8 Replies Latest reply on May 23, 2011 7:59 AM by qtip73
    Flash Builder 4.5 for PHP Trial no longer starting
    qtip73 Level 1
      Product has been working fine for about two weeks.  All of sudden I'm getting an error message at startup and that I should look in the log.  Below is a snapshot of the last entry:
      !SESSION 2011-05-17 12:06:02.120 -----------------------------------------------
      eclipse.buildId=M20100909-0800
      java.version=1.6.0_16
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86
      !ENTRY org.eclipse.osgi 4 0 2011-05-17 12:06:06.568
      !MESSAGE Application error
      !STACK 1
      org.eclipse.swt.SWTError: No more handles
          at org.eclipse.swt.SWT.error(SWT.java:4109)
          at org.eclipse.swt.SWT.error(SWT.java:3998)
          at org.eclipse.swt.SWT.error(SWT.java:3969)
          at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
          at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)
          at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)
          at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)
          at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)
          at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
          at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)
          at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)
          at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java :159)
          at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265)
          at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86)
          at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782)
          at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
          at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:798)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:108)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
        • 1. Re: Flash Builder 4.5 for PHP Trial no longer starting
          Jayant Bharosa
          Just had the same problem!!
          But not with trail but with the full version of Flash Builer 4.5 premium
          ENTRY org.eclipse.osgi 4 0 2011-05-19 18:29:34.236
          !STACK 1
          !SESSION 2011-05-19 18:30:52.612 -----------------------------------------------
          eclipse.buildId=M20110210-1200
          !ENTRY org.eclipse.osgi 4 0 2011-05-19 18:30:53.682
          !STACK 1
          ANY HELP WOULD BE APPRECIATED
          • 2. Re: Flash Builder 4.5 for PHP Trial no longer starting
            Unni Gopinathan S Adobe Employee
            Can you please check the bundled eclipse version. I have seen this error if you update the Flash Builder bundled eclipse through the update site.
            • 3. Re: Flash Builder 4.5 for PHP Trial no longer starting
              Jayant Bharosa Level 1
              Hi Innings,
              Thanks for the quick responce. Yes i did an update through flash builder 4.5.
              After that the problem came. What do you mean by "check the bundled eclipse version?"
              Thank you in advanced.
              • 4. Re: Flash Builder 4.5 for PHP Trial no longer starting
                qtip73 Level 1
                I haven't performed an update.  I did uninstall/reinstall the product with no change.  I'm not sure how to check the eclipse version because it won't start but I did find a text file (.eclipseproduct) in the eclipse subdirectory:
                name=Eclipse Platform
                id=org.eclipse.platform
                version=3.6.1
                Thanks.
                • 5. Re: Flash Builder 4.5 for PHP Trial no longer starting
                  RoyGanor Level 1
                  I did the update from the eclipse mechanism and haven't notice this issue, any additional step that can help to reproduce it?
                  Could you please start Adobe Flash builder with "-console -debug" and send the log, it will mainly be helpful to understand the runtime environment.
                  Roy
                  • 6. Re: Flash Builder 4.5 for PHP Trial no longer starting
                    qtip73 Level 1
                    I ran flashbuilder.exe from the console with the debug statement.  I got an error and was pointed to a log file.  Contents are below.
                    !SESSION 2011-05-19 16:31:01.604 -----------------------------------------------
                    Command-line arguments:  -os win32 -ws win32 -arch x86 -console -debug
                    !ENTRY org.eclipse.osgi 2 0 2011-05-19 16:31:02.181
                    !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.team.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.team.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.team.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.intro.universal.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.intro.universal.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.ui.intro.universal_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.team.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.team.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.mylyn.team.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.help.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.help.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.help_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.updatechecker.nl1_3.6.0.v2009112104 3401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.updatechecker.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.equinox.p2.updatechecker_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator.nl1_3.6.0.v20091121043401. jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.update.configurator.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.update.configurator_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.registry.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.registry.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.equinox.registry_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jsch.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jsch.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.jsch.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.text.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.text.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.181
                    !MESSAGE Missing host org.eclipse.text_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.publisher.nl1_3.6.0.v20091121043401 .jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.publisher.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.equinox.p2.publisher_[0.0.0,9.0.0).
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.wikitext.tasks.ui.nl1_3.6.0.v20091121043 401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.wikitext.tasks.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.mylyn.wikitext.tasks.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.osgi.services.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.osgi.services.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.osgi.services_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.team.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.team.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.team.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ltk.ui.refactoring.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ltk.ui.refactoring.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.ltk.ui.refactoring_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.repository.nl1_3.6.0.v2009112104340 1.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.repository.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.equinox.p2.repository_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.debug.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.debug.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.jdt.debug_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.presentations.r21.nl1_3.6.0.v20091121043401 .jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.presentations.r21.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.ui.presentations.r21_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jface.databinding.nl1_3.6.0.v20091121043401.ja r/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jface.databinding.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.jface.databinding_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.browser.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.browser.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.ui.browser_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.help.base.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.help.base.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.help.base_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.runtime.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.core.runtime_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.apt.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.apt.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.182
                    !MESSAGE Missing host org.eclipse.jdt.apt.ui_[0.0.0,9.0.0).
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ant.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ant.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.ant.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.jdt_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.navigator.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.navigator.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.ui.navigator_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.wst.xsd.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.xsd.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.wst.xsd.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.update.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.update.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins.nl1_3.6.0.v20091 121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.reconciler.dropins.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.equinox.p2.reconciler.dropins_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.registry.nl1_3.6.0.v2009112104340 1.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.http.registry.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.equinox.http.registry_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.console.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.console.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.equinox.p2.console_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.discovery.ui.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.discovery.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.mylyn.discovery.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.views.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.views.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.ui.views_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.jdt.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.director.app.nl1_3.6.0.v20091121043 401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.director.app.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.equinox.p2.director.app_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.workbench.texteditor.nl1_3.6.0.v20091121043 401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.workbench.texteditor.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.ui.workbench.texteditor_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.wst.internet.cache.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.internet.cache.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.wst.internet.cache_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.junit.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.jdt.junit.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.expressions.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.core.expressions.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.core.expressions_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.tasks.bugs.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.tasks.bugs.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.mylyn.tasks.bugs_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.doc.user.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.doc.user.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.jdt.doc.user_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.editors.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.editors.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.ui.editors_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.extensionlocation.nl1_3.6.0.v200911 21043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.extensionlocation.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.183
                    !MESSAGE Missing host org.eclipse.equinox.p2.extensionlocation_[0.0.0,9.0.0).
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ant.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ant.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.ant.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.databinding.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.core.databinding.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.core.databinding_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jsch.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jsch.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.jsch.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.swt.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.swt.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.swt_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.net.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.net.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.core.net_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.search.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.search.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.search_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.event.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.event.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.equinox.event_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.6.0.v20091 121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.equinox.p2.touchpoint.eclipse_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime.compatibility.auth.nl1_3.6.0.v200 91121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.runtime.compatibility.auth.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.core.runtime.compatibility.auth_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.help.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.help.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.help.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.preferences.nl1_3.6.0.v20091121043401. jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.preferences.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.equinox.preferences_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.junit4.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.junit4.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.junit4_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.workbench.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.workbench.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.ui.workbench_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.artifact.repository.nl1_3.6.0.v2009 1121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.equinox.p2.artifact.repository_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.security.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.security.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.equinox.security_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.apt.pluggable.core.nl1_3.6.0.v200911210434 01.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.apt.pluggable.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.jdt.apt.pluggable.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.commands.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.commands.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.184
                    !MESSAGE Missing host org.eclipse.core.commands_[0.0.0,9.0.0).
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.views.log.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.views.log.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.ui.views.log_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.net.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.net.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.ui.net_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.wst.xml.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.xml.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.wst.xml.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime.compatibility.nl1_3.6.0.v20091121 043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.runtime.compatibility.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.core.runtime.compatibility_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.team.cvs.ssh2.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.team.cvs.ssh2_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jface.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jface.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.jface_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.servlet.nl1_3.6.0.v20091121043401 .jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.http.servlet.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.equinox.http.servlet_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.swt.win32.win32.x86.nl1_3.6.0.v20091121043401. jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.swt.win32.win32.x86.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.swt.win32.win32.x86_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.views.properties.tabbed.nl1_3.6.0.v20091121 043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.views.properties.tabbed.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.ui.views.properties.tabbed_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.compare.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.compare.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.compare_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.resources.ui.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.resources.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.mylyn.resources.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.navigator.resources.nl1_3.6.0.v200911210434 01.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.navigator.resources.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.ui.navigator.resources_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.rcp.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.rcp.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.rcp_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.help.webapp.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.help.webapp.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.help.webapp_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.boot.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.boot.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.core.boot_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.app.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.app.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.equinox.app_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.osgi.util.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.osgi.util.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.osgi.util_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.garbagecollector.nl1_3.6.0.v2009112 1043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.garbagecollector.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.equinox.p2.garbagecollector_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.wst.validation.ui.nl1_3.6.0.v20091121043401.ja r/ was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.validation.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.185
                    !MESSAGE Missing host org.eclipse.wst.validation.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.metadata.nl1_3.6.0.v20091121043401. jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.metadata.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.metadata_[0.0.0,9.0.0).
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives.nl1_3.6.0.v20091 121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.touchpoint.natives.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.touchpoint.natives_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.filesystem.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.filesystem.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.core.filesystem_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.intro.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.intro.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.ui.intro_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.debug.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.debug.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.debug.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.cheatsheets.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.ui.cheatsheets_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.6.0.v2009112 1043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.ui.sdk.scheduler_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.jarprocessor.nl1_3.6.0.v20091121043 401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.jarprocessor.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.jarprocessor_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.director.nl1_3.6.0.v20091121043401. jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.director.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.director_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.debug.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.debug.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.jdt.debug.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.externaltools.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.ui.externaltools_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.tasks.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.tasks.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.mylyn.tasks.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.launching.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.launching.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.jdt.launching_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.engine.nl1_3.6.0.v20091121043401.ja r/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.engine.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.engine_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.contenttype.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.core.contenttype.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.core.contenttype_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.ide.application.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.ide.application.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.ui.ide.application_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.security.ui.nl1_3.6.0.v20091121043401. jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.security.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.security.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.jobs.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.jobs.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.core.jobs_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.console.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.console.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.ui.console_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.context.ui.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.context.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.mylyn.context.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.team.cvs.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.team.cvs.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.updatesite.nl1_3.6.0.v2009112104340 1.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.updatesite.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.updatesite_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.databinding.beans.nl1_3.6.0.v200911210434 01.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.databinding.beans.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.core.databinding.beans_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.resources.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.resources.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.core.resources_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.186
                    !MESSAGE Missing host org.eclipse.equinox.p2.ui_[0.0.0,9.0.0).
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.platform.doc.user.nl1_3.6.0.v20091121043401.ja r/ was not resolved.
                    !SUBENTRY 2 org.eclipse.platform.doc.user.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.platform.doc.user_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.p2.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.wst.sse.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.sse.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.wst.sse.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.compare.win32.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.compare.win32.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.compare.win32_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.junit4.runtime.nl1_3.6.0.v20091121043401.j ar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit4.runtime.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.jdt.junit4.runtime_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.junit.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.jdt.junit_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.mylyn.wikitext.ui.nl1_3.6.0.v20091121043401.ja r/ was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.wikitext.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.mylyn.wikitext.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.jdt.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.nl1_3.6.0.v20091121043401.ja r/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.ui.sdk.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.p2.ui.sdk_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.variables.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.core.variables.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.core.variables_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.core.manipulation.nl1_3.6.0.v2009112104340 1.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.core.manipulation.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.jdt.core.manipulation_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.wst.dtd.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.dtd.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.wst.dtd.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.ide.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.ide.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.ui.ide_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.repository.tools.nl1_3.6.0.v2009112 1043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.repository.tools.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.p2.repository.tools_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.ds.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.ds.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.ds_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jface.text.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jface.text.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.jface.text_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.directorywatcher.nl1_3.6.0.v2009112 1043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.directorywatcher.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.p2.directorywatcher_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.platform.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.platform.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.platform_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.scheduler.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.update.scheduler.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.update.scheduler_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.team.cvs.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.team.cvs.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.compare.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.compare.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.compare.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.common.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.common.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.common_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.update.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.update.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ltk.core.refactoring.nl1_3.6.0.v20091121043401 .jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ltk.core.refactoring.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.ltk.core.refactoring_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.ui.forms.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.forms.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.ui.forms_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.metadata.generator.nl1_3.6.0.v20091 121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.metadata.generator.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.p2.metadata.generator_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.p2.metadata.repository.nl1_3.6.0.v2009 1121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.equinox.p2.metadata.repository_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.help.appserver.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.help.appserver.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.help.appserver_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.filebuffers.nl1_3.6.0.v20091121043401.jar / was not resolved.
                    !SUBENTRY 2 org.eclipse.core.filebuffers.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.core.filebuffers_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.debug.ui.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.debug.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.187
                    !MESSAGE Missing host org.eclipse.debug.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.junit.runtime.nl1_3.6.0.v20091121043401.ja r/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit.runtime.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.188
                    !MESSAGE Missing host org.eclipse.jdt.junit.runtime_[0.0.0,9.0.0).
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.188
                    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jdt.apt.core.nl1_3.6.0.v20091121043401.jar/ was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.apt.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.188
                    !MESSAGE Missing host org.eclipse.jdt.apt.core_[0.0.0,9.0.0).
                    !ENTRY org.eclipse.osgi 2 0 2011-05-19 16:31:02.190
                    !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.osgi.services.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [2] was not resolved.
                    !SUBENTRY 2 org.eclipse.osgi.services.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.osgi.util.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [3] was not resolved.
                    !SUBENTRY 2 org.eclipse.osgi.util.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.ant.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [5] was not resolved.
                    !SUBENTRY 2 org.eclipse.ant.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.ant.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [6] was not resolved.
                    !SUBENTRY 2 org.eclipse.ant.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.compare.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [7] was not resolved.
                    !SUBENTRY 2 org.eclipse.compare.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.compare.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [8] was not resolved.
                    !SUBENTRY 2 org.eclipse.compare.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.compare.win32.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [9] was not resolved.
                    !SUBENTRY 2 org.eclipse.compare.win32.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.core.boot.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [10] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.boot.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.core.commands.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [11] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.commands.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.core.contenttype.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [12] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.contenttype.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.core.databinding.beans.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [13] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.databinding.beans.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.core.databinding.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [14] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.databinding.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.190
                    !MESSAGE Bundle org.eclipse.core.expressions.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [15] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.expressions.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.filebuffers.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [16] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.filebuffers.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.filesystem.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [17] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.filesystem.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.jobs.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [18] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.jobs.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.net.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [19] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.net.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.resources.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [20] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.resources.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.runtime.compatibility.auth.nl1_3.6.0.v20091121043401_3.6.0.v200911210434 01 [21] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.runtime.compatibility.auth.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.runtime.compatibility.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [22] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.runtime.compatibility.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.runtime.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [23] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.runtime.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.core.variables.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [24] was not resolved.
                    !SUBENTRY 2 org.eclipse.core.variables.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.debug.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [25] was not resolved.
                    !SUBENTRY 2 org.eclipse.debug.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.debug.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [26] was not resolved.
                    !SUBENTRY 2 org.eclipse.debug.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.app.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [27] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.app.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.common.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [28] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.common.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.ds.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [29] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.ds.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.event.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [30] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.event.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.http.registry.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [31] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.http.registry.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.http.servlet.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [32] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.http.servlet.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.artifact.repository.nl1_3.6.0.v20091121043401_3.6.0.v2009112104340 1 [33] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.console.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [34] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.console.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [35] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.director.app.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [36] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.director.app.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.director.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [37] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.director.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.directorywatcher.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [38] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.directorywatcher.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.engine.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [39] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.engine.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.extensionlocation.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [40] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.extensionlocation.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.garbagecollector.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [41] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.garbagecollector.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.jarprocessor.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [42] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.jarprocessor.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.metadata.generator.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [43] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.metadata.generator.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.metadata.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [44] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.metadata.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.metadata.repository.nl1_3.6.0.v20091121043401_3.6.0.v2009112104340 1 [45] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.publisher.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [46] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.publisher.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.reconciler.dropins.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [47] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.reconciler.dropins.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.repository.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [48] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.repository.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !MESSAGE Bundle org.eclipse.equinox.p2.repository.tools.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [49] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.repository.tools.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.191
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [50] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.p2.touchpoint.natives.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [51] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.touchpoint.natives.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.p2.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [52] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.p2.ui.sdk.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [53] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.ui.sdk.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [54] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.p2.updatechecker.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [55] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.updatechecker.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.p2.updatesite.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [56] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.p2.updatesite.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.preferences.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [57] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.preferences.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.registry.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [58] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.registry.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.security.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [59] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.security.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.equinox.security.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [60] was not resolved.
                    !SUBENTRY 2 org.eclipse.equinox.security.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.help.appserver.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [61] was not resolved.
                    !SUBENTRY 2 org.eclipse.help.appserver.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.help.base.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [62] was not resolved.
                    !SUBENTRY 2 org.eclipse.help.base.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.help.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [63] was not resolved.
                    !SUBENTRY 2 org.eclipse.help.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.help.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [64] was not resolved.
                    !SUBENTRY 2 org.eclipse.help.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.help.webapp.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [65] was not resolved.
                    !SUBENTRY 2 org.eclipse.help.webapp.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.apt.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [66] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.apt.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.apt.pluggable.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [67] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.apt.pluggable.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.apt.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [68] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.apt.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.core.manipulation.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [69] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.core.manipulation.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [70] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.debug.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [71] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.debug.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.debug.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [72] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.debug.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.doc.user.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [73] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.doc.user.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !MESSAGE Bundle org.eclipse.jdt.junit.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [74] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.192
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jdt.junit.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [75] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jdt.junit.runtime.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [76] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit.runtime.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jdt.junit4.runtime.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [77] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.junit4.runtime.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jdt.launching.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [78] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.launching.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jdt.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [79] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jdt.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [80] was not resolved.
                    !SUBENTRY 2 org.eclipse.jdt.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jface.databinding.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [81] was not resolved.
                    !SUBENTRY 2 org.eclipse.jface.databinding.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jface.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [82] was not resolved.
                    !SUBENTRY 2 org.eclipse.jface.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jface.text.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [83] was not resolved.
                    !SUBENTRY 2 org.eclipse.jface.text.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jsch.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [84] was not resolved.
                    !SUBENTRY 2 org.eclipse.jsch.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.jsch.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [85] was not resolved.
                    !SUBENTRY 2 org.eclipse.jsch.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.ltk.core.refactoring.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [86] was not resolved.
                    !SUBENTRY 2 org.eclipse.ltk.core.refactoring.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.ltk.ui.refactoring.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [87] was not resolved.
                    !SUBENTRY 2 org.eclipse.ltk.ui.refactoring.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.context.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [88] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.context.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.discovery.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [89] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.discovery.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.resources.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [90] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.resources.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.tasks.bugs.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [91] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.tasks.bugs.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.tasks.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [92] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.tasks.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.team.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [93] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.team.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.wikitext.tasks.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [94] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.wikitext.tasks.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.mylyn.wikitext.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [95] was not resolved.
                    !SUBENTRY 2 org.eclipse.mylyn.wikitext.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.platform.doc.user.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [96] was not resolved.
                    !SUBENTRY 2 org.eclipse.platform.doc.user.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.platform.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [97] was not resolved.
                    !SUBENTRY 2 org.eclipse.platform.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.rcp.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [98] was not resolved.
                    !SUBENTRY 2 org.eclipse.rcp.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.search.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [99] was not resolved.
                    !SUBENTRY 2 org.eclipse.search.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.swt.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [100] was not resolved.
                    !SUBENTRY 2 org.eclipse.swt.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.swt.win32.win32.x86.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [101] was not resolved.
                    !SUBENTRY 2 org.eclipse.swt.win32.win32.x86.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.team.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [102] was not resolved.
                    !SUBENTRY 2 org.eclipse.team.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Missing host org.eclipse.team.core_[0.0.0,9.0.0).
                    !MESSAGE Bundle org.eclipse.team.cvs.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [103] was not resolved.
                    !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.team.cvs.ssh2.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [104] was not resolved.
                    !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.team.cvs.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [105] was not resolved.
                    !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.team.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [106] was not resolved.
                    !SUBENTRY 2 org.eclipse.team.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.text.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [107] was not resolved.
                    !SUBENTRY 2 org.eclipse.text.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !MESSAGE Bundle org.eclipse.ui.browser.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [108] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.browser.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.193
                    !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.cheatsheets.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [109] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.console.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [110] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.console.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.editors.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [111] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.editors.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.externaltools.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [112] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.forms.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [113] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.forms.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.ide.application.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [114] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.ide.application.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.ide.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [115] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.ide.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.intro.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [116] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.intro.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.intro.universal.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [117] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.intro.universal.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Missing host org.eclipse.ui.intro.universal_[0.0.0,9.0.0).
                    !MESSAGE Bundle org.eclipse.ui.navigator.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [118] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.navigator.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.navigator.resources.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [119] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.navigator.resources.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.net.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [120] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.net.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [121] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.presentations.r21.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [122] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.presentations.r21.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.views.log.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [123] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.views.log.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.views.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [124] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.views.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.views.properties.tabbed.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [125] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.views.properties.tabbed.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.workbench.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [126] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.workbench.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.ui.workbench.texteditor.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [127] was not resolved.
                    !SUBENTRY 2 org.eclipse.ui.workbench.texteditor.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.update.configurator.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [128] was not resolved.
                    !SUBENTRY 2 org.eclipse.update.configurator.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Missing host org.eclipse.update.configurator_[0.0.0,9.0.0).
                    !MESSAGE Bundle org.eclipse.update.core.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [129] was not resolved.
                    !SUBENTRY 2 org.eclipse.update.core.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.update.scheduler.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [130] was not resolved.
                    !SUBENTRY 2 org.eclipse.update.scheduler.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.update.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [131] was not resolved.
                    !SUBENTRY 2 org.eclipse.update.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.wst.dtd.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [132] was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.dtd.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.wst.internet.cache.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [133] was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.internet.cache.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.wst.sse.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [134] was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.sse.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.wst.validation.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [135] was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.validation.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.wst.xml.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [136] was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.xml.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Bundle org.eclipse.wst.xsd.ui.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [137] was not resolved.
                    !SUBENTRY 2 org.eclipse.wst.xsd.ui.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !MESSAGE Missing host org.eclipse.wst.xsd.ui_[0.0.0,9.0.0).
                    !MESSAGE Bundle org.junit4.nl1_3.6.0.v20091121043401_3.6.0.v20091121043401 [138] was not resolved.
                    !SUBENTRY 2 org.junit4.nl1_3.6.0.v20091121043401 2 0 2011-05-19 16:31:02.194
                    !ENTRY org.eclipse.osgi 4 0 2011-05-19 16:31:02.195
                    !MESSAGE Application error
                    !STACK 1
                    java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
                        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:74)
                        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
                        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                        at java.lang.reflect.Method.invoke(Unknown Source)
                        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
                        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
                        at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
                    • 7. Re: Flash Builder 4.5 for PHP Trial no longer starting
                      sudhirm
                      @ qtip73: Can you also please attach or mail me (sudhirm AT adobe DOT com) the config.ini file under <installation folder>/eclipse/configuration and the eclipse.ini file under <installation folder>/eclipse
                      @Jayanth: I am sorry, but updating base eclipse is not a supported scenario. More details can be found in http://bugs.adobe.com/jira/browse/FBG-2515 and http://bugs.adobe.com/jira/browse/FB-30479
                      Sudhir
                      • 8. Re: Flash Builder 4.5 for PHP Trial no longer starting
                        qtip73 Level 1
                        Hello.
                        Looks like I resolved my own issue.  I removed Flash Builder PHP from one drive and installed it another.  After checking the references to the error logs I noticed it was referring to the installation I removed previously.  Turns out the uninstall does not remove all the files completely.  After the deleted whatever folder I could find from the old install, the application starts ok.
                        Thanks!
