1 Reply Latest reply on May 14, 2011 7:58 PM by Ned Murphy
    How do I make an animation like these?
    noahvictor
      Can someone please point me in the direction of a tutorial or make one ? Thanks it helps me a lot!
      I'm trying to make an animation similar to the ones on these websites, scrolling images with a navigation bar to return to an image.
      http://www.pfaffvw.com/
      http://www.spinning.com/
        • 1. Re: How do I make an animation like these?
          You probably won't find a tutorial for the first one you linked, though if you really learned how to make a slideshow in Flash you could figure out how to make one of these somewhat common derivative versions.  Try searching Google using terms like "AS3 slideshow tutorial"
          As for the second one you linked, that is not a Flash piece, and you could probably get insight to its workings by going thru the html page code and finding out what code is used and what supporting files are used to make it work. The html code for it starts right after the comment line...
          <!-- Begin Rotating Feature Banners -->
