file which is the entry point for the navigation through the PDF files set, a link in this HTML file open a PDF in the browser, then links to other PDF in the first PDF doesn't work
      - If i open the first PDF in Reader, links works
      - Inside the PDF the links seems to be File Links with relative paths
      - I think it's possible that there are security restrictions in Internet Explorer that inactive the links but i didn't found these options
      - i'ts also possible that when the first PDF is open, the current path is incorrect with the relative path of the link
      I have no solution with this problem.
      Any help will be appreciated.
      Thanks by advance
      Regards
