2 Replies Latest reply on May 15, 2011 9:06 PM by tehxike1
    external lib classes not found
    tehxike1 Level 1
      Starting with 4.5, Flex has complained about the linking of all my projects with default css because they were "merged into code".  The problem described sounded exactly like what I've dealt with- skins randomly not being found despite being defined in defaults, or being overridden by the parent.  I've switched the merge type to external, but now the classes defined in my lib projects can't be found.  Is there something else I need to do to make them work?
        • 1. Re: external lib classes not found
          tehxike1 Level 1
          Maybe further clarifiication will help...
          I have SmallLib, BigLib, and FlexProj.  BigLib references SmallLib (via external link type).  FlexProj references both (via external link types).  When I run FlexProj, it instantly crashes, saying it can't find my main Application (I use a custom Application class, which is in BigProj).  What do I need to do to get FlexProj to find the classes that are in BigLib and SmallLib?
          • 2. Re: external lib classes not found
            tehxike1 Level 1
            Ugh, nobody?  This is a new warning to 4.5..I'd hope somebody would be able to explain it in further detail.
