1 Reply Latest reply on May 17, 2011 12:37 AM by Adam Cameron.
    validating XML against schema with imports
    bhaja
      I've been trying to validate the XML document located at
      http://flintbox.com/static/api/examples/patents_example.xml
      against the schema located at
      http://flintbox.com/static/api/flintbox-collection.xsd
      in ColdFusion 9 using the code
      <cfset results=xmlvalidate(""http://flintbox.com/static/api/examples/patents_example.xml",
             "http://flintbox.com/static/api/sample-collection.xsd")>
      <cfoutput>
      <cfdump var="#results#">
      </cfoutput>
      When I do so, I observe the following errors:
                       [Error] :4:41: src-import.3.1: The namespace attribute,
                     1 'urn:us:gov:uspto:pair', of an <import> element information
                       item must be identical to the targetNamespace attribute,
                       'null', of the imported document.
                     2 [Error] :181:43: src-resolve: Cannot resolve the name
         errors        'uspto:Country' to a(n) 'element declaration' component.
                       [Error] :18:48: cvc-complex-type.2.4.d: Invalid content was
                     3 found starting with element 'Country'. No child element is
                       expected at this point.
                       [Error] :25:48: cvc-complex-type.2.4.d: Invalid content was
                     4 found starting with element 'Country'. No child element is
      I am able to successfully validate the document against the schema at http://www.xmlforasp.net/SchemaValidator.aspx, however.
      In the past, ColdFusion's XML validation mechanism seems to have had issues with schemas that contain imports, e.g., http://forums.adobe.com/message/155906. Have these issues still not been resolved?
        • 1. Re: validating XML against schema with imports
          Adam Cameron. Level 5
          Do you not think that perhaps you're answering your own question here?
          I don't see an issue about this on the bug tracker.  It might be an idea if you can get a simple, stand-alone repro case together and raise an issue (and post the reference back here and against that other thread so people know to vote for it).  If you post the repro case here too, it would be helpful.
          Adam
