3 Replies Latest reply on May 29, 2011 3:14 AM by alexlkc28
    Try to get an array of object from phpservices.lastResult
    alexlkc28
      I developed a php service which retrevies data from a database in MySQL, the service is working properly because I setup the php service using "Data/Services" wizard. I tested the operation of the service and I can get the data using "Test operations" with the "Data/Services" tab.
      What I am trying to do is to use lastResult to get the data, but I always get null.
      Below is the code:
      private
      function Setabcd():void
      getSecondMenuItemsResult2.token = bpmpServices.getSecondMenuItems(2);
      var bcd:Array = getSecondMenuItemsResult.lastResult;
      What I am trying to do in the above code is to get the lastResult result and save to an array object.
      Please advise.
