2 Replies Latest reply on May 18, 2011 11:44 PM by Dave McGregor
    Catalyst keeps crashing
    Dave McGregor Level 1
      I am a new user of Catalyst CS5. I'm running it on my iMac i5 computer under OS10.6.7. I figured out how to use it pretty quickly and have created a couple of interesting little projects so far, although basic. So I started trying something a bit more adventurous and have run into trouble.
      At first I started getting a java heap error when attempting to Run my project. I couldn't figure out how to fix that so I started again from scratch and things have gone downhill since then. Catalyst started crashing.
      Now I can't even launch Catalyst at all. When I first go to launch, it comes up with the welcome screen giving me the option of opening a recent project etc. When I click on Open New file, a browse window opens, but then Catalyst immediately crashes. I have tried to launch it several times – the same thing keeps happening. I have tried quitting everything and restarting my computer but the problem persists.
      I also tried re-installing the software but the same thing keeps happening.
      Everything was working fine yesterday. Now it's dead and I don't know how to fix it.
      Please help!
        • 1. Re: Catalyst keeps crashing
          I followed the online trouble shooting suggestions (steps 1-4) found here: http://kb2.adobe.com/cps/832/cpsid_83223.html
          I restarted my Mac in Safe Boot Mode as they suggested. Again Catalyst crashed, this time it generated the following Problem Report:
          Process:         Adobe Flash Catalyst CS5 [177]
          Path:            /Applications/Adobe Flash Catalyst CS5/Adobe Flash Catalyst CS5.app/Contents/MacOS/Adobe Flash Catalyst CS5
          Identifier:      com.adobe.thermo
          Version:         1.0.0.273393 (1.0.0.273393)
          Code Type:       X86 (Native)
          Parent Process:  launchd [127]
          Date/Time:       2011-05-19 16:35:20.831 +1200
          OS Version:      Mac OS X 10.6.7 (10J869)
          Report Version:  6
          Interval Since Last Report:          109103 sec
          Crashes Since Last Report:           4
          Per-App Interval Since Last Report:  55274 sec
          Per-App Crashes Since Last Report:   3
          Anonymous UUID:                      351EF248-1838-40F5-9A7E-7BCCF24D0D0B
          Exception Type:  EXC_BAD_ACCESS (SIGBUS)
          Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
          Crashed Thread:  0  Dispatch queue: com.apple.main-thread
          Application Specific Information:
          Java information:
          Exception type: Bus Error (0xa) at pc=0x1820eddf
          Java VM: Java HotSpot(TM) Client VM (14.3-b01-101 mixed mode macosx-x86)
          Current thread (0x18800c00):  JavaThread "main" [_thread_in_vm, id=1860928, stack(0xbf800000,0xc0000000)]
          Stack: [0xbf800000,0xc0000000]
          Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
          j  org.eclipse.swt.internal.carbon.OS.ReceiveNextEvent(I[IDZ[I)I+0
          j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+52
          j  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptio nHandler;Lorg/eclipse/swt/widgets/Display;)V+9
          j  org.eclipse.ui.internal.Workbench.runUI()I+393
          j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
          j  org.eclipse.ui.internal.Workbench$5.run()V+23
          j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
          j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
          j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
          j  com.adobe.thermo.application.ThermoApplication.start(Lorg/eclipse/equinox/app/IApplicatio nContext;)Ljava/lang/Object;+250
          j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
          j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
          j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
          j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
          j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
          v  ~StubRoutines::call_stub
          j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
          j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
          j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
          j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
          j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
          j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
          j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
          Java Threads: ( => current thread )
            0x1f03f000 JavaThread "AWT-Shutdown" [_thread_blocked, id=-1309970432, stack(0xb1db7000,0xb1eb7000)]
            0x50850400 JavaThread "Worker-1" [_thread_blocked, id=-1317924864, stack(0xb1621000,0xb1721000)]
            0x18a80c00 JavaThread "Thread-7" [_thread_blocked, id=-1290297344, stack(0xb307a000,0xb317a000)]
            0x18a64800 JavaThread "Code Model Worker" [_thread_blocked, id=-1291354112, stack(0xb2f78000,0xb3078000)]
            0x18a63c00 JavaThread "Code Model Worker" [_thread_blocked, id=-1315811328, stack(0xb1825000,0xb1925000)]
            0x189da000 JavaThread "Thread-1" [_thread_in_native, id=-1319514112, stack(0xb149d000,0xb159d000)]
            0x189bf400 JavaThread "Worker-0" [_thread_blocked, id=-1321635840, stack(0xb1297000,0xb1397000)]
            0x18961400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=-1322692608, stack(0xb1195000,0xb1295000)]
            0x18960c00 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=-1323749376, stack(0xb1093000,0xb1193000)]
            0x1f000000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1327341568, stack(0xb0d26000,0xb0e26000)]
            0x1e801000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1328398336, stack(0xb0c24000,0xb0d24000)]
            0x1e800000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1329455104, stack(0xb0b22000,0xb0c22000)]
            0x18922400 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1330511872, stack(0xb0a20000,0xb0b20000)]
            0x18916c00 JavaThread "Finalizer" daemon [_thread_blocked, id=-1331568640, stack(0xb091e000,0xb0a1e000)]
            0x18916000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1332625408, stack(0xb081c000,0xb091c000)]
          =>0x18800c00 JavaThread "main" [_thread_in_vm, id=1860928, stack(0xbf800000,0xc0000000)]
          Other Threads:
            0x18912000 VMThread [stack: 0xb071a000,0xb081a000] [id=-1333682176]
            0x1f009000 WatcherThread [stack: 0xb0e8f000,0xb0f8f000] [id=-1325862912]
          VM state:not at safepoint (normal execution)
          VM Mutex/Monitor currently owned by a thread: None
          Heap
          par new generation   total 35328K, used 5973K [0x200c0000, 0x22820000, 0x22820000)
            eden space 30336K,  19% used [0x200c0000, 0x20695538, 0x21e60000)
            from space 4992K,   0% used [0x22340000, 0x22340000, 0x22820000)
            to   space 4992K,   0% used [0x21e60000, 0x21e60000, 0x22340000)
          concurrent mark-sweep generation total 483968K, used 10412K [0x22820000, 0x400c0000, 0x400c0000)
          concurrent-mark-sweep perm gen total 65536K, used 25963K [0x400c0000, 0x440c0000, 0x500c0000)
          Virtual Machine Arguments:
          JVM Args: -Xdock:icon=../Resources/fc_app.icns -Xdock:name=Flash Catalyst -XstartOnFirstThread -Xms512m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m -Dorg.eclipse.swt.internal.carbon.smallFonts -Dorg.eclipse.swt.internal.carbon.noFocusRing
          Java Command: <unknown>
          Launcher Type: generic
          Physical Memory: Page Size = 4k, Total = 4096M, Free = 1831M
          Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
          0   libclient.dylib                   0x1820eddf JVM_Socket + 5647
          1   libswt-carbon-3449.jnilib         0x1e7caef0 callback + 792
          2   ???                               0x1e7f899b 0 + 511674779
          3   com.apple.AppKit                  0x1972eadf -[NSNavOpenPanel _shouldShowNodeRef:] + 2087
          4   com.apple.AppKit                  0x1973044b -[NSNavOpenPanel _delegateShouldEnableNode:] + 296
          5   com.apple.AppKit                  0x194b6622 -[NSNavDataSource canChooseFileAtURL:] + 53
          6   com.apple.AppKit                  0x19771dae -[NSNavMediaBrowserDelegate mediaBrowserView:attributedDisplayNameForMediaObject:] + 67
          7   com.apple.iLifeMediaBrowser       0x6263e6b2 -[ILMediaBrowserImageKitCell drawTitle] + 191
          8   com.apple.imageKit                0x59367129 -[IKImageBrowserCell draw] + 1708
          9   com.apple.imageKit                0x5935ee4e -[IKImageBrowserView(ImageBrowserDrawing) drawVisibleCells:] + 1299
          10  com.apple.imageKit                0x5935cf02 -[IKImageBrowserView(ImageBrowserDrawing) drawWithCurrentRendererInRect:] + 341
          11  com.apple.imageKit                0x5935db12 -[IKImageBrowserView(ImageBrowserDrawing) drawRect:] + 761
          12  com.apple.AppKit                  0x1911d82a -[NSView _drawRect:clip:] + 3510
          13  com.apple.AppKit                  0x1911c4c8 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1600
          14  com.apple.AppKit                  0x1911c7fd -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2421
          15  com.apple.AppKit                  0x1911c7fd -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2421
          16  com.apple.AppKit                  0x1911c7fd -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2421
          17  com.apple.AppKit                  0x1911c7fd -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2421
          18  com.apple.AppKit                  0x1911c7fd -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2421
          19  com.apple.AppKit                  0x1911a9e7 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 711
          20  com.apple.AppKit                  0x1911b9c3 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4771
          21  com.apple.AppKit                  0x1911b9c3 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4771
          22  com.apple.AppKit                  0x1911b9c3 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4771
          23  com.apple.AppKit                  0x1911b9c3 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4771
          24  com.apple.AppKit                  0x1911b9c3 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4771
          25  com.apple.AppKit                  0x1911b9c3 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4771
          26  com.apple.AppKit                  0x1911a55b -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 265
          27  com.apple.AppKit                  0x19116ea2 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 3309
          28  com.apple.AppKit                  0x19077a57 -[NSView displayIfNeeded] + 818
          29  com.apple.AppKit                  0x19040d40 -[NSWindow displayIfNeeded] + 204
          30  com.apple.AppKit                  0x1907228a _handleWindowNeedsDisplay + 696
          31  com.apple.CoreFoundation          0x002bde02 __CFRunLoopDoObservers + 1186
          32  com.apple.CoreFoundation          0x00279d8d __CFRunLoopRun + 557
          33  com.apple.CoreFoundation          0x00279464 CFRunLoopRunSpecific + 452
          34  com.apple.CoreFoundation          0x00279291 CFRunLoopRunInMode + 97
          35  com.apple.HIToolbox               0x00514e04 RunCurrentEventLoopInMode + 392
          36  com.apple.HIToolbox               0x00514af5 ReceiveNextEventCommon + 158
          37  com.apple.HIToolbox               0x0069d137 ReceiveNextEvent + 83
          38  libswt-pi-carbon-3449.jnilib      0x1f818d38 Java_org_eclipse_swt_internal_carbon_OS_ReceiveNextEvent + 188
          39  ???                               0x1a10b839 0 + 437303353
          40  ???                               0x1a103ed5 0 + 437272277
          41  ???                               0x1a103fdd 0 + 437272541
          42  ???                               0x1a103db1 0 + 437271985
          43  ???                               0x1a103ed5 0 + 437272277
          44  ???                               0x1a103ed5 0 + 437272277
          45  ???                               0x1a10428d 0 + 437273229
          46  ???                               0x1a103db1 0 + 437271985
          47  ???                               0x1a103ed5 0 + 437272277
          48  ???                               0x1a103ed5 0 + 437272277
          49  ???                               0x1a1043f3 0 + 437273587
          50  ???                               0x1a1043f3 0 + 437273587
          51  ???                               0x1a103f17 0 + 437272343
          52  ???                               0x1a103f17 0 + 437272343
          53  ???                               0x1a103f17 0 + 437272343
          54  ???                               0x1a1012d3 0 + 437261011
          55  libclient.dylib                   0x181a57d0 JVM_Lseek + 149024
          56  libclient.dylib                   0x181a5576 JVM_Lseek + 148422
          57  libclient.dylib                   0x181a5546 JVM_Lseek + 148374
          58  libclient.dylib                   0x181c7fe8 JVM_NewInstanceFromConstructor + 3896
          59  libclient.dylib                   0x181c9bde JVM_InvokeMethod + 1342
          60  libclient.dylib                   0x181c9892 JVM_InvokeMethod + 498
          61  libjava.jnilib                    0x1855416a Java_sun_reflect_NativeMethodAccessorImpl_invoke0 + 38
          62  ???                               0x1a10b839 0 + 437303353
          63  ???                               0x1a103f17 0 + 437272343
          64  ???                               0x1a103f17 0 + 437272343
          65  ???                               0x1a1043f3 0 + 437273587
          66  ???                               0x1a103f17 0 + 437272343
          67  ???                               0x1a103db1 0 + 437271985
          68  ???                               0x1a103db1 0 + 437271985
          69  ???                               0x1a1012d3 0 + 437261011
          70  libclient.dylib                   0x181a57d0 JVM_Lseek + 149024
          71  libclient.dylib                   0x181a5576 JVM_Lseek + 148422
          72  libclient.dylib                   0x181a5546 JVM_Lseek + 148374
          73  libclient.dylib                   0x181bb230 JVM_MonitorWait + 15088
          74  libclient.dylib                   0x18209a54 JVM_EnableCompiler + 8404
          75  eclipse_1117.so                   0x04f0e473 startJavaJNI + 1725
          76  eclipse_1117.so                   0x04f0ce81 startJavaVM + 382
          77  eclipse_1117.so                   0x04f0bef0 run + 4742
          78  com.adobe.thermo                  0x0000218e original_main + 1782
          79  com.adobe.thermo                  0x0000287a main + 1517
          80  com.adobe.thermo                  0x000018e2 start + 54
          Thread 1:  Dispatch queue: com.apple.libdispatch-manager
          0   libSystem.B.dylib                 0x00033922 kevent + 10
          1   libSystem.B.dylib                 0x0003403c _dispatch_mgr_invoke + 215
          2   libSystem.B.dylib                 0x000334f9 _dispatch_queue_invoke + 163
          3   libSystem.B.dylib                 0x0003329e _dispatch_worker_thread2 + 240
          4   libSystem.B.dylib                 0x00032d21 _pthread_wqthread + 390
          5   libSystem.B.dylib                 0x00032b66 start_wqthread + 30
          Thread 2:  Java: Exception Handler Thread
          0   libSystem.B.dylib                 0x0000d09a mach_msg_trap + 10
          1   libSystem.B.dylib                 0x0000d807 mach_msg + 68
          2   libSystem.B.dylib                 0x00079078 mach_msg_server + 520
          3   libclient.dylib                   0x1810fe25 JNI_CreateJavaVM_Impl + 61045
          4   libclient.dylib                   0x1810fdca JNI_CreateJavaVM_Impl + 60954
          5   libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          6   libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          7   libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 3:  Java: Gang worker#0 (Parallel GC Threads)
          2   libclient.dylib                   0x1810ef23 JNI_CreateJavaVM_Impl + 57203
          3   libclient.dylib                   0x1810edab JNI_CreateJavaVM_Impl + 56827
          4   libclient.dylib                   0x1810e928 JNI_CreateJavaVM_Impl + 55672
          5   libclient.dylib                   0x1810e588 JNI_CreateJavaVM_Impl + 54744
          6   libclient.dylib                   0x18124931 jio_vsnprintf + 321
          7   libclient.dylib                   0x1812486a jio_vsnprintf + 122
          8   libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          9   libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          10  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 4:  Java: Gang worker#1 (Parallel GC Threads)
          Thread 5:  Java: Gang worker#2 (Parallel GC Threads)
          Thread 6:  Java: Gang worker#3 (Parallel GC Threads)
          Thread 7:  Java: Concurrent Mark-Sweep GC Thread
          2   libclient.dylib                   0x1810f037 JNI_CreateJavaVM_Impl + 57479
          3   libclient.dylib                   0x1812bbb0 jio_vsnprintf + 29632
          4   libclient.dylib                   0x1810e9b7 JNI_CreateJavaVM_Impl + 55815
          6   libclient.dylib                   0x181e8b8c JVM_Available + 29852
          7   libclient.dylib                   0x1812b992 jio_vsnprintf + 29090
          Thread 8:  Java: VM Thread
          6   libclient.dylib                   0x181a3f5b JVM_Lseek + 142763
          7   libclient.dylib                   0x181a3c8a JVM_Lseek + 142042
          Thread 9:  Java: Reference Handler
          4   libclient.dylib                   0x181b8c95 JVM_MonitorWait + 5461
          5   libclient.dylib                   0x181b7bfe JVM_MonitorWait + 1214
          6   libclient.dylib                   0x181b787a JVM_MonitorWait + 314
          7   ???                               0x1a10b839 0 + 437303353
          9   ???                               0x1a103db1 0 + 437271985
          10  ???                               0x1a1012d3 0 + 437261011
          11  libclient.dylib                   0x181a57d0 JVM_Lseek + 149024
          12  libclient.dylib                   0x181a5576 JVM_Lseek + 148422
          13  libclient.dylib                   0x181b711b JVM_InternString + 2123
          14  libclient.dylib                   0x181b6f8a JVM_InternString + 1722
          15  libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          16  libclient.dylib                   0x181b680f JVM_StartThread + 2175
          17  libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          18  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          19  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 10:  Java: Finalizer
          8   ???                               0x1a208de4 0 + 438341092
          9   ???                               0x1a208a94 0 + 438340244
          10  ???                               0x1a103f17 0 + 437272343
          11  ???                               0x1a1012d3 0 + 437261011
          12  libclient.dylib                   0x181a57d0 JVM_Lseek + 149024
          13  libclient.dylib                   0x181a5576 JVM_Lseek + 148422
          14  libclient.dylib                   0x181b711b JVM_InternString + 2123
          15  libclient.dylib                   0x181b6f8a JVM_InternString + 1722
          16  libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          17  libclient.dylib                   0x181b680f JVM_StartThread + 2175
          18  libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          19  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          20  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 11:  Java: Surrogate Locker Thread (CMS)
          5   libclient.dylib                   0x1810e4a9 JNI_CreateJavaVM_Impl + 54521
          6   libclient.dylib                   0x181ce097 JVM_IsPrimitiveClass + 7639
          7   libclient.dylib                   0x181cdc11 JVM_IsPrimitiveClass + 6481
          8   libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          9   libclient.dylib                   0x181b680f JVM_StartThread + 2175
          10  libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          11  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          12  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 12:  Java: Signal Dispatcher
          0   libSystem.B.dylib                 0x0000d0d6 semaphore_wait_trap + 10
          1   libclient.dylib                   0x181ceb5e JVM_IsPrimitiveClass + 10398
          2   libclient.dylib                   0x181ce92e JVM_IsPrimitiveClass + 9838
          3   libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          4   libclient.dylib                   0x181b680f JVM_StartThread + 2175
          Thread 13:  Java: CompilerThread0
          6   libclient.dylib                   0x181cfec2 JVM_IsPrimitiveClass + 15362
          7   libclient.dylib                   0x181cfc9b JVM_IsPrimitiveClass + 14811
          Thread 14:  Java: Low Memory Detector
          6   libclient.dylib                   0x181d3e32 JVM_IsPrimitiveClass + 31602
          7   libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          8   libclient.dylib                   0x181b680f JVM_StartThread + 2175
          9   libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          10  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          11  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 15:  Java: VM Periodic Task Thread
          3   libclient.dylib                   0x181d510d JVM_IsPrimitiveClass + 36429
          4   libclient.dylib                   0x181d4cb3 JVM_IsPrimitiveClass + 35315
          Thread 16:  Java: Framework Event Dispatcher
          Thread 17:  Java: Start Level Event Dispatcher
          Thread 18:  Java: Worker-0
          4   libclient.dylib                   0x181b88a8 JVM_MonitorWait + 4456
          Thread 19:
          0   libSystem.B.dylib                 0x0003b046 __semwait_signal + 10
          1   libSystem.B.dylib                 0x00066ec5 nanosleep$UNIX2003 + 188
          2   libBridgeTalk.jnilib              0x1fd97d8b ScObjects::Thread::sleep(unsigned int) + 59
          3   libBridgeTalk.jnilib              0x1fd91f33 ScObjects::BridgeTalkThread::run() + 163
          4   libBridgeTalk.jnilib              0x1fd97e98 ScObjects::Thread::go(void*) + 168
          5   libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          6   libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 20:  Java: Thread-1
          2   libBridgeTalk.jnilib              0x1fd799fb mysleep(unsigned long) + 59
          3   libBridgeTalk.jnilib              0x1fd7a3ac Java_com_adobe_flexide_nativelibs_BridgeTalk_WaitForMessages + 124
          4   ???                               0x1a10b839 0 + 437303353
          5   ???                               0x1a103db1 0 + 437271985
          6   ???                               0x1a1012d3 0 + 437261011
          7   libclient.dylib                   0x181a57d0 JVM_Lseek + 149024
          8   libclient.dylib                   0x181a5576 JVM_Lseek + 148422
          9   libclient.dylib                   0x181b711b JVM_InternString + 2123
          10  libclient.dylib                   0x181b6f8a JVM_InternString + 1722
          11  libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          12  libclient.dylib                   0x181b680f JVM_StartThread + 2175
          13  libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          14  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          15  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 21:
          0   libSystem.B.dylib                 0x0000d0e2 semaphore_wait_signal_trap + 10
          1   libSystem.B.dylib                 0x0003ac9c _pthread_cond_wait + 1089
          2   libSystem.B.dylib                 0x0008345f pthread_cond_wait + 48
          3   com.adobe.amt.services            0x500e5126 AMTConditionLock::LockWhenCondition(int) + 46
          4   com.adobe.amt.services            0x500dddb0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
          5   com.adobe.amt.services            0x500e518c AMTThread::Worker(void*) + 24
          Thread 22:  Java: Code Model Worker
          3   libclient.dylib                   0x1825e2b0 JVM_ResolveClass + 2672
          4   libclient.dylib                   0x1825dc7d JVM_ResolveClass + 1085
          5   ???                               0x1a10b839 0 + 437303353
          8   ???                               0x1a10428d 0 + 437273229
          11  ???                               0x1a10428d 0 + 437273229
          12  ???                               0x1a1012d3 0 + 437261011
          13  libclient.dylib                   0x181a57d0 JVM_Lseek + 149024
          14  libclient.dylib                   0x181a5576 JVM_Lseek + 148422
          15  libclient.dylib                   0x181b711b JVM_InternString + 2123
          16  libclient.dylib                   0x181b6f8a JVM_InternString + 1722
          17  libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          18  libclient.dylib                   0x181b680f JVM_StartThread + 2175
          19  libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          20  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          21  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 23:  Java: Code Model Worker
          Thread 24:  Java: Thread-7
          3   libclient.dylib                   0x181d4fce JVM_IsPrimitiveClass + 36110
          4   libclient.dylib                   0x1821a223 JVM_Sleep + 403
          7   ???                               0x1a10428d 0 + 437273229
          8   ???                               0x1a1012d3 0 + 437261011
          9   libclient.dylib                   0x181a57d0 JVM_Lseek + 149024
          10  libclient.dylib                   0x181a5576 JVM_Lseek + 148422
          11  libclient.dylib                   0x181b711b JVM_InternString + 2123
          12  libclient.dylib                   0x181b6f8a JVM_InternString + 1722
          13  libclient.dylib                   0x181b6d74 JVM_InternString + 1188
          14  libclient.dylib                   0x181b680f JVM_StartThread + 2175
          15  libclient.dylib                   0x1810e33b JNI_CreateJavaVM_Impl + 54155
          16  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          17  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 25:
          3   com.adobe.adobeswfl               0x57aedd5f APXGetHostAPI + 2567887
          4   com.adobe.adobeswfl               0x5788f1ef APXGetHostAPI + 82783
          5   com.adobe.adobeswfl               0x57aede4c APXGetHostAPI + 2568124
          6   com.adobe.adobeswfl               0x57aedeb7 APXGetHostAPI + 2568231
          7   com.adobe.adobeswfl               0x57aedf9b APXGetHostAPI + 2568459
          Thread 26:
          Thread 27:
          Thread 28:
          Thread 29:
          0   libSystem.B.dylib                 0x0000d0fa semaphore_timedwait_signal_trap + 10
          1   libSystem.B.dylib                 0x0003ac85 _pthread_cond_wait + 1066
          2   libSystem.B.dylib                 0x00069aa8 pthread_cond_timedwait_relative_np + 47
          3   com.adobe.adobeswfl               0x57aedd27 APXGetHostAPI + 2567831
          4   com.adobe.adobeswfl               0x57c630d8 APXGetHostAPI + 4096584
          Thread 30:
          4   com.adobe.adobeswfl               0x57b086de APXGetHostAPI + 2676814
          Thread 31:
          1   libSystem.B.dylib                 0x0003ad02 _pthread_cond_wait + 1191
          2   libSystem.B.dylib                 0x0003c998 pthread_cond_wait$UNIX2003 + 73
          3   ...ple.CoreServices.CarbonCore    0x00d5148e TSWaitOnCondition + 126
          4   ...ple.CoreServices.CarbonCore    0x00d3ce15 TSWaitOnConditionTimedRelative + 202
          5   ...ple.CoreServices.CarbonCore    0x00d387e3 MPWaitOnQueue + 250
          6   AdobeACE                          0x5c6956f1 0x5c65b000 + 239345
          7   AdobeACE                          0x5c6950ed 0x5c65b000 + 237805
          8   ...ple.CoreServices.CarbonCore    0x00d1c7ca PrivateMPEntryPoint + 68
          Thread 32:
          Thread 33:
          Thread 34:  Java: Worker-1
          Thread 35:
          2   com.apple.CoreFoundation          0x0027a37f __CFRunLoopRun + 2079
          5   com.apple.Foundation              0x01f2e6f4 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
          6   com.apple.Foundation              0x01ef5ad0 -[NSThread main] + 45
          7   com.apple.Foundation              0x01ef5a80 __NSThread__main__ + 1499
          Thread 36:  com.apple.CFSocket.private
          0   libSystem.B.dylib                 0x0002c066 select$DARWIN_EXTSN + 10
          1   com.apple.CoreFoundation          0x002b9c83 __CFSocketManager + 1091
          2   libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          3   libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 37:
          4   com.apple.CoreFoundation          0x0027f3a4 CFRunLoopRun + 84
          5   com.apple.DesktopServices         0x04537c7d TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
          6   ...ple.CoreServices.CarbonCore    0x00d1c7ca PrivateMPEntryPoint + 68
          7   libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          8   libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 38:
          0   libSystem.B.dylib                 0x000329b2 __workq_kernreturn + 10
          1   libSystem.B.dylib                 0x00032f48 _pthread_wqthread + 941
          2   libSystem.B.dylib                 0x00032b66 start_wqthread + 30
          Thread 39:
          Thread 40:
          Thread 41:
          3   com.apple.Foundation              0x01f1d8a8 -[NSCondition wait] + 316
          4   com.apple.Foundation              0x01f0b3a1 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 1111
          5   com.apple.Foundation              0x01f0af43 -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:modes:] + 92
          6   com.apple.imageKit                0x5934cc6b -[_IKIRLMainProxy forwardInvocation:] + 121
          7   com.apple.CoreFoundation          0x002b7cd4 ___forwarding___ + 1108
          8   com.apple.CoreFoundation          0x002b7802 _CF_forwarding_prep_0 + 50
          9   com.apple.imageKit                0x59364900 -[IKImageBrowserView(ImageBrowserImport) startScrollPrefetchTask] + 545
          10  com.apple.imageKit                0x59403c30 -[IKTaskManager taskLoop] + 2030
          11  com.apple.Foundation              0x01ef5ad0 -[NSThread main] + 45
          12  com.apple.Foundation              0x01ef5a80 __NSThread__main__ + 1499
          13  libSystem.B.dylib                 0x0003a7fd _pthread_start + 345
          14  libSystem.B.dylib                 0x0003a682 thread_start + 34
          Thread 42:
          3   ...ple.CoreServices.CarbonCore    0x00d3ce3d TSWaitOnConditionTimedRelative + 242
          4   ...ple.CoreServices.CarbonCore    0x00d3cb7b TSWaitOnSemaphoreCommon + 511
          5   ...ickTimeComponents.component    0x650c7591 ReadSchedulerThreadEntryPoint + 4698
          Thread 43:
          5   ...ple.CoreServices.CarbonCore    0x00d976ee AIOFileThread(void*) + 1127
          Thread 44:
          3   com.apple.vImage                  0x032866ec vImageQueue_DequeueJob + 44
          4   com.apple.vImage                  0x032867ec vImageWorkerThreadFunc + 124
          Thread 45:
          Thread 46:
          Thread 47:  Java: AWT-Shutdown
          10  ???                               0x1a10428d 0 + 437273229
          Thread 48:
          Thread 49:
          Thread 0 crashed with X86 Thread State (32-bit):
            eax: 0x1851b760  ebx: 0x1e7cabe4  ecx: 0x00000000  edx: 0x18800d10
            edi: 0x00000000  esi: 0x18800c00  ebp: 0xbfffb138  esp: 0xbfffb0c0
             ss: 0x0000001f  efl: 0x00010246  eip: 0x1820eddf   cs: 0x00000017
             ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
            cr2: 0x00000000
          Binary Images:
              0x1000 -     0x3fff +com.adobe.thermo 1.0.0.273393 (1.0.0.273393) <46DE9F3A-6DC7-B864-B60A-DCF332BAB5A4> /Applications/Adobe Flash Catalyst CS5/Adobe Flash Catalyst CS5.app/Contents/MacOS/Adobe Flash Catalyst CS5
              0x9000 -     0x9ff7  com.apple.Carbon 150 (152) <BFDDA394-0F01-A3A3-A226-ED3A45975A56> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
              0xc000 -   0x1b3ff7  libSystem.B.dylib 125.2.10 (compatibility 1.0.0) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
            0x235000 -   0x235ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
            0x23d000 -   0x3b8fe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x4b0000 -   0x4b0ff7  com.apple.ApplicationServices 38 (38) <EAF1BC8C-4FD4-4300-B8F7-4B24E49125E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
            0x4b8000 -   0x4c2fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <DE0E0EF6-8190-3F65-6BDD-5AC9D8A025D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
            0x4ca000 -   0x4d0fff  com.apple.CommonPanels 1.2.4 (91) <CE92759E-865E-8A3B-1488-ECD497E4074D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
            0x4d8000 -   0x4dbffb  com.apple.help 1.3.1 (41) <6A5AD406-9D8E-5BAC-51E1-E09AB9A6D159> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
            0x4e0000 -   0x804fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0x944000 -   0x9a8fff  com.apple.htmlrendering 72 (1.1.4) <0D22B190-513B-7FF6-39FC-9D336285DE08> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
            0x9ca000 -   0x9dffff  com.apple.ImageCapture 6.0.2 (6.0.2) <E9F4B952-27A1-5BFC-CA8D-DADA055D30E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
            0x9f5000 -   0xaa3ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
            0xacd000 -   0xb10ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
            0xb39000 -   0xb55fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
            0xb65000 -   0xb67ff7  com.apple.securityhi 4.0 (36638) <FC01BFC4-04DB-96F3-2412-A86CC4F94CB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
            0xb6c000 -   0xb76ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
            0xb7f000 -   0xbf9fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <D7B75C1C-1D52-19B6-2801-2F9D9911681F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
            0xc2b000 -   0xc95fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
            0xcf0000 -   0xcf3fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
            0xcf6000 -  0x1016ff3  com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x108c000 -  0x1136fe7  com.apple.CFNetwork 454.11.12 (454.11.12) <BE832CCE-B692-F55F-F5F8-3973649AFEA1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
          0x119a000 -  0x11defe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x1205000 -  0x12d0fef  com.apple.CoreServices.OSServices 359 (359) <EC340F74-8192-C9DD-40B3-AE4E519A38D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x132f000 -  0x13affeb  com.apple.SearchKit 1.3.0 (1.3.0) <7AE32A31-2B8E-E271-C03A-7A0F7BAFC85C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x13e3000 -  0x1416ff7  com.apple.AE 496.4 (496.4) <C73D124C-C722-41D8-3465-4CE0D0BA9307> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x142e000 -  0x14cbfe3  com.apple.LaunchServices 362.2 (362.2) <77B97C8B-321D-46A2-1DB5-388E45DFBC9F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x150a000 -  0x1530ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x1546000 -  0x15a3ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x15c3000 -  0x1745fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D375C1CF-C88D-C5F6-3C49-CD429023FBAC> /usr/lib/libicucore.A.dylib
          0x17a7000 -  0x17b0ff7  com.apple.DiskArbitration 2.3 (2.3) <6AA6DDF6-AFC3-BBDB-751A-64AE3580A49E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x17ba000 -  0x17cefe7  libbsm.0.dylib ??? (???) <B328FA0A-899C-4FC4-F2AC-2FDC08819CD2> /usr/lib/libbsm.0.dylib
          0x17d7000 -  0x17e4ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x17ed000 -  0x189afe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <C8925910-B927-968B-4B71-D83A4CEF8646> /usr/lib/libobjc.A.dylib
          0x18ae000 -  0x18bcfe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
          0x18c1000 -  0x18cdff7  libkxld.dylib ??? (???) <585F0A91-EFB8-E066-BDFB-4AFF37A8C323> /usr/lib/system/libkxld.dylib
          0x18d1000 -  0x1917ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
          0x1924000 -  0x1b89feb  com.apple.security 6.1.1 (37594) <251BA05D-6F3D-F687-77C2-15E52539F308> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x1c66000 -  0x1d1ffe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
          0x1d2d000 -  0x1d6aff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x1d87000 -  0x1dafff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <12FBE8CB-CC8E-FE8A-7362-C852625C5AAF> /usr/lib/libxslt.1.dylib
          0x1dba000 -  0x1ebbfe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
          0x1edf000 -  0x2152fe7  com.apple.Foundation 6.6.6 (751.53) <C73FDD37-000B-C505-FD8D-80D1C9D17965> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x2261000 -  0x2a50557  com.apple.CoreGraphics 1.545.0 (???) <8A4CB0D9-1001-0F62-4DA4-B8AB3B45E226> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
          0x2b18000 -  0x2cd2feb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C96F11A7-2569-3037-C4C3-0342708FA3CB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
          0x2d2c000 -  0x2d8dfe7  com.apple.CoreText 3.151.8 (???) <6F5D6C49-4693-B9B7-6612-832E8F155747> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
          0x2dc5000 -  0x2e60ff7  com.apple.ApplicationServices.ATS 4.4 (???) <FD63F92B-8DDE-4DBA-A7A5-0294E3607083> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x2e87000 -  0x2f43fff  com.apple.ColorSync 4.6.6 (4.6.6) <D00B95AE-2379-CB8E-B18C-FF5B66741C23> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x2f7a000 -  0x2fcbff7  com.apple.HIServices 1.8.2 (???) <63B29FF5-7077-8317-E710-2D94ADF7B499> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x2ff6000 -  0x3007ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x3014000 -  0x30bcffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x30e9000 -  0x30fdffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <9F5CE4F7-D05C-8C14-4B76-E43D07A8A680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x310b000 -  0x310bff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x310e000 -  0x3157fe7  libTIFF.dylib ??? (???) <5CE284EC-F637-EDBB-FDB3-61E86407CBB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
          0x3162000 -  0x3166ff7  libGIF.dylib ??? (???) <447BC6E8-4C56-3D5D-983B-6BEA0D26F319> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
          0x316b000 -  0x3186ff7  libPng.dylib ??? (???) <65E824F7-523A-CC34-ABDD-2A3B12DE1CA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
          0x318e000 -  0x3190ff7  libRadiance.dylib ??? (???) <B83179D4-E41C-D2BA-1E4C-A64CB45C15E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
          0x3194000 -  0x31b8ff7  libJPEG.dylib ??? (???) <A50127EB-C202-0436-E62D-41E2E893E436> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
          0x31bf000 -  0x329ffe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x32ad000 -  0x32adff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x32b0000 -  0x32f2ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x32fb000 -  0x336aff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x3373000 -  0x3789ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <9D89FCB3-24C9-8FCF-DB49-27B184AC3222> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x37cb000 -  0x3c00ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <4D2F47EF-BD32-1E3C-6A0A-438896ADE2BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x3d86000 -  0x3e8afe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
          0x3edc000 -  0x3eddff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x3ee1000 -  0x3f98feb  libFontParser.dylib ??? (???) <DDBBB503-5289-2E2B-AD35-F3BA00D00D5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x4028000 -  0x4061ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <90C5DE81-1BEF-D807-A898-0FC19BDD14EC> /usr/lib/libcups.2.dylib
          0x406e000 -  0x408efe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <BF7FF2F6-5FD3-D78F-77BC-9E2CB2A5E309> /usr/lib/libresolv.9.dylib
          0x4098000 -  0x40dcff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x40fb000 -  0x4466ff7  com.apple.QuartzCore 1.6.3 (227.36) <8E927524-EB0A-D5BA-C2E4-FA26FE4C428A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x4536000 -  0x4610ffb  com.apple.DesktopServices 1.5.10 (1.5.10) <2BA08DD4-35A2-A0FF-ADEA-B381F0CEEB81> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x465b000 -  0x4797ff7  com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <781018FB-474B-E09C-D419-5BFF80590A10> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x4807000 -  0x4857ff7  com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x486f000 -  0x4881ff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <D4BA36E6-3B6F-2796-0758-8473600CBF5B> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x488e000 -  0x48adff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x48c4000 -  0x48d2ff7  com.apple.opengl 1.6.12 (1.6.12) <81AEF74E-E33A-B021-9CDB-6199104105FF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x48da000 -  0x490bff7  libGLImage.dylib ??? (???) <1AF72191-087A-5D75-B3B9-3F537315F635> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x4913000 -  0x4934fe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x493d000 -  0x4941ff7  IOSurface ??? (???) <F9E6DFC1-8DD9-7C7E-CA85-B80735586E05> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x4949000 -  0x498cff7  libGLU.dylib ??? (???) <2C7B2727-26F6-F29D-9D15-33044E87359F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x499a000 -  0x49a5ff7  libGL.dylib ??? (???) <4425B9AA-B494-A336-EABB-6BBC9FF4EC4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x49b4000 -  0x4ac0ff7  libGLProgrammability.dylib ??? (???) <2D172B4E-432F-D18E-EA99-3BD56DBE7649> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x4adf000 -  0x4ae2ff7  libCoreVMClient.dylib ??? (???) <12EF6056-7AC7-6691-75A2-BD0675C56A35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x4ae7000 -  0x4aebff7  libGFXShared.dylib ??? (???) <4F2199F0-320F-0B59-0380-D3131D644CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x4af0000 -  0x4af1ff7  com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <253E9552-5CEA-0D5A-1EDA-3B8F669B79EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x4af6000 -  0x4af6ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
          0x4af9000 -  0x4b7bffb  SecurityFoundation ??? (???) <BFE377A4-C830-3ECA-E69F-8A8094CDA0A6> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x4bb2000 -  0x4bb7ff7  com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x4bbf000 -  0x4bc5fe7  com.apple.CommerceCore 1.0 (9) <928FCA4F-1366-AE18-CF67-87C79F5DAC21> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
          0x4bcc000 -  0x4be4ff7  com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x4bf5000 -  0x4c42feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
          0x4c5e000 -  0x4c80fef  com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x4c8a000 -  0x4c9aff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <E276514D-394B-2FDD-6264-07A444AA6A4E> /usr/lib/libsasl2.2.dylib
          0x4f09000 -  0x4f11ffe +eclipse_1117.so ??? (???) <5F5FE7EA-E629-F116-6E09-EB5430AF7F6E> /Applications/Adobe Flash Catalyst CS5/plugins/org.eclipse.equinox.launcher.carbon.macosx_1.0.100.v20080509-1800/eclipse_111 7.so
          0x4f6f000 -  0x4f7aff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <4560936D-7730-5DD2-BFD7-95270DDC210A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
          0x4f87000 -  0x4fc2feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistry.dylib
          0x4fdd000 -  0x4fe0ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B84D7376-EE9C-2B7F-04FA-D622E2C10CA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
          0x4feb000 -  0x4ff2ff7  com.apple.JavaVM 13.1.0 (13.1.0) <3B30FB82-8722-89DE-9D60-DBE6A712BCB1> /System/Library/Frameworks/JavaVM.framework/JavaVM
          0x6f00000 -  0x6f33ffb  libTrueTypeScaler.dylib ??? (???) <574C2C51-65EC-7D2A-086D-C9312287DE22> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libTrueTypeScaler.dylib
          0x6f3f000 -  0x6f80ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <95079B56-0B7B-F114-5C43-5220DBE0FBB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
          0x6fa9000 -  0x6fb1ff7  libverify.dylib 1.0 (1.0) <15F0B7E3-71D9-551D-1412-E59199DCA88D> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libverify.dylib
          0x6fb6000 -  0x6fbdff7  JavaNativeFoundation ??? (???) <2164E3F3-7CB7-B645-41F7-A6691A412F6D> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
          0x6fc6000 -  0x6fc6ff7  com.apple.Cocoa 6.6 (???) <5A785062-1ABB-2A54-BAAC-8FEF95275E05> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x6fc9000 -  0x6fc9ff7  liblangid.dylib ??? (???) <FCC37057-CDD7-2AF1-21AF-52A06C4048FF> /usr/lib/liblangid.dylib
          0x17fdb000 - 0x17fe7ff7  libzip.jnilib ??? (???) <7F0A06C0-FD89-6BE5-566C-464E89D0B179> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libzip.jnilib
          0x18100000 - 0x184f6fe7  libclient.dylib ??? (???) <8BEB6302-DB94-A680-93E0-79CAFAAD5411> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
          0x1854e000 - 0x1856bff7  libjava.jnilib ??? (???) <85448DE0-70B4-4118-EB91-DAE7F57B3CF3> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjava.jnilib
          0x19000000 - 0x198e0ff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x19d79000 - 0x19ea7fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x1decb000 - 0x1ded8ff7  libnet.jnilib ??? (???) <5DF6A0A1-A3A7-9D9D-DF74-EED603918BA3> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnet.jnilib
          0x1dede000 - 0x1dee1ff7  libnio.jnilib ??? (???) <4C4037DB-4790-E2D9-B054-9ECB7CC3E330> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnio.jnilib
          0x1e354000 - 0x1e355ff7  ATSHI.dylib ??? (???) <56F243F1-C341-86EA-2BCC-31E75D46EBBC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
          0x1e7c8000 - 0x1e7caff7 +libswt-carbon-3449.jnilib ??? (???) <696A09DF-02B0-6FB7-680A-B307A11C3846> /Users/davemcgregor/Library/Application Support/Adobe/Flash Catalyst/configuration/org.eclipse.osgi/bundles/206/1/.cp/libswt-carbon-3449.jnilib
          0x1f800000 - 0x1f836ff7 +libswt-pi-carbon-3449.jnilib ??? (???) <A0F09B13-F884-F8AA-46A8-EBF0A4DE941F> /Users/davemcgregor/Library/Application Support/Adobe/Flash Catalyst/configuration/org.eclipse.osgi/bundles/206/1/.cp/libswt-pi-carbon-3449.jnilib
          0x1fa27000 - 0x1fc03ffb  libType1Scaler.dylib ??? (???) <494D1BE1-8395-9A53-1224-1CFD4236D40E> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libType1Scaler.dylib
          0x1fd78000 - 0x1fdb7ffb +libBridgeTalk.jnilib ??? (???) <14711AF1-E7C3-A69A-4279-3F802D34705F> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libBridgeTalk.jnilib
          0x1fdd9000 - 0x1fe49feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/adobe_caps.framework/ado be_caps
          0x1fe58000 - 0x1fe5afff +libAMT_JNILib.jnilib ??? (???) <048B3F3C-85C5-483A-B3F5-A6CFC6A1D236> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/x86/libAMT_JNILib.jnilib
          0x1fe60000 - 0x1fec6ffb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/amtlib.framework/Vers ions/A/amtlib
          0x1fef6000 - 0x1ffabfe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
          0x20000000 - 0x20098fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x500c0000 - 0x50127fea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/amtservices.framework /Versions/A/amtservices
          0x50166000 - 0x501d6feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/adobe_caps.framework/ Versions/A/adobe_caps
          0x501e4000 - 0x501ecfff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/asneu.framework/Versi ons/A/asneu
          0x501fc000 - 0x50235ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <C64CCBDC-B8E9-45E8-53E7-8577CFE9F2F0> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/UpdaterNotifications. framework/Versions/A/UpdaterNotifications
          0x50371000 - 0x50383fff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePIP.framework/Adobe PIP
          0x50390000 - 0x50398ff7  com.apple.iLMBAperturePlugin 2.5.4 (252.1.7) <BCA944B7-8F84-F8C5-798A-34C05D5B10A0> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBAperturePlugin.ilmbplugin/Contents/MacOS/iLMBApert urePlugin
          0x5039f000 - 0x503a0ff7  com.apple.iLMBAppDefPlugin 2.5.4 (252.1.7) <FE5F088E-DAB2-041F-2056-B4C44930A1B9> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBAppDefPlugin.ilmbplugin/Contents/MacOS/iLMBAppDefP lugin
          0x503a5000 - 0x503a7ff7  com.apple.iLMBFolderPlugin 2.5.4 (252.1.7) <7B80429E-335E-C73F-A4C8-5D6BF44FB2E5> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBFolderPlugin.ilmbplugin/Contents/MacOS/iLMBFolderP lugin
          0x503ac000 - 0x503b0ff7  com.apple.iLMBGarageBandPlugin 2.5.4 (252.1.7) <D8ACAF97-19F0-68CC-E789-EA7D95CF75C2> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBGarageBandPlugin.ilmbplugin/Contents/MacOS/iLMBGar ageBandPlugin
          0x503b8000 - 0x503baff7  com.apple.iLMBMoviesFolderPlugin 2.5.4 (252.1.7) <D727B496-D421-E727-AA70-6ABBD2B7D8EF> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBMoviesFolderPlugin.ilmbplugin/Contents/MacOS/iLMBM oviesFolderPlugin
          0x50533000 - 0x50536ff7 +libswt-cocoa-carbon-3449.jnilib ??? (???) <5BB65E15-2840-5C78-F72E-E1FA1B27948A> /Users/davemcgregor/Library/Application Support/Adobe/Flash Catalyst/configuration/org.eclipse.osgi/bundles/206/1/.cp/libswt-cocoa-carbon-3449.jnilib
          0x5053c000 - 0x5064bfe7  com.apple.WebKit 6533.20 (6533.20.25) <0C572899-8558-34EE-ABB4-3D163FFF5192> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
          0x5071e000 - 0x5071eff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <72FF6A91-C3EC-4634-A0FB-E1586C2404E4> /usr/lib/libmx.A.dylib
          0x5073a000 - 0x50740ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <218EC7C4-0520-2D8C-62EE-AA82D35448FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
          0x53ffa000 - 0x53ffaff7  com.apple.quartzframework 1.5 (1.5) <7DD4EBF1-60C4-9329-08EF-6E59731D9430> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x5581a000 - 0x55c51ff3  com.apple.RawCamera.bundle 3.6.4 (561) <DBA5D7C1-CD82-CE7F-5AE5-A0E4E128236F> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x55ceb000 - 0x55cf7ff7  com.apple.iLMBiMoviePlugin 2.5.4 (252.1.7) <A8406668-3E7F-A3A3-7779-170F9E553796> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBiMoviePlugin.ilmbplugin/Contents/MacOS/iLMBiMovieP lugin
          0x55cfe000 - 0x55d12ffb  com.apple.iLMBiPhoto8Plugin 2.5.4 (252.1.7) <F0FD3A8C-6054-BB5A-5073-DA4AD09C7CF3> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBiPhoto8Plugin.ilmbplugin/Contents/MacOS/iLMBiPhoto 8Plugin
          0x55d1a000 - 0x55d23ff7  com.apple.iLMBiPhotoPlugin 2.5.4 (252.1.7) <59E4D58D-6084-E98F-BD53-E5B6A6E3CF2E> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBiPhotoPlugin.ilmbplugin/Contents/MacOS/iLMBiPhotoP lugin
          0x55d2a000 - 0x55d32ff7  com.apple.iLMBiTunesPlugin 2.5.4 (252.1.7) <31E751D5-B724-9819-CFB6-E92D43CEFB2B> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBiTunesPlugin.ilmbplugin/Contents/MacOS/iLMBiTunesP lugin
          0x55d39000 - 0x55d3bff7  com.apple.iLMBPhotoBoothPlugin 2.5.4 (252.1.7) <87318BD9-AEA2-CB0C-D018-4B6D44434035> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBPhotoBoothPlugin.ilmbplugin/Contents/MacOS/iLMBPho toBoothPlugin
          0x55d5d000 - 0x55f5bff3  com.apple.JavaScriptCore 6533.20 (6533.20.20) <011E271D-4CA4-FFB0-2EDD-13C31C239899> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x55fb6000 - 0x56a08ff7  com.apple.WebCore 6533.20 (6533.20.24) <AB32AF40-6B73-D096-FC7B-7081F65EAA02> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
          0x56fcd000 - 0x56fd0ff7 +libEmbeddedPlayerJNILib.jnilib ??? (???) <8AF3001E-EF31-1A6E-C942-49BF66E876F1> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.embeddedplayer_1.0.0.273393/os/macosx/x86/libEmbeddedPlayer JNILib.jnilib
          0x56fd5000 - 0x56fd8ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.embeddedplayer_1.0.0.273393/os/macosx/owl/adbeape.framework /Versions/A/adbeape
          0x56fde000 - 0x57007feb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <E0F7666B-921D-C4D6-63B3-E8B445D26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
          0x5784b000 - 0x58664fc3 +com.adobe.adobeswfl ??? (2.0.0.7489) <C954CA64-9B28-A7FA-E391-C1C6524F1639> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
          0x58824000 - 0x5889dff7  com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x588d3000 - 0x58bccfef  com.apple.QuickTime 7.6.6 (1756.15) <C2567783-4EAC-6803-522B-D701B95C4DAE> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
          0x58c78000 - 0x58c7fff7  com.apple.agl 3.0.12 (AGL-3.0.12) <37255DC6-9FD1-45CC-AC80-A84FD2B5450A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
          0x58c86000 - 0x58cc6ff3  com.apple.securityinterface 4.0.1 (40418) <FED0C1B5-469E-ADFF-308E-C10B6A68AE45> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x58ce7000 - 0x58e2afef  com.apple.QTKit 7.6.6 (1756.15) <32C49374-14BC-53E7-FBFF-E11B42A41F56> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x58ee0000 - 0x58f38fe7  com.apple.datadetectorscore 2.0 (80.7) <3830B574-3B0B-76DA-390D-702D908A71F4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x58f61000 - 0x58fbbfe7  com.apple.CorePDF 1.3 (1.3) <EA168671-F44F-BFE4-AA7D-3801DA29A650> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x58fea000 - 0x59215ff3  com.apple.QuartzComposer 4.2 ({156.28}) <C99A68D1-4ED5-A3A8-887E-FAAC9DF5EC80> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x592f6000 - 0x5931dff7  com.apple.quartzfilters 1.6.0 (1.6.0) <F45520B0-6B27-CD57-54B1-203FE32120DA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x5933b000 - 0x5951dfff  com.apple.imageKit 2.0.3 (1.0) <B4DB05F7-01C5-35EE-7AB9-41BD9D63F075> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x595ef000 - 0x5965dff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x59699000 - 0x596c9ff7  com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
          0x596e8000 - 0x5973eff7  com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
          0x5976e000 - 0x59870fef  com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
          0x598d7000 - 0x59914ff7  com.apple.CoreMedia 0.484.20 (484.20) <FA68B18E-3FC2-EAA9-F70B-4ABD60E5474C> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x5992f000 - 0x59a5bffb  com.apple.MediaToolbox 0.484.20 (484.20) <D68A9F42-F7C6-5364-65A7-E72CEC6F854E> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x59abf000 - 0x59f78ffb  com.apple.VideoToolbox 0.484.20 (484.20) <C2D75C82-2EEE-6795-E50D-350A915B2475> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x5a020000 - 0x5a067ffb  com.apple.CoreMediaIOServices 134.0 (1160) <4CD78557-3CDA-A4B5-33CB-BBB876B4463D> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
          0x5a088000 - 0x5a103fff  com.apple.AppleVAFramework 4.10.23 (4.10.23) <57B7C626-F344-AB15-8556-00425FA765DE> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x5a10d000 - 0x5a14bff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x5a16e000 - 0x5a176ff7  com.apple.DisplayServicesFW 2.3.0 (283) <3FF74427-2240-9E23-876D-9A9CDAF62114> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x5a180000 - 0x5a190ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <95DC4010-ECC4-3A75-5DEE-11BB2AE895EE> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
          0x5a19b000 - 0x5a1dbff7  com.apple.ImageCaptureCore 1.0.4 (1.0.4) <CE815114-CEFA-4AF4-7365-7908428AB733> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x5a1fc000 - 0x5a1fdff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <1DD14B2E-E466-1A45-5CF7-947766F0ECD9> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
          0x5a45a000 - 0x5a52bfe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <41417F73-42C5-FFC3-E7A1-EF94602CDCD6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
          0x5aacc000 - 0x5aadafe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <B408E41B-D90F-4A04-DB72-D61C8C52BFBC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
          0x5aade000 - 0x5aaf0ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <EA696A00-4054-6F65-0F86-7901EAB5969F> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
          0x5aaf4000 - 0x5aaf4fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/SPBasic.framework/Versio ns/A/SPBasic
          0x5c219000 - 0x5c21aff7  com.apple.textencoding.unicode 2.3 (2.3) <A7D310DB-A5E6-C834-F72F-A66453834CC0> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
          0x5c435000 - 0x5c4b6fe7 +libNativeImporter.jnilib ??? (???) <3799F3A1-95E8-B41B-928E-791C6B698DD0> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libNativeImporter.jni lib
          0x5c540000 - 0x5c581fe3 +MFILoaderLibrary_v3.dylib ??? (???) <980979C6-57F2-53FB-1787-F9A136A240AF> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/MFILoaderLibrary_v3.dyli b
          0x5c5ab000 - 0x5c63cff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUConverter.framework/V ersions/3.6/libicucnv.dylib.36.0
          0x5c65b000 - 0x5c76ffff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeACE.framework/Versi ons/A/AdobeACE
          0x5c792000 - 0x5ccb8fff +AdobeAGM ??? (???) <2C7E8943-5433-E75E-E1D9-8C701D249504> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeAGM.framework/Versi ons/A/AdobeAGM
          0x5cdf9000 - 0x5ce35fff +AdobeARE ??? (???) <5E9AB1C8-3D42-2412-5277-C519F28ED120> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeARE.framework/Versi ons/A/AdobeARE
          0x5ce3e000 - 0x5ce59fff +AdobeBIB ??? (???) <DC9BC9B6-F46D-6EBB-5419-4B332D4A8265> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeBIB.framework/Versi ons/A/AdobeBIB
          0x5ce63000 - 0x5ce84ff7 +AdobeBIBUtils ??? (???) <87ABD1C3-14DA-0D8A-80C5-1D03DC7A20E8> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeBIBUtils.framework/ Versions/A/AdobeBIBUtils
          0x5ce90000 - 0x5d182ff7 +AdobeCoolType ??? (???) <432B8366-503C-E655-4DAF-E26DF7371E87> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeCoolType.framework/ Versions/A/AdobeCoolType
          0x5d20a000 - 0x5d5e2ff7 +AdobeMPS ??? (???) <13614867-4D80-EB74-FA7F-6136492478BA> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeMPS.framework/Versi ons/A/AdobeMPS
          0x5d711000 - 0x5dd45feb +AdobePDFL ??? (???) <49D6D58A-1EBB-424A-4CB0-8F9691E0991D> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePDFL.framework/Vers ions/A/AdobePDFL
          0x5de71000 - 0x5dec9ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeXMP.framework/Versi ons/A/AdobeXMP
          0x5ded8000 - 0x5dfa9fe7 +AdobeJP2K ??? (???) <2ABF10A7-540A-06C8-21FA-186263931DF9> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeJP2K.framework/Vers ions/A/AdobeJP2K
          0x5dfcb000 - 0x5ed0efff +com.adobe.psl AdobePSL 12.0.0.7471 (12.0.0.7471) <50E013B2-D1BA-E032-3440-44B603E0D6C2> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePSL.framework/Versi ons/A/AdobePSL
          0x5f04d000 - 0x5f073ff6 +AdobeAXE8SharedExpat ??? (???) <2C79B4A1-79AF-41DC-9EF1-53A4A98D396D> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeAXE8SharedExpat.fra mework/Versions/A/AdobeAXE8SharedExpat
          0x5f084000 - 0x5f26aff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeLinguistic.framewor k/Versions/3/AdobeLinguistic
          0x5f2f8000 - 0x5fca8fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUData.framework/Versio ns/3.6/libicudata.dylib.36.0
          0x5fcab000 - 0x5fd78ff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUInternationalization. framework/Versions/3.6/libicui18n.dylib.36.0
          0x5fddb000 - 0x5feb5fef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUUnicode.framework/Ver sions/3.6/libicuuc.dylib.36.0
          0x5fef5000 - 0x5ffd8fef +AdobePDFPort ??? (???) <E70AA3DA-D99B-6646-CB46-DBD16C0A8C2D> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePDFPort.framework/V ersions/A/AdobePDFPort
          0x6000d000 - 0x60145fe7 +WRServices ??? (???) <9E3A36AD-71F1-B9C7-AC3F-30A7E63C8B57> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/WRServices.framework/Ver sions/A/WRServices
          0x60187000 - 0x6027bff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
          0x602aa000 - 0x602bafe7  libConverter.dylib 169.1.0 (compatibility 1.0.0) <116CF161-A391-45BC-81B5-0954C87C8ABB> /System/Library/Printers/Libraries/libConverter.dylib
          0x602c8000 - 0x602caff7  com.apple.QuickTimeH264.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
          0x602d8000 - 0x6032bfe7 +libCoolTypeJNI.jnilib ??? (???) <52D924D3-E422-BB02-14CD-D7481CB21E15> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libCoolTypeJNI.jnilib
          0x6038c000 - 0x6054eff7  libawt.jnilib ??? (???) <89A76FB4-B6BF-59C8-DF09-5CD3C5938948> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libawt.jnilib
          0x605d6000 - 0x605d9fe7  com.apple.java.JavaRuntimeSupport 13.1.0 (13.1.0) <5FB78969-8DFA-7EB0-B321-9623032613AD> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.fram ework/Versions/A/JavaRuntimeSupport
          0x606e9000 - 0x606eefff +libHeadlights.jnilib ??? (???) <B05A37BE-0223-2032-623C-831B48FC6125> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libHeadlights.jnilib
          0x606f3000 - 0x60746ffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/LogSession.framework/Ver sions/A/LogSession
          0x6078e000 - 0x607b2fe7  GLRendererFloat ??? (???) <0C6A1BCF-97F0-F7D6-C840-2991681BB67C> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
          0x61c67000 - 0x61d17fe3  com.apple.QuickTimeImporters.component 7.6.6 (1756.15) <687BB3B8-15F6-47F3-C4A6-C6DC94098BEC> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
          0x61ff4000 - 0x61ff9fff  com.apple.AppleMPEG2Codec 1.0.2 (220.1) <CE69C1D8-796C-753F-AD3C-F1CC2B8C0AAD> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
          0x62100000 - 0x62237ff7  com.apple.CoreAUC 6.04.05 (6.04.05) <4A2BEE1A-A74A-746B-EFA6-470CD3354252> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x625fa000 - 0x62677ff7  com.apple.iLifeMediaBrowser 2.5.4 (468.1.1) <93A47E48-2C1F-7BAE-AF9F-5F52130BE59F> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
          0x626b5000 - 0x627fefe7  com.apple.iLMBAperture31Plugin 2.5.4 (252.1.7) <2E872C0E-C7E4-4C2E-1F46-8656958232FD> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBAperture31Plugin.ilmbplugin/Contents/MacOS/iLMBApe rture31Plugin
          0x6283f000 - 0x6298bfe7  com.apple.iLMBiPhoto9Plugin 2.5.4 (252.1.7) <01CBD6B3-71E9-B594-8E64-CC3C9C5E52DD> /Library/Application Support/iLifeMediaBrowser/Plug-Ins/iLMBiPhoto9Plugin.ilmbplugin/Contents/MacOS/iLMBiPhoto 9Plugin
          0x629cd000 - 0x62a98ff3  com.apple.iTunesAccess 9.1 (9.1) <54ED049F-708F-93B0-D1B3-A1CD2D989EAE> /System/Library/PrivateFrameworks/iTunesAccess.framework/iTunesAccess
          0x62bbc000 - 0x62d34fe7  GLEngine ??? (???) <0E1DF3E4-0EEE-9FD8-8F52-FFFCF0DF23A7> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
          0x64b00000 - 0x64b07ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x64b0f000 - 0x65a62fe3  com.apple.QuickTimeComponents.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
          0x664fa000 - 0x6654ffef  com.apple.AppleProResDecoder 2.0 (223) <773F7C18-BE38-10C8-3745-0EB45E811A11> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
          0x66587000 - 0x665c3fe3  com.apple.QuickTimeFireWireDV.component 7.6.6 (1756.15) <9C48FD18-B6B8-10FA-3B09-47915626A73C> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireD V
          0x665cf000 - 0x665eafef  com.apple.AppleIntermediateCodec 1.3.2 (153) <D42634C1-8BDA-31ED-5216-13CB19BA7D1B> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
          0x66700000 - 0x667defef  com.apple.QuickTimeMPEG4.component 7.6.6 (1756.15) <FE001B3F-BFB4-00E6-4C32-D7F2A8E5EF35> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
          0x66801000 - 0x66813ff7  com.apple.CoreMediaAuthoring 0.706 (706) <81D68084-D7BD-E52E-9B1C-C8EC0FCECE3C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x66824000 - 0x6683dfe7  com.apple.applepixletvideo 1.2.19 (1.2d19) <3E236E2A-5646-8A6D-FDEE-A21C468161C0> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
          0x66842000 - 0x66c27fe3  QuickTimeH264.scalar ??? (???) <275FEF5D-B116-979D-9637-CDCEE2DDC820> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
          0x66dc4000 - 0x66faafef  com.apple.audio.codecs.Components 2.0.3 (2.0.3) <B7C712BC-43E0-6B3F-003B-569194195EEC> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
          0x70000000 - 0x700cbfff  com.apple.audio.units.Components 1.6.4 (1.6.4) <67DA329D-A571-6066-953C-4BBFCBF87BD5> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
          0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <1C06ECD9-A2D7-BB10-AF50-0F2B598A7DEC> /usr/lib/dyld
          0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <A6FD4184-1017-59F6-990E-785BDF6202BE> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
          0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <59936EB5-5FA4-EEEB-9858-E9BF50AB1776> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
          0xfa100000 - 0xfa192fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
          Model: iMac11,3, BootROM IM112.0057.B00, 4 processors, Intel Core i5, 2.8 GHz, 4 GB, SMC 1.59f2
          Graphics: ATI Radeon HD 5750, ATI Radeon HD 5750, PCIe, 1024 MB
          Memory Module: global_name
          Bluetooth: Version 2.4.0f1, 2 service, 19 devices, 0 incoming serial ports
          Network Service: Built-in Ethernet, Ethernet, en0
          Serial ATA Device: ST31000528AS, 931.51 GB
          Serial ATA Device: OPTIARC DVD RW AD-5680H
          USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000
          USB Device: LaCie Storage, 0x059f  (LaCie), 0x1029, 0xfa140000
          USB Device: Generic USB Hub, 0x058f  (Alcor Micro, Corp.), 0x9254, 0xfa130000
          USB Device: CanoScan, 0x04a9  (Canon Inc.), 0x2225, 0xfa133000
          USB Device: DataTraveler 2.0, 0x0930  (Toshiba Corporation), 0x6533, 0xfa134000
          USB Device: HASP 2.17, 0x0529  (Aladdin Knowledge Systems), 0x0001, 0xfa132000
          USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa120000
          USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000
          USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0xfa111000
          USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000
          USB Device: ET-0405-UV1.1-1, 0x056a  (WACOM Co., Ltd.), 0x0010, 0xfd130000
          USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd110000
          USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000
          • 2. Re: Catalyst keeps crashing
            Dave McGregor Level 1
            Step5 in the trouble shooting guide suggested setting up a New User Account and launching the application under there.
            This worked. Catalyst runs! Yay...
            Unfortunately it is not going to be practical running it by this method permanently. Although I realise it may help in isolating the problem.
            There's obviously some sort of conflict going on between Catalyst and something else. The question is what?
            Remember it was all working fine yesterday. I can't for the life of me think of what I've done to introduce any conflict.
            Step6  suggests finding and deleting any AdobeFnt*.lst files from the system file (these are temporary font cache files that can sometimes cause problems).
            Trouble is: I couldn't find any so I could not complete this step.
            Step7 says "Troubleshoot font issues" – remove or disable non-essential fonts. It's true I have lot's of fonts on my computer. I manage them with Font Agent Pro. However, each of the last previous times I've tried launching Catalyst, I've had NO other programs running including my font program. Yet Catalyst still crashes.
            Step8 This is not applicable because it's Windows specific and I'm on a Mac
            Step9 Says search the Adobe knowledge base for errors. If I was getting an error message I could do this. As it happens Catalyst just simply crashes – that's all.
            Step10 says Run the Adobe Support Advisor, which is an AIR application designed to identify and analyse installation issues. This I did but after doing so it said:
            "inspection could not identify any issues" Please contact Adobe for further assistance.
            This has taken me several hours so far. I don't seem to be getting anywhere. Can somebody please help.
