21 Replies Latest reply on May 18, 2011 3:07 AM by SOGC
    FlashBuilder 4.0 Fails To Start
    SOGC
      We recently upgraded our web server from a dual-core 2GB system to a quad-core 4GB system.  After installing FlashBuilder 4.0, any attempts to start it fail.
      Here is the log from the crash:
      # A fatal error has been detected by the Java Runtime Environment:
      #  Internal Error (0xe06d7363), pid=760, tid=3284
      # JRE version: 6.0_16-b01
      # Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode windows-x86 )
      # Problematic frame:
      # C  [kernel32.dll+0x3fbae]
      # If you would like to submit a bug report, please visit:
      #   http://java.sun.com/webapps/bugreport/crash.jsp
      # The crash happened outside the Java Virtual Machine in native code.
      # See problematic frame for where to report the bug.
      ---------------  T H R E A D  ---------------
      Current thread (0x019a9000):  JavaThread "main" [_thread_in_native, id=3284, stack(0x00030000,0x00130000)]
      siginfo: ExceptionCode=0xe06d7363, ExceptionInformation=0x19930520 0x0012bde0 0x662b0800
      Registers:
      EAX=0x0012bd38, EBX=0x0012bea0, ECX=0x00000003, EDX=0x00000000
      ESP=0x0012bd38, EBP=0x0012bd88, ESI=0x0012be84, EDI=0x0012c154
      EIP=0x76fffbae, EFLAGS=0x00000212
      Top of Stack: (sp=0x0012bd38)
      0x0012bd38:   e06d7363 00000001 00000000 76fffbae
      0x0012bd48:   00000003 19930520 0012bde0 662b0800
      0x0012bd58:   36ffad08 36fface0 00000017 00000017
      0x0012bd68:   0012bdec 00000000 661c19cf 36ffad08
      0x0012bd78:   0000001f 36fface0 00000017 0012c154
      0x0012bd88:   0012bdc0 6620716a e06d7363 00000001
      0x0012bd98:   00000003 0012bdb4 e06d7363 00000001
      0x0012bda8:   00000000 00000000 00000003 19930520
      Instructions: (pc=0x76fffbae)
      0x76fffb9e:   a9 00 00 83 c4 0c 8d 45 b0 50 ff 15 14 17 fc 76
      0x76fffbae:   c9 c2 10 00 90 90 90 90 90 8b ff 55 8b ec 51 51
      Stack: [0x00030000,0x00130000],  sp=0x0012bd38,  free space=1007k
      Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
      C  [amtservices.dll+0x4716a]
      C  [amtservices.dll+0x727a8]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      j  com.adobe.flexide.amt.AMTLib.AMTObtainProductLicense(IILjava/lang/String;Ljava/lang/Strin g;Ljava/lang/String;Ljava/lang/String;IILjava/lang/String;)I+0
      j  com.adobe.flexide.amt.AMTLib.ObtainProductLicense(Ljava/lang/String;Ljava/lang/String;Lja va/lang/String;Ljava/lang/String;IILjava/lang/String;Z)I+27
      j  com.adobe.flexide.amt.Activator.AMT_ObtainLicense(Ljava/lang/String;Ljava/lang/String;IIZ )I+32
      j  com.adobe.flexbuilder.ui.asn.ASNUIBridge.start()Z+43
      j  com.adobe.flexbuilder.ui.UIPlugin.start(Lorg/osgi/framework/BundleContext;)V+21
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run()Ljava/lang/Object;+64
      v  ~StubRoutines::call_stub
      j  java.security.AccessController.doPrivileged(Ljava/security/PrivilegedExceptionAction;)Lja va/lang/Object;+0
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(Lorg/osgi/frame work/BundleActivator;)V+22
      j  org.eclipse.osgi.framework.internal.core.BundleContextImpl.start()V+23
      j  org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(I)V+379
      j  org.eclipse.osgi.framework.internal.core.AbstractBundle.start(I)V+20
      j  org.eclipse.osgi.framework.util.SecureAction.start(Lorg/osgi/framework/Bundle;I)V+8
      J  org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(Ljava/lan g/String;Ljava/lang/Class;Lorg/eclipse/osgi/baseadaptor/loader/ClasspathManager;)V
      J  org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(Ljava/lang/String;)Lj ava/lang/Class;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(Ljava/lang/String;)Ljava/lan g/Class;
      j  org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(Ljava/lang/String;)Ljava/l ang/Class;+8
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Ljava/lang/String;ZLjava/ lang/ClassLoader;)Ljava/lang/Class;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClass(Ljava/lang/String;Z)Ljava/lang/Cl ass;
      J  org.eclipse.osgi.internal.loader.BundleLoader.findClass(Ljava/lang/String;)Ljava/lang/Cla ss;
      J  org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(Ljava/lang/String;Z)Lj ava/lang/Class;
      J  java.lang.ClassLoader.loadClass(Ljava/lang/String;)Ljava/lang/Class;
      J  java.lang.ClassLoader.loadClassInternal(Ljava/lang/String;)Ljava/lang/Class;
      j  com.adobe.flexbuilder.standalone.SplashHandler.init(Lorg/eclipse/swt/widgets/Shell;)V+120
      j  org.eclipse.ui.internal.Workbench$6.run()V+174
      j  org.eclipse.core.runtime.SafeRunner.run(Lorg/eclipse/core/runtime/ISafeRunnable;)V+5
      j  org.eclipse.ui.internal.Workbench.createSplashWrapper()V+32
      j  org.eclipse.ui.internal.Workbench.runUI()I+111
      j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$5.run()V+55
      j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j  com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(Lorg/eclipse/equinox/app/IA pplicationContext;)Ljava/lang/Object;+100
      j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      ---------------  P R O C E S S  ---------------
      Java Threads: ( => current thread )
        0x35f24c00 JavaThread "Thread-1" [_thread_in_native, id=3316, stack(0x37690000,0x37790000)]
        0x35f24400 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=2760, stack(0x36a80000,0x36b80000)]
        0x35f24000 JavaThread "Component Resolve Thread" daemon [_thread_blocked, id=3020, stack(0x36980000,0x36a80000)]
        0x35ef1400 JavaThread "Worker-1" [_thread_blocked, id=2956, stack(0x36880000,0x36980000)]
        0x35f55800 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=2952, stack(0x36780000,0x36880000)]
        0x34e0b400 JavaThread "Worker-0" [_thread_in_native, id=1104, stack(0x36680000,0x36780000)]
        0x35dfb400 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=3036, stack(0x36580000,0x36680000)]
        0x34d41000 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=3016, stack(0x35880000,0x35980000)]
        0x34d47800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=3480, stack(0x35680000,0x35780000)]
        0x34d5f000 JavaThread "State Saver" [_thread_blocked, id=3024, stack(0x35510000,0x35610000)]
        0x020d9000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2972, stack(0x34a90000,0x34b90000)]
        0x020d3c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3032, stack(0x34990000,0x34a90000)]
        0x020d3400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2144, stack(0x34890000,0x34990000)]
        0x020d0c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2964, stack(0x34790000,0x34890000)]
        0x02098400 JavaThread "Finalizer" daemon [_thread_blocked, id=2188, stack(0x34690000,0x34790000)]
        0x02097000 JavaThread "Reference Handler" daemon [_thread_blocked, id=2172, stack(0x34590000,0x34690000)]
      =>0x019a9000 JavaThread "main" [_thread_in_native, id=3284, stack(0x00030000,0x00130000)]
      Other Threads:
        0x02093000 VMThread [stack: 0x34490000,0x34590000] [id=2184]
        0x020d9c00 WatcherThread [stack: 0x34b90000,0x34c90000] [id=3040]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 18176K, used 7703K [0x04180000, 0x05530000, 0x068e0000)
        eden space 16192K,  35% used [0x04180000, 0x04715c20, 0x05150000)
        from space 1984K, 100% used [0x05150000, 0x05340000, 0x05340000)
        to   space 1984K,   0% used [0x05340000, 0x05340000, 0x05530000)
      tenured generation   total 241984K, used 23151K [0x068e0000, 0x15530000, 0x24180000)
         the space 241984K,   9% used [0x068e0000, 0x07f7bc58, 0x07f7be00, 0x15530000)
      compacting perm gen  total 65536K, used 16737K [0x24180000, 0x28180000, 0x34180000)
         the space 65536K,  25% used [0x24180000, 0x251d8460, 0x251d8600, 0x28180000)
      No shared spaces configured.
      Dynamic libraries:
      0x00400000 - 0x0040e000     C:\Program Files\Adobe\Adobe Flash Builder 4\FlashBuilder.exe
      0x771d0000 - 0x772f8000     C:\Windows\system32\ntdll.dll
      0x76fc0000 - 0x7709c000     C:\Windows\system32\kernel32.dll
      0x77130000 - 0x771cd000     C:\Windows\system32\USER32.dll
      0x76e80000 - 0x76ecb000     C:\Windows\system32\GDI32.dll
      0x77350000 - 0x77416000     C:\Windows\system32\ADVAPI32.dll
      0x76db0000 - 0x76e73000     C:\Windows\system32\RPCRT4.dll
      0x74350000 - 0x744ee000     C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_n one_5cb72f2a088b0ed3\COMCTL32.dll
      0x76c30000 - 0x76cda000     C:\Windows\system32\msvcrt.dll
      0x76ed0000 - 0x76f29000     C:\Windows\system32\SHLWAPI.dll
      0x76880000 - 0x7689e000     C:\Windows\system32\IMM32.DLL
      0x76ce0000 - 0x76da8000     C:\Windows\system32\MSCTF.dll
      0x77300000 - 0x77309000     C:\Windows\system32\LPK.DLL
      0x76800000 - 0x7687d000     C:\Windows\system32\USP10.dll
      0x72000000 - 0x72014000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
      0x74c50000 - 0x74c58000     C:\Windows\system32\VERSION.dll
      0x6d800000 - 0x6da8b000     C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
      0x73c90000 - 0x73cc2000     C:\Windows\system32\WINMM.dll
      0x768a0000 - 0x769e5000     C:\Windows\system32\ole32.dll
      0x770a0000 - 0x7712d000     C:\Windows\system32\OLEAUT32.dll
      0x73c50000 - 0x73c8d000     C:\Windows\system32\OLEACC.dll
      0x7c360000 - 0x7c3b6000     C:\Windows\system32\MSVCR71.dll
      0x756a0000 - 0x756cc000     C:\Windows\system32\apphelp.dll
      0x6d7b0000 - 0x6d7bc000     C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\verify.dll
      0x6d330000 - 0x6d34f000     C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\java.dll
      0x6d290000 - 0x6d298000     C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\hpi.dll
      0x75800000 - 0x75807000     C:\Windows\system32\PSAPI.DLL
      0x6d7f0000 - 0x6d7ff000     C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\zip.dll
      0x74c60000 - 0x74c9b000     C:\Windows\system32\rsaenh.dll
      0x75750000 - 0x7576e000     C:\Windows\system32\USERENV.dll
      0x75730000 - 0x75744000     C:\Windows\system32\Secur32.dll
      0x6d610000 - 0x6d623000     C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\net.dll
      0x76410000 - 0x7643d000     C:\Windows\system32\WS2_32.dll
      0x77420000 - 0x77426000     C:\Windows\system32\NSI.dll
      0x74f00000 - 0x74f3b000     C:\Windows\system32\mswsock.dll
      0x74ee0000 - 0x74ee5000     C:\Windows\System32\wship6.dll
      0x74ab0000 - 0x74abf000     C:\Windows\system32\NLAapi.dll
      0x75130000 - 0x75149000     C:\Windows\system32\IPHLPAPI.DLL
      0x75090000 - 0x750c5000     C:\Windows\system32\dhcpcsvc.DLL
      0x75340000 - 0x7536c000     C:\Windows\system32\DNSAPI.dll
      0x752f0000 - 0x752f7000     C:\Windows\system32\WINNSI.DLL
      0x75060000 - 0x75082000     C:\Windows\system32\dhcpcsvc6.DLL
      0x730c0000 - 0x730cf000     C:\Windows\system32\napinsp.dll
      0x730a0000 - 0x730a8000     C:\Windows\System32\winrnr.dll
      0x763c0000 - 0x76409000     C:\Windows\system32\WLDAP32.dll
      0x73040000 - 0x73046000     C:\Windows\system32\rasadhlp.dll
      0x6d630000 - 0x6d639000     C:\Program Files\Adobe\Adobe Flash Builder 4\jre\bin\nio.dll
      0x003a0000 - 0x003f9000     C:\Program Files\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\226\1\.cp\swt-win32-3555.dll
      0x76bb0000 - 0x76c23000     C:\Windows\system32\comdlg32.dll
      0x758a0000 - 0x763b1000     C:\Windows\system32\SHELL32.dll
      0x766e0000 - 0x767fa000     C:\Windows\system32\WININET.dll
      0x77340000 - 0x77343000     C:\Windows\system32\Normaliz.dll
      0x769f0000 - 0x76ba6000     C:\Windows\system32\iertutil.dll
      0x76440000 - 0x76550000     C:\Windows\system32\urlmon.dll
      0x74970000 - 0x749af000     C:\Windows\system32\uxtheme.dll
      0x01980000 - 0x01994000     C:\Program Files\Adobe\Adobe Flash Builder 4\configuration\org.eclipse.osgi\bundles\226\1\.cp\swt-gdip-win32-3555.dll
      0x73e80000 - 0x7402b000     C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6002.18342_none_9e54 f8aaca13c773\gdiplus.dll
      0x353e0000 - 0x35421000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.0.272416\os\win32\x86\BridgeTalk.dll
      0x35780000 - 0x357ea000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.nativelibs_4.0.0.272416\libs\adobe_caps.dll
      0x76550000 - 0x766da000     C:\Windows\system32\SETUPAPI.dll
      0x74bb0000 - 0x74bd1000     C:\Windows\system32\NTMARTA.DLL
      0x75320000 - 0x75331000     C:\Windows\system32\SAMLIB.dll
      0x35430000 - 0x35447000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexbuilder.utils.osnative_4.0.0.272416\os\win32\x86\JNIToNativeBridg e.dll
      0x35450000 - 0x3545a000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amt_win_jnilib.dll
      0x67320000 - 0x673ae000     C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4974_none_50940634bcb 759cb\MSVCP90.dll
      0x667d0000 - 0x66873000     C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4974_none_50940634bcb 759cb\MSVCR90.dll
      0x66490000 - 0x66576000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amtlib.dll
      0x661c0000 - 0x662d4000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\amtservices.dll
      0x73810000 - 0x73870000     C:\Windows\system32\WINHTTP.dll
      0x66b30000 - 0x66b9a000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\adobe_caps.dll
      0x35610000 - 0x35638000     C:\Program Files\Adobe\Adobe Flash Builder 4\plugins\com.adobe.flexide.amt_4.0.0.272416\os\win32\x86\asneu.dll
      0x76f30000 - 0x76fb4000     C:\Windows\system32\CLBCatQ.DLL
      0x72cf0000 - 0x72cfb000     C:\Windows\system32\wbem\wbemprox.dll
      0x72990000 - 0x729eb000     C:\Windows\system32\wbemcomn.dll
      0x72950000 - 0x72960000     C:\Windows\system32\wbem\wbemsvc.dll
      0x72440000 - 0x724d9000     C:\Windows\system32\wbem\fastprox.dll
      0x752d0000 - 0x752e8000     C:\Windows\system32\NTDSAPI.dll
      0x753a0000 - 0x75416000     C:\Windows\system32\NETAPI32.dll
      0x74110000 - 0x7413d000     C:\Windows\system32\WINTRUST.dll
      0x75190000 - 0x75282000     C:\Windows\system32\CRYPT32.dll
      0x75300000 - 0x75312000     C:\Windows\system32\MSASN1.dll
      0x77310000 - 0x77339000     C:\Windows\system32\imagehlp.dll
      VM Arguments:
      jvm_args: -Xms256m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m -Djava.net.preferIPv4Stack=true
      java_command: <unknown>
      Launcher Type: generic
      Environment Variables:
      PATH=C:/Program Files/Adobe/Adobe Flash Builder 4/jre/bin/client;C:/Program Files/Adobe/Adobe Flash Builder 4/jre/bin;C:\Program Files\Adobe\Adobe Flash Builder 4\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPow erShell\v1.0\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\
      USERNAME=bokarius
      OS=Windows_NT
      PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel
      ---------------  S Y S T E M  ---------------
      OS: Windows Server 2008 Build 6002 Service Pack 2
      CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1
      Memory: 4k page, physical 2097151k(2097151k free), swap 4194303k(4194303k free)
      vm_info: Java HotSpot(TM) Client VM (14.2-b01) for windows-x86 JRE (1.6.0_16-b01), built on Jul 31 2009 11:26:58 by "java_re" with MS VC++ 7.1
      time: Tue May 17 05:38:56 2011
      elapsed time: 5 seconds
        • 1. Re: FlashBuilder 4.0 Fails To Start
          Level 2
          is the machine that FB is installed on windows server 2008 ? if I could have gotten FB to install on a server class machine a lot of pain would have gone away a few months ago with FB 4 crashing all the time and needing reinstalls. I would have just shoved it up on Amazon EC2 (which I recommend you all look at) and spun off a virtual machine from an image if it ever crashed. EC2 only supports servers, not client OS's
          • 2. Re: FlashBuilder 4.0 Fails To Start
            m1kal_ Level 2
            Just by curosity, why are you installing Flash Buidler (an IDE for developper) on a server machine?
            Mich
            • 3. Re: FlashBuilder 4.0 Fails To Start
              Level 2
              if you are asking me and not the poster then yeah yeah yeah. i do a lot of work inside of Visual Studio and Sql Server MGT studio. They install fine inside of a server environment. Amazon EC2 only supports servers. but hey you are deploying the stuff on a server anyway. If it crashes there is zero down time in reconfig. msft reconfigs take about 2 hrs each for VS and SQL if you are lucky.
              so once FB started crashing i thought hey maybe FB would install up there with Java. Nada for me at least. It would not run.
              I reinstalled FB4 at least 5 times on my dev box W7.
              and you remote desktop to it. it is sitting hundreds of miles away from me and is incredibly snappy. dev from work dev from home dev from anywhere.
              • 4. Re: FlashBuilder 4.0 Fails To Start
                SOGC Level 1
                It is installed on Server 2008 - BUT, we have it installed on TWO other Window Server 2008 boxes that have 2GB of RAM and dual core processors.
                This is the first attempt at installing it on a 4GB quad core box, and it's not working.
                We need it installed as we have a development box and a production box, and we have a set of code that we compile on development, and then make changed on production and compile a different set of code on production.
                Are you guys implying that it won't run AT ALL on a Server 2008 box?  That's madness.
                • 5. Re: FlashBuilder 4.0 Fails To Start
                  Level 2
                  i am not implying that it won;t i would be delighted if it worked for me. perhaps if there are others like you that have success i will try again if the wrench hits the fan. I use the Amazon cloud for my servers.
                  i am not sure why you have yours installed on a server based on what i read. i mean it sounds like you have different rollout environments that does not mean the FB needs to be on the server but i can be dense.
                  my reason was because the environment crashed so much i was getting sick of it and wanted a virtual machine i could wipe my hand from and just re-run a clean instance in case it was some flakey Java thingey. FB 4.5 has been very stable so anyway just my 2 cents.
                  • 6. Re: FlashBuilder 4.0 Fails To Start
                    SOGC Level 1
                    I'd use FB 4.5 but it's design mode doesn't work with the Flex 4.0 SDK, per this thread: http://forums.adobe.com/thread/850869?tstart=0
                    Is there any way to resolve this issue and get FB 4.0 to work?
                    • 7. Re: FlashBuilder 4.0 Fails To Start
                      Level 2
                      ok so i did not read that thread but why are you trying to do that as in use new with old sdk
                      also why really do you need to have FB running on the server.
                      you can have hundreds of server environments why does your FB dev need to be there despite my goofy reason ?
                      • 8. Re: FlashBuilder 4.0 Fails To Start
                        SOGC Level 1
                        Well, we're not ready to migrate to a new SDK yet - when we tried compiling our 4.0 SDK project with the 4.1 SDK, we immediately ran into issues.
                        Frankly, I'm suprised at how unstable and how many issues FlashBuilder has in general in terms of doing any kind of migrations.
                        We don't have the funds to have several development and production servers, so we have one development and one production web server - we move development code over to production, make the appropriate modifications, and then compile the production code on the production web server.
                        So, once again, what do we do?
                        Are we to believe that while FB 4.0 worked on a Server 2008 machine with 2GB ram dual core, it doesn't work a on a 4GB quad core machine?
                        Are we also to believe that FB 4.5 doesn't support the Flex 4.0 SDK in design mode?
                        It seems like any way we turn we're out of options.
                        • 9. Re: FlashBuilder 4.0 Fails To Start
                          Level 2
                          ok so first off get FB off of servers. sounds like you have enough going on. it doesnt take much to make something not work like  a different Java version so get off that.
                          so let's say you are now on a few dev boxes that are client OS's
                          why are you wanting to go from 4.0 to 4.1 when you could jump to 4.5 and be done for a year  ?
                          if the migration is going to take some time then go for the gold or just stay where you are.
                          i cannot appreciate what you are going thru because i am always using the latest tool and sdk so keep that in mind but i don;t understand this 2 migrations in 1 year thing it is like passing a kidney stone twice
                          • 10. Re: FlashBuilder 4.0 Fails To Start
                            SOGC Level 1
                            We don't have any other boxes to put FB onto.
                            What I'm hearing is that we can't run FB 4.0 (for some unexplained reason), and that we're being forced to upgrade to FB 4.5 and therefore are also being forced to migrate to a new SDK.
                            • 11. Re: FlashBuilder 4.0 Fails To Start
                              SOGC Level 1
                              I think that I've just figured out our solution.
                              We don't need design mode on our production server, and can just export to release build after moving the code from production.
                              So, we can use FB 4.0 on our development server with design mode, and then FB 4.5 on our production server w/out design mode.
                              • 12. Re: FlashBuilder 4.0 Fails To Start
                                Level 2
                                what are you a company with just 2 servers and that is it?
                                what do you mean you have no client boxes that is too funny !
                                • 13. Re: FlashBuilder 4.0 Fails To Start
                                  SOGC Level 1
                                  Haha well, we use dedicated servers hosted by GoDaddy.  We're a small startup, and don't have any reason to rent more servers than we need.
                                  We technically have 3 servers - one dev box that's a web server and DB box, and a production web server / and one production DB.
                                  Our solution does everything that we need, and now that we have a fix for this FB issue, all is as it should be
                                  • 14. Re: FlashBuilder 4.0 Fails To Start
                                    Level 2
                                    too funny cheers !
                                    • 15. Re: FlashBuilder 4.0 Fails To Start
                                      Level 2
                                      you could get a 300$ box from Dell !
                                      • 16. Re: FlashBuilder 4.0 Fails To Start
                                        SOGC Level 1
                                        Right .. however, we don't have any colocated space to store the server, nor would we want to burden ourselves with a non-hosted solution (for the time being).  We're just barely covering our costs, and not having to worry about the IT side of things saves a LOT of time and resources.
                                        It's $200 or so extra a month for a hosted 2GB dual core box, and given that we can run FB on our production web server, and that it doesn't take up any resources other than disk space (when we don't use it), there's no harm in running it on our production web server.
                                        If there's an alternative solution that meets our needs and is viable from a cost perspective, then we'd absolutely explore it and potentially switch over.
                                        • 17. Re: FlashBuilder 4.0 Fails To Start
                                          Level 2
                                          we can give u an offer ...
                                          you will be pleased
                                          • 18. Re: FlashBuilder 4.0 Fails To Start
                                            SOGC Level 1
                                            Who's we?  Are you a hosting provider?
                                            • 19. Re: FlashBuilder 4.0 Fails To Start
                                              Level 2
                                              drewpierce@live.com
                                              dont worry no hosing
                                              • 20. Re: FlashBuilder 4.0 Fails To Start
                                                m1kal_ Level 2
                                                I know that it's not closely linked to the subject, but I still can't understand why on earth you have to compile your application on the server. Is your code depends closely to the server environment.
                                                For example, code in Flex and Java doesn't depends on the server environment as the compilation result is a pseudo code (bytecode) running then inside a virtual machine.
                                                For my part, I'm developping (java server part and flex ui) everything on my dev box (mac), compile it and then just copy the compiled file (swf and jars) to the production servers (linux).
                                                Regards,
                                                Mich
                                                • 21. Re: FlashBuilder 4.0 Fails To Start
                                                  SOGC Level 1
                                                  For ease and efficiency -
