2 Replies Latest reply on May 16, 2011 2:58 PM by Kristin95762
    accessing buttons on a custom component from the main app
    Kristin95762 Level 1
      This code from Adobe LiveDocs produces and error. There is no "click" event in the code hints for this implementation. So how do I access the button component in my popup window from the main application? Someone left a comment at the bottom of the page but it was not responded to.
      Kristin
      from: http://help.adobe.com/en_US/flex/using/WS6c678f7b363d5da52e8f1ca1124a0430dcf-8000.html
      Error 1009. Cannot access a property or method of a null object reference.
      pop1.cancelButton.addEventListener("click", removeMe);
        • 1. Re: accessing buttons on a custom component from the main app
          Peter Blazejewicz Level 4
          The code sample in that section:
          http://help.adobe.com/en_US/flex/using/WS6c678f7b363d5da52e8f1ca1124a0430dcf-8000.html#WS6 c678f7b363d5da52e8f1ca1124a0430dcf-7ffe
          ("Passing data using events") works for me without compiler or runtime error.
          It is accessed that way that:
          - PopUpManager creates overlying window (component) which is casted to ArrayEntryFormEvents class.
          - because in ArrayEntryFormEvents instances of components in .mxml are named - including "cancelButton" they could be directly accessed via dot based syntax e.g. that way with re-assign:
          var cancelButton:Button = pop1.cancelButton;
          cancelButton.addEventListener(MouseEvent.CLICK, removeMe);
          or directly as in sample:
          pop1.cancelButton.addEventListener(MouseEvent.CLICK, removeMe);
          The main application is owner of pop1 instance so it has no problem with accessing "cancelButton" - as it is available directly for dot based syntax being public variable of ArrayEntryFormEvents,
          regards,
          Peter
          • 2. Re: accessing buttons on a custom component from the main app
            thanks for your response.
            This is my code in the main app mxml
            private function showAddAuthorWindow():void
            authorPopup = new AddAuthorWindow;
            authorPopup.addEventListener(Event.CLOSE, closeHandler);
            authorPopup.addEventListener("addAuthor", addAuthorHandler);
            authorPopup.addEventListener("cancel", closeHandler);
            authorPopup.testButton.addEventListener("click", buttonClicked);
            PopUpManager.addPopUp(authorPopup, this, true);
            PopUpManager.centerPopUp(authorPopup);
            authorPopup.setInitialFocus();
            private function buttonClicked():void
            trace("clicked");
            Maybe my problem is that this is not a default button, but one that I added to the popup. Could that be it?
            I'm trying to control all the actions of the titlewindow from the main application. I am loading data into a list box in the custom component, etc, etc. I figured I had a lot of code in the titlewindow.mxml that shouldn't be localized there. And I'm way too new at this stuff to be utilizing long winded class files just yet.
            Can I load data into a custom control, select, delete, and update data in a custom control through code written primarily in the mainApp.as file?
            \Kristin
