2 Replies Latest reply on May 16, 2011 7:36 AM by Yan K.
    Getting assemblerResult documents map
    Yan K. Level 1
      I"m using the following DDX to extract PDF attachments:
      <?xml version="1.0" encoding="UTF-8"?>
      <DDX xmlns="http://ns.adobe.com/DDX/1.0/">
      <FileAttachments result="attachmentInfo.xml" nameKeys="*" extract="true">
      <PDF source="inDoc"/>
      <FilenameEncoding encoding="ISO-8859-1"/>
      </FileAttachments>
      </DDX>
      After DDX execution I'm able to retrieve the attachments one by one using the syntax:  /documents[@id='yan.pdf_attach.0000.0003']
      Is there a way to assign to output map of documents variable the whole documents map without looping the attachments ?
      My goal is to call the process from .Net and retrieve all the attachments of input doc.
      Thanks!
