7 Replies Latest reply on Jul 13, 2011 11:32 AM by Harry See Adobe
    Problems with offline caching
    dirk eismann Level 1
      In a recent AIR 2.6 application I use the offline caching feature of LCDS 3.1
      The application itself uses a Java 6 / Spring 3 / JPA 1 / Hibernate stack (custom code, not using LC model driven development). For offline support, I started with the sample code from the LCDS 3.1 documentation which works ok in most cases - at least, if I fetch collections when online, then go to offline mode and fetch the same collections from the cache. This works fine and the SQLite data base gets created correctly.
      However, as soon as I start calling fill() on a DataService in offline mode on a collection that has *not* been fetched before or try to load an lazy association which has not been fetched before, the DataService "hangs" in terms of that the AsyncToken returned by that fill() method never fires a result or fault event.
      The last thing that happens in the client is
        [DEBUG] mx.data.SQLDBCache SQLDBCache - before select: SELECT id,data FROM [ORGANIZATION_FAVSOrganization]
      and that’s it. In this case I don’t get any further feedback and the DataService does not create a result or fault event, it does not even time out. Not sure if this is by design or not but as I’m listening for result/faults event to display/hide progress indicators gives me a lot of headaches on how to control them in offline mode.
      Any ideas?
      Dirk
        • 1. Re: Problems with offline caching
          Harry See Adobe
          Dirk,
            Could you please send me a snippet of your code for offline?
            Also if you could send me a sqllite database that is being stored.
            This will help me figure out what is going on.
             You can either post your zip file or send it directly to me (hsee@adobe.com)
          Harry
          • 2. Re: Problems with offline caching
            RanjeetDeshmukh
            same problem here..
            is there any update on this?
            thanks much!
            • 3. Re: Problems with offline caching
              Harry See Adobe Level 1
              Ranjeet,
                I am working with DIrk to narrow down his problem. In LCDS 3.1 the new feature of offline was added.
                As a part of the offline feature there is a sub feature called offlineAdapter. You can look at the documentation at this site.
              (http://help.adobe.com/en_US/LiveCycleDataServicesES/3.1/Developing/WS4ba8596dc6a25eff5fb1b f7c1271f8f6997-7ffa.html).
                Is you problem exactly the same as Dirk?
                If not, could you please send me a snippet of your code for offline?
              Harry
              • 4. Re: Problems with offline caching
                RanjeetDeshmukh Level 1
                Harry, thank you for your immed response.
                I think I might have posted my problem under a wrong thread. I am facing this issue for older version of LCDS which I downloaded couple of years back.. it says ES 2.6 and am still a bit confused about the version numbers.
                That being said, my problem is exactly the same. Everything works fine when LCDS server is reachable. However when offline, Fill() just does not call any of the handlers.
                In case if you can still help:
                Here is the DS definition:
                     public class UsersDataService extends EventDispatcher implements IFITDataService
                          private var mDS:DataServiceWrapper;
                          private var mAllUsers:ArrayCollection;
                          public function UsersDataService()
                               mDS = new DataServiceWrapper("UserInfo");
                               mDS.cacheID = "allusers"
                               mAllUsers = new ArrayCollection();
                               mDS.addEventListener(DataServiceFaultEvent.FAULT,OnFault);
                               mDS.autoConnect = true;
                          public function getAllUsers(locationId:String):void
                               mDS.addEventListener(ResultEvent.RESULT, OnResult);
                               if(mDS.isCollectionManaged(mAllUsers))
                                    mDS.refreshCollection(mAllUsers);
                               else
                                    mDS.fill(mAllUsers, locationId);
                          public function getUser(userName:String):void
                               mDS.getItem({ID:userName});
                          public function OnResult(event:ResultEvent):void
                               mDS.removeEventListener(ResultEvent.RESULT, OnResult);
                               trace(event)
                               var dsEvent:DataServiceEvent = new DataServiceEvent(DataServiceEvent.Result)
                               dsEvent.user = event.result
                               dispatchEvent(dsEvent);
                          public function OnFault(event:FaultEvent):void
                               trace(event)
                          public function getData(locationId:String):void
                               getAllUsers(locationId);
                          public function refresh():void
                               else
                                    getAllUsers(FITSession.regLocationID);
                          public function get users():ArrayCollection
                               return mAllUsers
                          public function get connected():Boolean
                               return mDS.connected;
                I am also attaching the 'allusers' db
                Thanks much!
                • 5. Re: Problems with offline caching
                  Ranjeet,
                    I do not see the following in the code snippet that you sent.
                           ds.fallBackToLocalFill = true;
                    This is need to retrieve the data from the offline cache.
                    Please try it.
                  -Harry
                  • 6. Re: Problems with offline caching
                    That method is not available in my version of client side LCDS libraries.
                    • 7. Re: Problems with offline caching
                      You have an much older version of data services.
                      The offline feature is that version was a 1.0 release.
                      Can you update a newer version?
