4 Replies Latest reply on May 31, 2011 9:50 PM by A.kameshwaran
    line with a arrow
    A.kameshwaran Level 1
      Hi All,
           I want to draw multiple line with a arrow.  Please guide me how can i do it by code dynamically. exactly as below.
      Kameshwaran A.
        • 1. Re: line with a arrow
          LukeElChul Level 1
          create an empty symbol
          put this code in it.
          //***** Set some opening parameters
          onClipEvent (load) {
          //Make original line invisible
          _root.line._visible = 0;
          //Initiate some variables
          number_lines = 0;
          line_active = 0;
          //***** Every time the mouse button is released...
          onClipEvent (mouseUp) {
          //Get the position of the mouse
          origin_x = _xmouse;
          origin_y = _ymouse;
          //Increase the number of lines by one
          //Generate a new line name
          name = "line"+number_lines;
          //Duplicate a new line
          _root.line.duplicateMovieClip(name, number_lines);
          //Position the line's end point at mouse position
          _root[name]._x = origin_x;
          _root[name]._y = origin_y;
          //Update line length / orientation
          _root[name]._xscale = _root._xmouse-origin_x;
          _root[name]._yscale = _root._ymouse-origin_y;
          //If this is the start of a new shape
          if (!line_active)
          //Set the line tracking variable
          line_active = 1;
          //Set the start point of the new shape
          start_x = origin_x;
          start_y = origin_y;
          //***** Every time the mouse is moved
          onClipEvent (mouseMove) {
          //If there's a line currently being drawn...
          if (line_active)
          //***** When a key is pressed
          onClipEvent (enterFrame) {
          //If it's the Enter key
          if (Key.isDown(Key.ENTER))
          //Join the end point of this line...
          //...to the start point of the first line in this shape
          _root[name]._xscale = "";
          _root[name]._yscale = "";
          //Reset line-tracking variable
          line_active = 0;
          draw a line convert it to a symbol and give it an instance name of line.
          and there you can draw lines.
          detach the lines by pressing enter.
          and thats it.
          your welcome in advance (:
          INPORTANT to leave all your symbols in the scene not in the libery are it will not work
          Message was edited by: xFARRELLx
          • 2. Re: line with a arrow
                  Thanks for the reply. What i need is a line with arrow and should not be attached from the library. It should be drawn in runtime on demand.
            • 3. Re: line with a arrow
              LukeElChul Level 1
              so you whant the line to just draw by itself.
              you whant an arrow go in the sybol line and draw an arrow.
              • 4. Re: line with a arrow
                I will be having x and y points. With that i will be drawing the line. Now i need to add arrow inorder to show the line flowing direction. give some idea for me.
