4 Replies Latest reply on May 20, 2011 5:14 AM by Rohit . Kumar
    Conversion between ASObject and custom Java object
    Franekek12
      I have Java Enterprice Application with BlazeDS installed there and Flash client (created in pure Flash -not Flex). Now I want to send my custom Java object over the wire.
      On The java side i have method:
      public void echo1(Dupa dupa){
           System.out.println("--");
           System.out.println(dupa.dup);
      On the Flash side:
      var myDupa:Dupa = new Dupa();
      myDupa.dup = "www";
      var rooms:Object = remoteObject.echo1(myDupa);
      Where object's 'Dupa' definition is:
      Java:
      package test;
      public class Dupa {
           public String dup;
      Flash:
      package test {
      [Bindable]
      [RemoteClass(alias="test.Dupa")]
      public class Dupa {
            public var dup:String;
      And I always receives error:
      [FaultEvent fault=[RPC Fault faultString="Cannot invoke method 'echo1'." faultCode="Server.ResourceUnavailable" faultDetail="The expected argument types are (test.Dupa) but the supplied types were (flex.messaging.io.amf.ASObject) and converted to (null)."] messageId="2EEB750E-240E-9AE3-9AE4-284E56C81B89" type="fault" bubbles=false cancelable=true eventPhase=2]
      When i change me Java method signature to:
      public String echo2(flex.messaging.io.amf.ASObject test){...}
      Everything work fine. But it this situation I have ASObject which i have to convert to test.Dupa.
      The question is:
      How can i force Flash to convert sent content to my custom object (test.Dupa)?
      If its not possible, how can I convert ASObject object to test.Dupa (or whatever I want).
      Thx fo replies.
        • 1. Re: Conversion between ASObject and custom Java object
          Rohit . Kumar Adobe Employee
          Looks like RemoteClass tag did not have any effect. Can you try the following: Within the Dupa AS class, decare a constructor and explictly call the flash.net.registerClassAlias("test.Dupa", test.Dupa) in it.
          Rohit
          • 2. Re: Conversion between ASObject and custom Java object
            Franekek12 Level 1
            It helped! Thank You very much.
            But there is another question (or two):
                 Why the "RemoteClass" metadata is not recognized by the Flash Player?
                 Do I need some import statement in my AS class or some liberaries are missing?
            And there is another one problem. Everything work fine for this function call:
            But for this function call:
            var rooms:Dupa = remoteObject.echo1(myDupa);
            I receives this error:
            TypeError: Error #1034: Type Coercion failed: cannot convert mx.rpc::AsyncToken@2708d041 to test.Dupa.
            It means, in my opinion, that received object's type is :AsyncToken. How can i get my Dupa object from it.
            • 3. Re: Conversion between ASObject and custom Java object
              tomj Adobe Employee
              If you are not using Flex, then the hooks are not executed.
              Tom Jordahl
              • 4. Re: Conversion between ASObject and custom Java object
                The Flex compiler ultimately converts the metadata tags into AS code during compilation. In case of [RemoteClass], it rougly gets converted to the what I wrote in my earlier response.
                As regards the second question, here you can get access to the result of the RemoteObject.
                var token:AsyncToken = remoteObject.echo1(myDupa);
                token.addAsyncResponder(resultFunc, faultFunc));
                public function resultFunc(r:ResultEvent, t:Object = null) {
                      room = r.result as Room;
                public function faultFunc(f:FaultEvent, t:Object = null) {
                Rohit
