13 Replies Latest reply on May 24, 2011 8:45 AM by Eva-KCI
    Mini TOC does not appear
    Eva-KCI Level 1
      RoboHelp 9.0.0.228/Server 9
      WebHelp Pro
      Single Project (upgraded from RH x5 to RH9)
      The mini TOC seems to work in some, but not all topics.  In the topics where it is not working, the mini TOC placeholder appears in the Design veiw, but when the topic is viewed (eye glasses icon) or the entire project is generated and viewed, the mini TOC is not there.
      Any ideas why not?
      Thank you,
      Eva
        • 1. Re: Mini TOC does not appear
          Hi Eva
          For the topics where the Mini TOC doesn't appear to be working, do you have sections inside the topic with the beginning of the section formatted as a heading? If not, that totally explains it. Usually you have some Heading 2s or lower and that's what the placeholder keys from.
          Cheers... Rick
          Helpful and Handy Links
          RoboHelp Wish Form/Bug Reporting Form
          Begin learning RoboHelp HTML 7, 8 or 9 within the day!
          Adobe Certified RoboHelp HTML Training
          SorcerStone Blog
          RoboHelp eBooks
          • 2. Re: Mini TOC does not appear
            Eva-KCI Level 1
            Good point Rick.  Yes, the topics definitely have multi-level headers & the mini TOC settings include all the levels.
            • 4. Re: Mini TOC does not appear
              Eva-KCI Level 1
              Here's the code (most content was replaced with "TEXT").  In this example, we only have heading 1 and heading 2 applied.
              <?xml version="1.0" encoding="utf-8" ?>
              <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
              <html xmlns="http://www.w3.org/1999/xhtml">
              <head>
              <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
              <meta name="topic-check-list" content="Ran Smart Index" />
              <meta name="build tags" content="Inbound" />
              <meta name="generator" content="Adobe RoboHelp 9" />
              <title>Rebate Program</title>
              <link rel="StyleSheet" href="..\..\default.css" type="text/css" />
              </head>
              <body>
              <?rh-region_start type="header" style="width: 100%; position: relative;" ?>       <p>Last revised: TEXT </p>
              <?rh-region_end type="header" ?>
              <h1> Rebate Program</h1>
              <p>TEXT.</p>
              <p class="Note">TEXT.</p>
              <p>&#160;</p>
              <p style="text-align: center;"><span style="font-size: 11pt; font-variant: small-caps; color: #ff0000; font-weight: bold;">IMPORTANT:</span>
              <span style="font-size: 11pt; font-variant: small-caps; font-weight: bold;">Do
              not</span> <span style="font-size: 11pt; font-variant: small-caps;"> TEXT.</span></p>
              <p style="text-align: center;">&#160;</p>
              <h2>Rebate Program Overview</h2>
              <p> TEXT. &#160;&#160;</p>
              <p>&#160;</p>
              <p> TEXT <?rh-symbol_start name="Trademark" ?>™<?rh-symbol_end ?></p>
              <p>&#160;</p>
              <h2>Additional Program Details</h2>
              <ul type="disc">
                              <li class="p" style="background-color: Transparent; font-size: 10pt;"><p> TEXT <span style="font-weight: bold;"><b>TEXT</b></span> TEXT</p></li>
              </ul>
              <p class="Note"> TEXT <span
                              style="background-color: Transparent;"> TEXT </span><span
                              style="background-color: Transparent; font-weight: bold;">within</span><span
                              style="background-color: Transparent;"> TEXT <font color="#000000">rebate</font>.</span></p>
              <ul style="font-size: 10pt;" type="disc">
                              <li class="p" style="background-color: Transparent; font-size: 10pt;"><p> TEXT <span style="font-weight: bold;"><b>must</b></span>&#160; TEXT <font color="#000000">rebate</font>:</p></li>
              </ul>
              <table style="margin-left: 160px; border-collapse: separate; border-collapse: separate;"
                                              cellspacing="0" width="54.061%" border="1">
                              <col style="width: 53.109%;" />
                              <col width="181" />
                              <tr>
                                              <td><ul style="font-size: 10pt;" type="circle">
                                                              <li style="font-size: 10pt;"> TEXT *</li>
                                                              <li style="font-size: 10pt;"> TEXT </li>
                                              </ul></td>
                                              <td style="vertical-align: top;"><ul style="font-size: 10pt;" type="circle">
                                              </ul></td>
                              </tr>
                              <tr>
                                              <td colspan="2"><p style="text-align: center; font-size: 10pt;">(*)
                                              TEXT </p>
                                              <p style="text-align: center; font-size: 10pt;">&#160;the Product
                                              Placement Card.</p></td>
                                              </tr>
              </table>
                              <li class="p" style="background-color: Transparent; font-size: 10pt;"><p>Maximum
                              <font color="#000000">rebate</font> TEXT p></li>
              </ul>
              <p class="Note"> TEXT <span style="background-color: Transparent;"> TEXT.</span></p>
              <ul type="disc">
                              <li class="p" style="background-color: Transparent;"><p><font color="#000000">Rebate</font>
                              TEXT.</p></li>
              </ul>
              <p class="Note" style="background-color: Transparent;"><span><b style="font-weight: bold;">Do
              Not</b></span> TEXT.</p>
              <ul type="disc">
                              <li class="p" style="background-color: Transparent;"><p> TEXT Card <font color="#000000">Rebate</font> Program.</p></li>
              </ul>
              <p>&#160;</p>
              <h2> TEXT <span style="font-size: 12pt; color: #000000;"> TEXT </span></h2>
              <p class="Note"><span style="font-weight: bold;"> TEXT </span> TEXT.</p>
              <ol start="1" type="1">
                              <li class="p" style="font-size: 10pt;"><p> TEXT <a href="..\..\Product\Order_Handling\Product.htm"
        target="_blank"
        style="font-size: 10pt;"> TEXT </a>.</p></li>
                              <li class="p" style="font-size: 10pt;"><p> TEXT <span style="font-weight: bold;">Billing,
                              TEXT </span> TEXT</p></li>
              </ol>
              <p>&#160;</p>
              <h2>Procedure - Internal Customers <span style="font-size: 12pt; color: #000000;">(E.g.,
              KCI Reps)</span></h2>
                              <li style="font-size: 10pt;"><span> TEXT </span></li>
              </ol>
              <p>&#160;</p>
              <p>
              <!--Metadata type="DesignerControl" startspan
              <object classid="clsid:FF80F713-5DC6-11d0-A7B4-00AADC53E937" id="RelatedTopics"
                                              border="0" style="margin-top: 0px; margin-bottom: 0px; margin-left: 0px;
                                              margin-right: 0px;" align="bottom">
              <param name="_Version" value="65536"  />
              <param name="_ExtentX" value="2408"  />
              <param name="_ExtentY" value="609"  />
              <param name="_StockProps" value="13"  />
              <param name="ForeColor" value="0"  />
              <param name="BackColor" value="14215660"  />
              <param name="UseButton" value="-1"  />
              <param name="UseText" value="0"  />
              <param name="ControlLabel" value="Related Topics"  />
              <param name="UseIcon" value="0"  />
              <param name="Items" value="New KCI Products;..\..\Product\New_KCI_Products.htm$$**$$"
              <param name="Image" value=""  />
              <param name="FontInfo" value="Arial,8,0,,"  />
              <param name="_CURRENTFILEPATH" value="C:\ TEXT \Rebate_Program.htm"
              <param name="_ID" value="RelatedTopics"  />
              <param name="UseMenu" value="-1"  />
              <param name="Frame" value="_blank"  />
              <param name="Window" value=""  />
              </object>-->
              <object
                classid="clsid:ADB880A6-D8FF-11CF-9377-00AA003B7A11"
                id="RelatedTopics"  type="application/x-oleobject" >
                <param  name="Command"  value="Related Topics,MENU" />
                <param  name="Button"  value="Text:Related Topics" />
                <param  name="Font"  value="Arial,8,0,," />
                <param  name="Item1"  value="New Products;..\..\Product\New_Products.htm" />
              </object>
              <!--Metadata type="DesignerControl" endspan-->
              </p>
              <?rh-region_start type="footer" style="width: 100%; position: relative;" ?>
                              <p>Created on: 10/06/10</p>
              <?rh-region_end type="footer" ?>
              </body>
              </html>
              • 5. Re: Mini TOC does not appear
                Eva-KCI Level 1
                I have reported this to Adobe as a bug.  The mini TOC is failing to work in many of my topics.
                • 6. Re: Mini TOC does not appear
                  Hi Eva
                  The code you posted does not have a Mini-TOC placeholder in it. Normally this would appear in the HTML as so:
                  <?rh-placeholder type="minitoc"
                  How exactly are you trying to get the placeholder in there? Hopefully you do realize that you must insert the placeholder in some way in order for it to appear.
                  Cheers... Rick
                  SorcerStone Blog
                  RoboHelp eBooks
                  • 7. Re: Mini TOC does not appear
                    Eva-KCI Level 1
                    Rick,
                    Thank you so much for looking over the code I posted.  While I cannot explain why the mini TOC code is missing altogether from that topic, I did pull up a different topic where the mini TOC also fails to appear and looked for the placeholder code & it is there as such:
                    Mini TOC code
                    <?rh-placeholder type="minitoc" list-type="none" flags="7" min-heading-level="h2"
                    max-heading-level="h6" caption="In this Topic" ph-style="font-family:Arial;font-size:12pt;font-weight: normal;font-style: normal;text-decoration: none;"
                    caption-style="font-family:Arial;font-size:12pt;font-weight: normal;font-style: normal;text-decoration: none;"
                    margin=";;;" ?>
                    I'm going to Insert --> Placeholder --> Mini TOC.
                    Does this code look right?  Is there another component to this that could prevent it from working, even if the code were correct?  Maybe some project file?  or any other troubleshooting ideas?
                    Eva
                    • 8. Re: Mini TOC does not appear
                      LOL, okay that code does look correct. But now we have seen code for an entire topic that has no placeholder, and we have also seen the placeholder code separately.
                      Perhaps please try this. Use Screenr and record a small video of you looking at the topic and showing us what is what. http://www.screenr.com/
                      Cheers... Rick
                      SorcerStone Blog
                      RoboHelp eBooks
                      • 10. Re: Mini TOC does not appear
                        Hello again
                        Thanks for the video. Helps to see sometimes what is actually happening.
                        Unfortunately I only have stabs in the dark to try. These are admittedly long shots but shouldn't be difficult to try.
                        I think I'd first try removing any association with a CSS file. Just click the little notepad icon and choose none for the CSS. Test again.
                        Click Tools > Options > General and enable the option for Convert RoboHelp edited topics to HTML
                        Does the same thing happen in a totally fresh and shiny new topic?
                        Cheers... Rick
                        SorcerStone Blog
                        RoboHelp eBooks
                        • 11. Re: Mini TOC does not appear
                          Eva-KCI Level 1
                          Rick,
                          I tried what you suggested (removing CSS/marking the Convert RH topics to HTML), but no success.
                          I'm working with a project that was upgraded from RH x 5 and the issue presents itself in some, not all,  topics originally created in RH x 5.  I have not come across the issue with any new topics that were created after the upgrade to RH 9.
                          Another of your posts, unrelated to this thread, caught my attention.  In that post you suggested copying the "problem" topic to Notepad, clearing out the topic's code,  pasting the content back into the topic, and then reapplying the headings to see if the coding issues could be resolved.  I gave this a shot, but still no luck.
                          So, I know I have at least two topics that originated from RH x5...one where the mini TOC is working and the other where it is not.  I just don't know enough about coding to be able to "see" the problem even if the answer is in the code.
                          Thank you for helping!
                          Eva
                          • 12. Re: Mini TOC does not appear
                            Hello again
                            Okay, let's try this. I happen to have X5 open from an earlier test with something completely different.
                            Send me one of the actual HTML topic pages where this is happening. That way the file name will be intact.
                            Then tell me if this topic is inside a folder or not. If so, what is the path leading to the topic? My plan is to simulate as much of your project setup as I'm able to. This includes naming as well as placement on the hard drive. I'll also need to know exactly where on your hard drive the project exists at the moment.
                            My address is rstone75 (at) kc (dot) rr (dot) com
                            Cheers... Rick
                            SorcerStone Blog
                            RoboHelp eBooks
                            • 13. Re: Mini TOC does not appear
                              Eva-KCI Level 1
                              Rick figured out that special characters in the folder names seemed to prevent the mini-TOC from working.
                              So, the topics where the issue existed were filed in folders that contained special characters, like a comma or ampersand.  Removing the special characters from the folder names somehow allows the mini-TOC to work.
                              Here's an example.
                              Original Folder Name:Revised Folder Name to enable mini TOC Functionality:
                              Collections,_Credit,_&_ReturnsCollections_Credit_Returns
