3 Replies Latest reply on May 12, 2011 10:04 PM by ShardulSingh
    How Can I Limit the Range that 2 Thumbs Can Select on an HSlider?
    laxmidi Level 1
      I've got a Flex 3 project and I'm using FlexlIb's HSlider with 2 thumbs. How do I "bind" the two thumbs together so that they can only select up to a certain value.
      In my case, I'm using dates. But, I can give you a simpler case. Let's say I have an HSlider with a track that goes from 0 to 100. It has 2 thumbs. How do I make it so that the thumbs can only choose a range from 0 to 30 anywhere on the track? So the 2 thumbs are tied. They can't choose more than 30.
      <code:HSlider id="dateRange"
                 allowThumbOverlap="true" thumbCount="2" showDataTip="false"
                 liveDragging="true" lockRegionsWhileDragging="true"
                 change="dateChange();"
                 showTrackHighlight="true" tickThickness="5"  width="100%"
      Any suggestions?
      Thank you.
      -Laxmidi
        • 1. Re: How Can I Limit the Range that 2 Thumbs Can Select on an HSlider?
          ShardulSingh Level 3
          hi
          You mean to say that if you move the first one then the second one should move with the value of first one +30 ?
          Shardul
          • 2. Re: How Can I Limit the Range that 2 Thumbs Can Select on an HSlider?
            laxmidi Level 1
            Hi Shardul,
            Thanks for your message. Yep, that's what I mean.
            -Laxmidi
            • 3. Re: How Can I Limit the Range that 2 Thumbs Can Select on an HSlider?
              You can try something like this........
              I dont get to time finish it perfectly...........Please hv a look and do the fixes....
              <?xml version="1.0"?>
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
                  <mx:Script>
                      <![CDATA[
                          import mx.controls.sliderClasses.SliderThumb;
                          import mx.events.SliderEvent;
                          import mx.controls.sliderClasses.Slider;
                          private function onSliderChange(event:SliderEvent):void {
                              var ct:Slider=Slider(event.currentTarget);
                              ct.values[0] = ct.values[1]-30;
                         private var thumbMin : SliderThumb;
                         private var thumbMax : SliderThumb;
                          private function onCreationComplete() : void
                              var thumbMin : SliderThumb = hs.getThumbAt(0);
                              thumbMin.enabled = false;
                              var thumbMax : SliderThumb =  hs.getThumbAt(1);
                  </mx:Script>
                  <mx:HSlider id="hs" thumbCount="2"
                      change="onSliderChange(event);" minimum="0" maximum="100" value="{0,30}" creationComplete="onCreationComplete()"/>
              </mx:Application>
              with Regards,
              Shardul
