3 Replies Latest reply on May 16, 2011 10:59 AM by Flex harUI
    openItems set item
    Wimbo19
      Hello Developers
      Currently I am working on this little try out project where we use a Tree with XML as a dataprovider. Currently everything is working, but we are trying to create a feature where a user can select which nodes are opend.
      Data input
      <root>
          <PagesController label="Pages" type="controllers">
              <Home label="Home" type="editables" id="1" controllers="pages"/>
          </PagesController>
          <UsersController label="Users" type="controllers">
              <addAction label="Add" type="actions" controllers="users"/>
          </UsersController>
      </root>
      The following line of code is working correctly. The only problem is that I want to generate a loop where as3 fills in the PagesController value.
      var results:XMLList = XMLList(event.result);
      FlexGlobals.topLevelApplication.cms.openItems = results..PagesController;
      I tried to create a object to replace the PagesController value, but for some reason the openItems property isnt working propper.
      Hopefully someone can be helpfull to solve my problem.
      Best regards,
      Wimbo
