8 Replies Latest reply on May 19, 2011 10:25 PM by Christian Lett
    Strange CPU-vs-GPU Problem with Generated PB Kernel
    Christian Lett Level 3
      This is odd - As part of a larger graph I'm trying to generate a simple boxed hirizontal grid. Here's the code distilled into a kernel:
      <languageVersion : 1.0;>
      kernel gridTest
      <   namespace : "Your Namespace";
          vendor : "Your Vendor";
          version : 1;
          output float4 dst;
          parameter float2 gridBounds <
              defaultValue: float2(200.0, 200.0);
          dependent float gridSpacing;
          const float3 LINE_COLOUR = float3(0.5, 0.25, 0.0);
          region generated() {
              return region(float4(0.0, 0.0, gridBounds.x + 1.0, gridBounds.y + 1.0));
          void evaluateDependents() {
              gridSpacing = gridBounds.y / 10.0;
          void evaluatePixel() {
              float2 coordFloored = floor(outCoord());
              if(mod(coordFloored.y, gridSpacing) < 1.0 || coordFloored.x == 0.0 || coordFloored.x == floor(gridBounds.x))
                  dst.rgb = LINE_COLOUR * 0.8;
              // Hilight bottom, middle and top grid lines
              if(mod(coordFloored.y, gridSpacing * 5.0) < 1.0)
                  dst.rgb += LINE_COLOUR * 0.75;
              dst.a = 1.0;
      Run in GPU mode, it's fine. Run in CPU mode and I get a vertical grid line every few pixels. It's coming from the "coordFloored.x == 0.0" part but I can't figure out why. It's like the outCoord() is reverting to zero every few pixels across. I only spotted it once I ran it in AE, as it runs on the CPU.
      I guess I'm either doing something wrong I just can't see, or it's a bug.
      Any ideas? It's driving me crazy!
      Christian
