2 Replies Latest reply on May 19, 2011 10:56 AM by bon_t
    How to apply different formatting to TextArea content
    bon_t Level 1
      Hello,
      I have a TextArea component called labels that will be populated by Strings in an Array called labelsArray.
      Example of labelsArray content:
      [CODE]private var labelsArray:Array = new Array( "apple", "*banana", "carrot" );[/CODE]
      Initially, I populated labels with this statement:
      [CODE]labels.text = labelsArray.join( "\n" );[/CODE]
      If the String is preceded by an asterisk(*) - as is the case with "banana" in the sample content - that String needs to be in a different color AND be surrounded by square brackets []. The asterisk itself is not displayed.
      I was not able to find any formatting applied to Strings.
      I found out about the TextFormat class to be applied to TextField objects with setTextFormat.
      I also found out about the TextLayoutFormat class to be applied to TextArea objects with setFormatOfRange. Unfortunately, I don't under the explanations given for the parameters of setFormatOfRange:
      setFormatOfRange( format, anchorPosition, activePosition )
      anchorPosition - A character position, relative to the beginning of the text String, specifying the end of the selection that stays fixed when the selection is extended with the arrow keys.
      activePosition - A character position, relative to the beginning of the text String, specifying the end of the selection that moves when the selection is extended with the arrow keys.
      I don't understand starting from "...specifying the end..." to the end. I don't understand how arrow keys come into play with formatting of text.
      Is there something much simpler than this? I'm hoping to loop through labelsArray and apply formatting if needed on each String, and then concatenating/appending it to labels.text.
      Thanks for your help!
      Bonnie
        • 1. Re: How to apply different formatting to TextArea content
          Flex harUI Adobe Employee
          To just change color, you should be able to use the html
          tag and then
          assign to the htmlText property
          • 2. Re: How to apply different formatting to TextArea content
            bon_t Level 1
            With some external help, I've figured this out and would like to share my solution.
            If you are using a Halo (mx) TextArea component, then you can simply use the htmlText attribute, which is a String, and set your xml marked-up String to this attribute.
            However, if you are using a Spark TextArea component, the htmlText attribute no longer exists. You have to set the textFlow attribute. And you do this indirectly with the following command:
            [CODE]<TextArea component>.textFlow = spark.utils.TextFlowUtil.importFromString( <htmlTextString> );[/CODE]
            I hope this helps others out,
            Bonnie
