1 Reply Latest reply on May 28, 2011 10:11 AM by Shongrunden
    Flash Builder 4.0 and Flex 4.5 SDK Errors
    yavstr Level 1
      I'm having issues using 4.5 in FB 4.0
      Every time I create a new project and target 4.5 I get the following errors:
      DescriptionResourcePathLocationType
      1084: Syntax error: expecting rightbrace before csstesting
      Line 24Flex Problem
      1084: Syntax error: expecting rightbrace before end of programtesting
      Line 447Flex Problem
      1084: Syntax error: expecting rightbrace before stesting
      Line 24Flex Problem
      1093: Syntax error.testing
      Line 24Flex Problem
      1093: Syntax error: A string literal must be terminated before the line breaktesting
      Line 24
      Flex Problem
      keep in mind the is a new project targeting the 4.5 SDK in Flash Builder 4.0. I have done nothing but create the project.
      If I create the project with 4.1 SDK in Flash Builder 4.0, there are no issues.
      Can someone confirm this is an issue with using 4.5 in FB 4.0 or share a solution to resolving the issues?
      Thank you.
