8 Replies Latest reply on Aug 14, 2006 10:45 AM by Newsgroup_User
    Dreaweaver only saves as template
    Level 7
      Folks:
      I'm using Dreamweaver 8. Today, it's refusing to save files as anything
      but a template.
      When I try to save (File > Save or Ctrl+S), the save as template dialog
      opens up. If I choose Files > Save As, I can save the files on top of
      themselves, but that's a real pain in the neck.
      Does anyone have a fix for this?
      - Kevin
        • 1. Re: Dreaweaver only saves as template
          Level 7
          as a guess, there is an html comment in the code that is template syntax.
          do a find for <!-- and scan all the comments.
          • 2. Re: Dreaweaver only saves as template
            Level 7
            The file was built from a template, so there are template-syntax HTML
            comments. Why would that force me to save the file as a template?
            - Kevin
            • 3. Re: Dreaweaver only saves as template
              Level 7
              How did you make this file?
              did you open the template.dwt file, and do a "Save As" file.html?
              don't do that.
              the way to make a child page of a template-
              File-->New
              In new file dialog box, click Templates.
              Click thissite
              click thetemplatefileyouwant
              check in lower right corner "update file when template changes"
              then save the new file to within the site folder.
              That makes a child of a template.
              • 4. Re: Dreaweaver only saves as template
                Level 7
                Just like you said. I used File > New > Templates > Chose the template,
                then saved the file.
                - Kevin
                • 5. Re: Dreaweaver only saves as template
                  Level 7
                  could you upload it, and post a link to it pls.
                  • 6. Re: Dreaweaver only saves as template
                    Level 7
                    Kevin:
                    Alan is correct. The only thing that would make DW think that you need to
                    save a page as a template would be if the page had template markup in it.
                    Look in the code and see if you can find <!-- TemplateBegin anywhere. If
                    you can, then that page has been improperly created from a template.
                    Murray --- ICQ 71997575
                    Adobe Community Expert
                    (If you *MUST* email me, don't LAUGH when you do so!)
                    http://www.dreamweavermx-templates.com - Template Triage!
                    http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                    http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                    http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
                    "Kevin" <user@example.net> wrote in message
                    news:ebit8i$c7$1@forums.macromedia.com...
                    > - Kevin
                    • 7. Re: Dreaweaver only saves as template
                      Level 7
                      Murray *ACE* wrote:
                      > Kevin:
                      Thanks for that tip, Murray. I wish I'd known to look for that
                      particular tag amongst the other Template tags. By the time I saw your
                      message, I had already deleted the problem file and recreated it without
                      problems. I don't know if I'll ever get used to Dreamweaver, but I need
                      to build a Contribute-compatible site for work, so I'm soldiering on.
                      - Kevin
                      • 8. Re: Dreaweaver only saves as template
                        Level 7
                        Good luck, Kevin.
                        news:ebqcop$5bn$1@forums.macromedia.com...
                        > Murray *ACE* wrote:
                        >> Kevin:
                        >> to save a page as a template would be if the page had template markup in
                        >> it.
                        > Thanks for that tip, Murray. I wish I'd known to look for that particular
                        > tag amongst the other Template tags. By the time I saw your message, I had
                        > already deleted the problem file and recreated it without problems. I
                        > don't know if I'll ever get used to Dreamweaver, but I need to build a
                        > - Kevin
