0 Replies Latest reply on May 16, 2011 8:45 PM by BillyBurf
    flex 3 and Maven with RB in a SWC - Help!
    BillyBurf
      I followed an example on a flexmojos site at https://docs.sonatype.org/display/FLEXMOJOS/Application+Localization to  add my Language.properties to a library project.  The Language.properties file  was not in the standard location, so I added <resourceBundlePath> to the  SWC maven POM:
      Multi-Module SWC Localization
      If you are using a  multi-module maven project that uses a SWC with localization and a SWF that uses  the SWC there are a few options:
      Use runtimeLocales in your SWC and add the  Resource Bundle as a dependency in your SWF for each of your supported locales:  SWC POM
              <build>
                      <plugins>
                               <plugin>
                                       <groupId>org.sonatype.flexmojos</groupId>
                                       <artifactId>flexmojos-maven-plugin</artifactId>
                                       <configuration>
                                                               <runtimeLocales><locale>en_US</locale></runtimeLocales>
        ${basedir}/src/main/flex/locales/{locale}
                                                              </resourceBundlePath>
                                       </configuration>
                               </plugin>
                      </plugins>
               </build>
      The project compiles fine and creates the 2 SWC files.
      The Application project (SWF) does not compile because it says it  cannot find the Language resource bundle.
      SWF POM
               <dependencies>
                      <dependency>
                               <groupId>com.example</groupId>
                               <artifactId>example-swc</artifactId>
                               <version>${project.version}</version>
                               <type>swc</type>
                      </dependency>
                       <dependency>
                               <type>rb.swc</type>
                               <classifier>en_US</classifier>
                       </dependency>
              </dependencies>
      Does the  Application POM also need to have a change to it to know the path of the RB?
      The Applications main MXML file has:
           <mx:Metadata>
              [ResourceBundle("Language")]
           </mx:Metadata>
      Does this need to change at all?
      Thanks to all  for your help!
