1. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 5:02 AM (in response to Mike Benjamin)Click on Show Options and then choose Transparent Background.
Hopefully that should stick for you?
2. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Mike Benjamin May 16, 2011 5:12 AM (in response to Eugene Tyson)Hi Eugene,
I've been using InDesign since Adobe gave birth to it. But now my brain has died! Where is Show Options please???
Mike
3. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 5:15 AM (in response to Mike Benjamin)File>Place
Then there's a check box for Show Options on the Place Dialog box
4. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Mike Benjamin May 16, 2011 5:18 AM (in response to Eugene Tyson)You're a star. And now of course I remember turning this off to demonstrate it to someone. Mega thanks!
Mike
5. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 5:20 AM (in response to Mike Benjamin)Say sorry to the Adobe Updater
6. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 5:25 AM (in response to Eugene Tyson)You don't even have to select Show Options.
When you place the file hold down SHIFT when pressing the Open button.
7. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 5:28 AM (in response to Eugene Tyson)Didn't even know that little gem myself, randomly came across it on a tweet!
8. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Mike Benjamin May 16, 2011 5:31 AM (in response to Eugene Tyson)I was more than ready to start kicking Adobe again! But this time I accept full responsibility!
9. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
BobLevine May 16, 2011 5:40 AM (in response to Eugene Tyson)That "little gem" is a holdover from Pagemaker. :-)
Bob
10. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 5:43 AM (in response to BobLevine)Never used Pagemaker! But that little tip will save me a lot of time from now on!
How would anyone possibly guess that? Should be tip and shortcut info in every dialog box!
11. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
[Jongware] May 16, 2011 5:54 AM (in response to Eugene Tyson)What, so anyone would know that right from the start? Then there'd be no InDesignSecrets worth mentioning!
Shift+Enter and Alt+Enter in the control bar are a similar hidden gem.
12. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 5:58 AM (in response to [Jongware])Brilliant. I need to upgrade my brain to a larger capacity so I can hold more than 5 years worth of information.
13. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
BobLevine May 16, 2011 6:02 AM (in response to Eugene Tyson)Just purge anything related to Quark and you should be good to to.
Bob
14. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
Eugene Tyson May 16, 2011 6:04 AM (in response to BobLevine)><
done
15. Re: Has importing native Illustrator files into InDesign 7.0.4 changed?
John Hawkinson May 16, 2011 5:15 PM (in response to Eugene Tyson)So, another part of this is you can just hold-down shift while double-clicking the file.
This is slightly annoying when placing multiple files.
As far as I know, you need to make sure to click once to start the range, click again to end the range, and then
shift-double-click to open the range with Import Options.
