3 Replies Latest reply on May 18, 2011 1:38 PM by majester8425
    HTTPService with XML format errors when XML is empty. How can I test the value ?
    majester8425 Level 1
      I have a simple HTTPService which returns XML. 99% of the time there are values and all is good with the world, however sometimes there are no values and my xml looks like this
      <?xml version="1.0" encoding="UTF-8" ?>
        <node />
      This is totally valid. How can I test for this and avoid
      ReferenceError: Error #1069: Property node not found on flash.xml.XMLNode and there is no default value.
      I have tried
      if
      Normally the xml with values look like
      (event.result.node == null)
      <node>
      -     <node label="MYLABEL1" id="231" type="O" />
            <node label="MYLABEL2" id="263" type="O" />
        </node>
